Old Aug 25, 2014, 09:48 AM
JohnET's Avatar
United States, NC, Charlotte
Joined Apr 2013
Nhut,
One option is to use a trim potentiometer in conjunction with your resistor. Something like this should work (either in series or parallel depending on if you are high or low) ;
http://www.mcmelectronics.com/produc...Fe5lOgod_hsAeQ
I have a bunch of old electronics laying around and found one that would work on an old PC power supply.
Or, you could get a 15k one and not need the standard resistor;
Try to find one as close to 1% as possible and be sure to test it with a multimeter before connecting it to the OSD Pro to ensure you DO NOT exceed 16v!
Regards, John
JohnET is offline Find More Posts by JohnET
Site Sponsor
Old Aug 25, 2014, 10:21 AM
Joined Jul 2012
Incorrect voltage reading for second battery
Originally Posted by JohnET View Post
Nhut,
Regards, John
Thanks John for your quick feedback.
But Its pity for me that the link does not work and I also dont have an old PC power supply. Could you send me a different link?
I have tried 15k 5% but nothing is better. Does it still need a trim potentiometer?
I use 3s for video so obviously it does not exceed 16v, right?
Thanks.
Nhut
NhutSgn is offline Find More Posts by NhutSgn
Old Aug 25, 2014, 10:34 AM
JohnET's Avatar
Joined Apr 2013
Sorry, this link should work.
http://www.mcmelectronics.com/product/287-1116
Correct, 3s will not exceed 16 volts.
Regards, John
Site Sponsor
Old Aug 26, 2014, 12:22 PM
Joined Jul 2012
Thank you, John.
I will try to find it here.
Regards,
Nhut
Old Sep 07, 2014, 10:52 AM
Bigmic's Avatar
Norway, Sogn og Fjordane, Askvoll
Joined Aug 2012
Hi. Have som problems to come back to on screen menu after i have choosed aux1 and 2 to rth test. After this i can't open the menu with the aux switch - only the rtl test comes on and off and i can't go to menu to switch back again to select the menu ...
Bigmic is offline Find More Posts by Bigmic
Old Sep 07, 2014, 12:31 PM
Bigmic's Avatar
Joined Aug 2012
Ok - my foul! I need a 3 pos.-switch - Now it works! :roll eyes:
But how to activate RTH-test with a switch (without to go to menu). I know that it had worked before I did the update to the newest sw. Now I didn't know where I can enable it..
Old Sep 08, 2014, 05:02 AM
Canada, ON, Thunder Bay District
Joined Apr 2007
I use throttle cut on my Futaba 7C to test RTH.
Fast Guy is online now Find More Posts by Fast Guy
Old Sep 27, 2014, 06:59 PM
United States, PA, Lewistown
Joined Aug 2014
I just received my pro package and I am using it for fpv stand alone from my flight controller or Rx in a quad copter. I have selected to view the radar option to view. My question is how is the home position determined in my configuration or is it not possible for the home point to be derived without input from the FC?
Joe
joeg1717 is online now Find More Posts by joeg1717
Old Sep 28, 2014, 07:59 AM
Joined Apr 2007
Joe
Do you have the GPS and data logger?
Old Sep 28, 2014, 08:08 AM
Melbourne, Australia
Joe
The Home position is set when you connect power to the eLogger and the GPS has acquired position fix.
Geoff
garris2 is offline Find More Posts by garris2
Old Sep 28, 2014, 05:16 PM
Joined Aug 2014
great ....thanks guys !
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
