Old Aug 28, 2015, 11:30 AM
kallend is offline
Find More Posts by kallend
Flying R/C since 1964
kallend's Avatar
United States, IL, Chicago
Joined Sep 2004
Skydive door for hangar 9 DHC-6 Twin Otter
The Hangar 9 model of the USAF Academy's Twin Otter has the normal Otter door instead of the roll-up lexan door that is used on this particular aircraft.
http://img1.jetphotos.net:8080/img/4...1338423270.jpg
Here is a good picture of such a door: http://2.bp.blogspot.com/-yHUcit_VLD...2014_1024A.jpg
Has anyone put a roll-up door on their Twin Otter? If so, can you give details?
kallend is offline Find More Posts by kallend
Old Aug 31, 2015, 11:57 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Are you plan on sending divers out the door? You can't really put anything behind the CG, the main gear is too far forward to have anything behind it. Actually I have problem with the nose wheel not staying on the ground when I tried to push the CG back to make it flies better!
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Sep 01, 2015, 04:35 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Seems like you could easily replicate that door with strips of plastic taped together with silver mylar tape.
http://www.uline.com/BL_6448/Metalized-Mylar-Tape
To open/close the door you can probably modify one of those mini screwdrivers... runs on 5-6Vdc, same as a servo:
http://www.homedepot.com/p/General-T...-500/202025658
So you build a track to run the doors in and a spindle to wind the door on... some kind of up/down/off switch for the screwdriver.
As Brian says you gotta worry about the CG, but you can pack your parachutists over the CG then feed them out one at a time progressively so as not to affect the balance too much, or dump them all out at once so quickly that the imbalance recovers before the tail gets heavy.
For a progressive feed you could make some sort of screw feed with a clock spring attached to vending-machine style helical coil.
http://www.wired.com/images_blogs/ga...05/MG_5621.jpg
Or you could shoot them out using a multi-shot rubberband-gun trigger:
http://www.instructables.com/id/Rubb...un-Multi-Shot/
Or simply have a sloped floor than dumps towards the door so they are gravity fed... and hope they don't get jammed. Careful packing and a smooth chute would probably prevent any problems.
However you do it, I look forward to seeing your solution.
warhead_71 is offline Find More Posts by warhead_71
Old Sep 03, 2015, 02:45 AM
kallend is offline
kallend's Avatar
Joined Sep 2004
Brian, an EAJ
No, just wanted to make it look like the full-sized plane it's modeled after.
Latest blog entry: Using a DX9 to "strobe" LED...
Old Sep 03, 2015, 09:04 PM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
I wonder if one of the transparent roll-top type covers off of a pencil box would be big enough. But if you dont need it to open, clear plastic and alum or chrome striping tape would do it
David Hogue is offline Find More Posts by David Hogue
Old Sep 12, 2015, 06:47 PM
pasquale91 is offline
Find More Posts by pasquale91
United States, TX, Edgewood
Joined Sep 2014
I helped replace one on our DZ's Otter after it got sucked off in-flight.
pasquale91 is offline Find More Posts by pasquale91
Old Sep 14, 2015, 02:53 PM
kallend is offline
kallend's Avatar
Joined Sep 2004
Eloy?
Old Sep 14, 2015, 04:24 PM
BQ97 is offline
Find More Posts by BQ97
Joined Feb 2013
Eloy is between Tucson and Phoenix AZ. I bet it was at Skydive Dallas.
BQ97 is offline Find More Posts by BQ97
Old Sep 20, 2015, 12:59 PM
Joined Sep 2014
Originally Posted by kallend View Post
Eloy?
Goldcoast, when it was still in Moss Point, was my home DZ
Only been in Texas 4 yrs, Mobile, AL and Lafayette LA before that.
Old Sep 20, 2015, 09:59 PM
kallend is offline
kallend's Avatar
Joined Sep 2004
Ha!
I was at Z-Hills when a Skyvan door came off in flight. Landed in the swamp.
Old Sep 21, 2015, 11:38 AM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Ahhh... I can't believe I didn't think of this before: LEGOs!
How To Make Lego Automatic Garage Shutter Doors With Electric Power Functions (1 min 29 sec)
Old Sep 21, 2015, 02:03 PM
Joined Sep 2014
https://www.youtube.com/watch?v=ayIW1jTvazk
I think you have a winner right there!
For Sale Hangar 9 Twin Otter - BNF cnk789 Aircraft - Electric - Airplanes (FS/W) 3 Dec 22, 2015 05:34 PM
Sold Hangar 9 Twin Otter W/ 2 O.S 55 AX's Rotten40851 Aircraft - Fuel - Airplanes (FS/W) 0 Jun 11, 2015 11:30 AM
Sold Hangar 9 Twin Otter BNF cnk789 Aircraft - Electric - Airplanes (FS/W) 1 Jun 09, 2015 10:38 PM
Found Hangar 9 Twin Otter shantz_loran Aircraft - Fuel - Airplanes (FS/W) 5 May 17, 2015 08:50 PM
Sold Plans and Accessories for 1/6 Scale (130") DHC-6 Twin Otter Wolpertinger Aircraft - Fuel - Airplanes (FS/W) 2 Jun 01, 2011 08:54 PM
