Old Dec 18, 2012, 12:42 PM
carrerars's Avatar
Joined Aug 2008
Gulfstream G-V
Hello everybody,
actually Iīm building a 1:17 scale G-V.
Wingspan is about 1.7m.
70mm CS fans.
One or two 3300mAh 4s
All the best
Markus
carrerars is offline Find More Posts by carrerars
Old Dec 18, 2012, 02:20 PM
Up-Out-&-Gone
demondriver's Avatar
Charelston SC U.S.A.
Joined Mar 2007
OHHHHHHH-YEAHHHHH! Thats One Sexy Bird Carreras!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Introducing The "Demon-Claw"...
Old Dec 18, 2012, 02:26 PM
Doushiyou12's Avatar
Joined Feb 2010
Beauty.
Count me in
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Dec 18, 2012, 09:01 PM
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
North AL, USA
Joined Nov 2009
Those nacelles have some attitude!
ruff1 is offline Find More Posts by ruff1
Old Dec 18, 2012, 09:42 PM
747-400
alaska
Joined Mar 2007
Nice!
w747 is offline Find More Posts by w747
Old Dec 18, 2012, 10:02 PM
MD
Joined Aug 2010
I flew GV's for 7 years and still have lots of my flight/maintenance manuals if you need any info. Looks great so far!
Asymair95 is offline Find More Posts by Asymair95
Old Dec 19, 2012, 01:05 AM
carrerars's Avatar
Joined Aug 2008
Thank you all for your nice replies.
Still investigating the cg (troublemaker as always)
Can anyone please confirme/correct the cg shown in the attached pic?
Any help is greatly appreciated!!
Thank you
Markus
Old Dec 22, 2012, 06:46 AM
carrerars's Avatar
Joined Aug 2008
Anyone out there to help me with my cg issue??
Thank you
Markus
Old Dec 22, 2012, 07:48 AM
The Depronizer
Andre Kochanski's Avatar
Germany, NRW, Dortmund
Joined Aug 2012
Hey Markus,
can you send me the complete dimensions of the plane? I can feed my program with these and give you the correct CG.
greetings!
Andre Kochanski is offline Find More Posts by Andre Kochanski
Old Dec 22, 2012, 10:45 AM
Up-Out-&-Gone
Joined Mar 2007
Thank you
Markus
If your CG calculator is accurate & your data is sound then it should be right.
Old Dec 22, 2012, 12:40 PM
carrerars's Avatar
Joined Aug 2008
Thank you Andre and DD,
here the data of my plane:
Length: 173cm
Wingspan 168cm
(the rest you find in my PDF)
Iīve tried several cg calculators and got different results so I hope of a confirmation of one of you experts.
Thanks again
Markus
Old Dec 22, 2012, 12:45 PM
Up-Out-&-Gone
Joined Mar 2007
Markus from what I've seen this si the most reliable CG calculator online.
http://www.nasascale.org/howtos/cg-calculator.htm
Old Dec 22, 2012, 12:49 PM
The Depronizer
Joined Aug 2012
For my calculation i need the complete horizontal stabilizer dimensions and the distance to the wings leading edge.
If you already used this program you can trust it. It never let me down!
greetings!
Old Dec 22, 2012, 05:10 PM
carrerars's Avatar
Joined Aug 2008
Hi,
attached you find dimensions of horizon stabilizer.
Distance from leading edge of main wing to leading edge of horizontal stabilizer is 910 mm.
Hope thatīs enough information.
Markus
Old Dec 22, 2012, 08:21 PM
The Depronizer
Joined Aug 2012
Alright, I think i have reasonable results now. The center piece is a little wider than the fuse to compensate for the wing box and the lift of the fuselage.
The CG the program suggests is a little nose-heavy when you compare it with the one you have.
Thats because your geographical solution is just a rough guess. It doesnīt take the horizontal stab into account.
Anyhow you are on the safe side if you place the CG at 270mm from root leading edge.
More important is the choice of airfoil and wing incidence. I guess that you are using the ClarkY11,7% and put the flat bottom horizontally or parallel to the fuselage longitudinal axis. If the horizontal stab is parallel to the bottom you will have a "difference of incidence" of about 2 degrees, which is perfect for our airliners.
If I can help you with more info, just let me know!
EDIT: forgot the pics
Build Log Gulfstream G-IV SP InvalidUsername RC Airliners (Commercial, Cargo, Troop Carrier) 35 Sep 18, 2012 04:12 PM
For Sale Gulfstream G-IV kit with 2 Minifan 480s Thomas B Aircraft - Electric - Jets (FS/W) 2 Aug 26, 2007 12:32 PM
Sold Gulfstream G-IV EDF silent runner Aircraft - Electric - Jets (FS/W) 9 Apr 04, 2007 11:00 PM
Gulfstream G-IV U812 Electric Ducted Fan Jet Talk 28 Jun 12, 2005 05:21 PM
Looking for Gruman Gulfstream G-1 plans Capjun Scale Kit/Scratch Built 1 Mar 27, 2005 05:01 PM
