Old Sep 14, 2014, 02:52 PM
Axle209
Sacramento
Joined Jan 2006
Thanks all.
Axle209 is offline Find More Posts by Axle209
Old Sep 19, 2014, 03:21 PM
Axle209
Sacramento
Joined Jan 2006
Motor Question
I have repaired my Mystique and replaced the motor with Hacker A3012x v3 700 KV. My issue is prop adapter that came with the motor was a little long, so I used the prop adapter that came with nose cone prop assembly for the Mystique, I placed two washers behind prop to ensure the prop did not rub on fuse. I tried tighten down real tight and ran the motor but prop comes off after about 10 second of a motor run, tried this twice with same results (nose cone not installed yet). So what prop adapter and prop did you guys use with this motor in the Mystique.
Old Sep 20, 2014, 05:12 PM
Ultra Violet
Electromagnetic's Avatar
Joined Feb 2013
Wing Support Issue?
Has the wing tube support design been revised? I have read reports of failures last year.
Electromagnetic is online now Find More Posts by Electromagnetic
Old Sep 24, 2014, 11:01 AM
Joined May 2013
Motor
Hi all
Of course there are many motor / props options. But the easy way is the Eflite 25 / Eflite alum spinner with prop. Itīs just screw in place. CG, back plate gap, prop assembling and wire fittings, all this issues are solved in just one step. I never missed a prop.
Power is more than enought to put Mystique at good thermal height in 20 seconds.
For shure there are other more powerfull motors, but only a special need for extra power may explain other options, IMHO.
Please I don't want open a debate about motor preferences. I just prefer the simplest way to do things.
Once I needed buy all the stuff for Mystique, I ordered as per manual, except for radio and servos ( mine is all JR ). E Flite 25 motor, E flite speed 60A and E Flite prop assembly. Battery is a Thunder Power 3S 3300 mAh.
After more than 70 hours of flying time I'm convinced had gone the right way. After all this time I needed only change a prop blade due a scratch with a little rock at landing and a tailplane carbon rod.
crsc
crsc is offline Find More Posts by crsc
Old Yesterday, 07:48 PM
Joined Aug 2010
Bump
thekubiaks is online now Find More Posts by thekubiaks
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
