Old Jan 22, 2015, 02:24 PM
Joined Oct 2007
Boscam head tracker goggle with spektrum
Hi
its been a long time that I am looking for the right way to solve this problem ?
Description:
BOSCAM HEAD TRACKER GOGGLE WITH SPEKTRUM ?????
pls and pls everyone don't change the desiccation subject like every forum I read . thay start with the same subject and end up whit something els. I am looking for the right solution for this problem only and to fix it we need to focus .
so as far from my looking around and web searches I get this info:
boscam come with 2 cables one for futaba and one jr or fresky or turingy
so that the cable we need and its have a 3.5 jack and power connecter in the TX side and 4pin square connecter in the goggles side . like this one
Description:
and I read many post that spektrum will not work due to the lack of flexibility about what channels can be overridden in trainer mode.
so I want to show everyone this video
DIY - Spektrum Head Tracking Cable - RCGroups (5 min 20 sec)
also its work perfect with fat shark see this
Fat Shark FPV setup and Head Tracking on Spektrum DX8 (10 min 48 sec)
that mean it work but we just need to make more testing to find out how to do it and how to connect it right .
I start with the 1st test which is cut and connecting mono cable to that comes with boscam (PIC #1)
and test number 2 is without cutting any cable and adding battery to that cable and see (question) what voltage should I use 7.4 or 11 volt on that cable ?
what is the right setup in my DX18 SPEKTRUM to have the right way to work when I press the trainer switch ?
I will follow up with the result from my test as soon and we will see.
any one have any idea he is more than welcome
so pls any help is appreciated
cool_t5 is offline Find More Posts by cool_t5
Old Jan 28, 2015, 09:09 AM
Joined Oct 2007
So as working going
this what i get until now and hopefully someone will helps us here.
See the video
Spektrum with boscam goggles and head tracker work (1 min 24 sec)
also
Spektrum with boscam goggles and head tracker work (2 min 3 sec)
Any help on the glitching and moving limits pls
Sold Skyzone FPV Goggles 5.8GHz Dual Diversity 32CH Receiver With Head-Tracker (V2) KurTecH FPV Equipment (FS/W) 10 Jan 21, 2015 10:20 PM
For Sale Skyzone FPV goggles with diversity and head tracker capable wingerit Aircraft - Electric - Multirotor (FS/W) 6 Dec 18, 2014 03:30 AM
Sold FatShark RCV922 Aviator Edition FPV Goggles with Head Tracker Module HansAuf FPV Equipment (FS/W) 7 Feb 02, 2014 04:15 AM
