Old Aug 01, 2015, 03:31 PM
planepainter is offline
Find More Posts by planepainter
planepainter
planepainter's Avatar
Mt. Juliet, TN
Joined Sep 2008
RealFlight 7.5 lockup problem
Hi Guys. I just insatalled RealFlight 7.5 on to my home computer so I could brush up on my skills and also be able to "fly" when the weather is bad or other issues where I can't get to the field.
I love this sim!! I can fly pattern planes as well as sailplanes and slopers.
But in the last few days while I am flying on the program, the computer has locked up 5 times to black screen and can't be restarted except by a force quit. After I do that the computer comes on as normal and is ok until the next lockup.
Has anybody else had this issue?
My system is:
Dell 960 PC
Windows 7 Pro
Intel Core 3.3 GHz
64 bit OS
5.00 GB ram (4.87 usable)
Any info would be appreciated.
planepainter is offline Find More Posts by planepainter
Old Aug 01, 2015, 04:59 PM
jegouvrc is offline
Find More Posts by jegouvrc
jegouvrc's Avatar
United States, FL, Kendall
Joined Jun 2015
Do you have The latest Version of RF7.5
Is It Version: 7.50.015?
jegouvrc is offline Find More Posts by jegouvrc
Old Aug 01, 2015, 05:59 PM
planepainter
Mt. Juliet, TN
Joined Sep 2008
Hello jegouvrc. Everything I am reading on the disk installation guide says 7.5
Old Aug 01, 2015, 07:33 PM
jegouvrc is offline
jegouvrc's Avatar
Joined Jun 2015
try going to the Main Menu Click on help then on About
and see what's your product Version...
Old Aug 01, 2015, 09:30 PM
planepainter
Mt. Juliet, TN
Joined Sep 2008
Ok, you are correct. it is 7.50.015
Old Aug 02, 2015, 12:04 AM
jegouvrc is offline
jegouvrc's Avatar
Joined Jun 2015
OK. You have the latest version.
I have W8 but In W7 It should be the same.
Find out what type of Video card you have in your computer.
Old Aug 02, 2015, 02:20 PM
jegouvrc is offline
jegouvrc's Avatar
Joined Jun 2015
Sometimes computers starts to fail when overheated. I have to use my vacuum cleaner once in a while to make sure that all the vents and fans are not obstructed by dust buildups.
Remember when your playing FR7.5 your CPU and Graphics Card will heat up. up to a point it can start failing. There is a thin line in the temperature ranges that can change everything. Maybe just cleaning up those vents to keep the airflow will do the trick.
Jorge...
Old Aug 02, 2015, 02:27 PM
planepainter
Mt. Juliet, TN
Joined Sep 2008
Ok. Thanks. I will give it a try and thank you for the suggestions. I will also look up the info above when I have a few minutes. Regards, Donald.
Discussion Taranis X9D with RealFlight 7.5 a_user Radios 5 Jun 04, 2015 12:19 AM
Found RealFlight 7.5 Wired Interface TheDoug Aircraft - General - Miscellaneous (FS/W) 1 May 29, 2015 11:12 AM
Sold RealFlight 7.5 Wired Interface kennywiz Aircraft - General - Miscellaneous (FS/W) 3 May 26, 2015 09:28 AM
Sold RealFlight 7.5 w/Wireless SLT Interface daskip87 Aircraft - General - Miscellaneous (FS/W) 5 May 17, 2015 07:12 PM
Sold Realflight G4 Sim and link to version 7.5 upgrade planewrecker Aircraft - General - Miscellaneous (FS/W) 2 May 04, 2015 05:51 PM
