Old May 15, 2015, 04:08 PM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
Field Chargers for Winch Batteries
Hi
Charging your winch batteries at home isn't difficult with A/C equipment such as the ctek range.
On the field you can use your rc charger but they are 14v. It seems 14.4v is correct for wet batteries.
I've got an optima yellow top AGM battery and want to charge it at 14.6 or 14.7v on the field.
Does any one know of chargers that are good for agm from a 12v supply?
Tom
satinet is offline Find More Posts by satinet
Old May 15, 2015, 08:59 PM
pigly is offline
Find More Posts by pigly
PaulG
Newcastle, NSW Australia
Joined Dec 2004
Inverter?
Tom,
Why not get an inverter to run your normal charger from the battery you would usually use for recharging on the field? This is used by caravanners. You will probably need a good quality pure sine wave output but there are not many watts involved (less than 100 W) , just remember that the output from the inverter is 240V and thus potentially lethal, but proper precautions should do the trick. Or do you want a higher charge rate than 5 A ? My measurements are that my typical launches consume about 1 Ahr, so your normal charger would be putting the energy back in the battery for a launch rate of about every 15 min.
I have had no problems running printers and laptops on the field using 12V batteries and a 600W invertor but could not get my portable camping fridge to work with 600W due to the starting current surge requirements.
pigly is offline Find More Posts by pigly
Old May 16, 2015, 03:26 PM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
I had seen those on the website i bought my battery from. I don't know much about them so need to do some research
Question winch battery chargers rdwoebke Sailplane Talk 15 May 18, 2015 06:14 PM
Mini-HowTo Power Cell/12V Battery Both Replaces DC Power Source and Also is a Field Charger drjay Batteries and Chargers 7 Dec 31, 2014 01:44 PM
Discussion Battery for a field charger? theskunk Electric Plane Talk 10 Jul 22, 2014 06:26 PM
Sold Misc OEM Chargers for lipo's, also 12V chargers for field battery. jl33fr33 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 29, 2014 04:02 PM
Question Field Battery & Charger For Field Battery JoeCrasher Batteries and Chargers 6 Dec 04, 2003 07:45 PM
