Old Aug 28, 2015, 09:57 AM
czorzella is offline
Find More Posts by czorzella
czorzella's Avatar
United States, FL, Kissimmee
Joined Jan 2012
Originally Posted by struggleforlife View Post
Do I understand correctly that the 4010 is protected against this kind of mistake?
Not all. Only V2.
Since December 2014 the new Junsi 4010duos have a built in balancer protection. You should ask for this when you buy a new one!
czorzella is offline Find More Posts by czorzella
Old Aug 28, 2015, 10:09 AM
Liberty10 is offline
Find More Posts by Liberty10
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
I protect my 308 with buddyrc safe 40A Paraboard V3
Liberty10 is offline Find More Posts by Liberty10
Old Aug 28, 2015, 10:13 AM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
That is a nice solution.
However, it being a parallel board, I don't think that will work on a 8s lipo with 2 (4s) connectors.
Or am I being silly?
struggleforlife is offline Find More Posts by struggleforlife
Old Aug 28, 2015, 10:41 AM
Yin & Yang
Liberty10's Avatar
Joined Jul 2011
It's only up to 6S which suit me since 6S is my primary battery. Not sure how to deal with dual balance plugs cause I've never had any.
Old Aug 28, 2015, 11:52 AM
czorzella's Avatar
Joined Jan 2012
It doesn't. You could use this parallel board from Revolectrix.
http://www.revolectrix.com/MPA_XH.htm
Old Aug 28, 2015, 10:53 PM
tfmccull is online now
Find More Posts by tfmccull
tfmccull's Avatar
Joined Aug 2012
Just got a 308duo, plugged it in for the first time and nothing but a white screen. the buttons beep when i press them, but i get no interface whatsoever. any ideas? did i get a dud unit.
tfmccull is online now Find More Posts by tfmccull
Old Aug 29, 2015, 12:39 AM
IntegrityHndywrk is online now
Find More Posts by IntegrityHndywrk
IHW Heli Division
IntegrityHndywrk's Avatar
United States, FL, Palm Coast
Joined Mar 2012
Could just be a loose screen ribbon wire. You could open it up and see if you can fix the connection.
IntegrityHndywrk is online now Find More Posts by IntegrityHndywrk
Old Aug 29, 2015, 10:26 AM
T.A.Z is online now
Find More Posts by T.A.Z
Obsession, not a hobby
T.A.Z's Avatar
United States, AZ, Phoenix
Joined Sep 2013
Why would you not contact the place of purchase?
T.A.Z is online now Find More Posts by T.A.Z
Old Aug 29, 2015, 10:59 PM
scottwest is online now
Find More Posts by scottwest
Talk to me Goose
scottwest's Avatar
United States, OR, Portland
Joined Oct 2012
A question for you parallel charging gurus.
Could the balance only function of the icharger be run initially to safely equalize packs connected to a parallel board with batts of varying voltage( example: one pack with cells from 3.5 volts and one pack with cells of 4 volts) prior to parallel charging?
Thanks!
scottwest is online now Find More Posts by scottwest
Old Aug 30, 2015, 07:06 AM
RNFLY is offline
Find More Posts by RNFLY
Germany, BY, BA
Joined Sep 2014
The answer is : no!
The „balance only“ function is not the right way, because the packs equalize themselves immediately, when the packs been connected together on the parallel board. The charge current into the more discharged pack and the parallel board would be too high.
Some users suggest in this case, only connect the balance plugs on a save paraboard with polyfuses on the balance connectors. This should limit the current through the balance wires. I didn`t try this.
The saver way is, to discharge/charge each pack separate to a common storage level.
Maybe you could put the energy of the more charged pack, by using the „channel to channel“ charge function and stop it manually, when roughly even.
RNFLY is offline Find More Posts by RNFLY
Old Aug 30, 2015, 07:20 AM
Yin & Yang
Liberty10's Avatar
Joined Jul 2011
The short answer is no.
You can discharge the charged packs into the discharged packs using regenerative discharge mode. Personally as long as I have at least 2 discharged packs I'll connect the 2 discharged packs mains to the board and then connect 1 full charged lipo and discharge it into the others. I've monitored it with a wattsup meter and on 6S 3300mah it peaked at 20A which is only 3C into the 2 packs and it does not hold that peak for very long. That's actually a rare scenario for me. Usually I have 6-8 discharged packs and 2-4 still charged.
Old Aug 30, 2015, 09:28 AM
Talk to me Goose
scottwest's Avatar
Joined Oct 2012
Not what I wanted to hear, but thanks guys.
Old Aug 30, 2015, 10:04 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Use a simple resistor.
http://www.rcgroups.com/forums/showthread.php?t=1255751
mrforsyth is online now Find More Posts by mrforsyth
Article iCharger 4010Duo - Review CSpaced Batteries and Chargers 245 Aug 08, 2015 11:12 AM
Question What else has Jack been hiding from us? Newtron North Coast Electric Flyers 2 Mar 05, 2012 10:09 PM
Suggestion How do I know if my warning point has been retracted AndyOne Site Suggestions / Complaints 2 Mar 05, 2012 08:21 AM
Sold message has been deleted sonicboom24 Cars - Cars and Parts (FS/W) 0 Feb 22, 2012 12:34 PM
