How about this It is small and at 7.4 volts you have 80.88 oz of torque
http://www3.towerhobbies.com/cgi-bin...?&I=LXAEXY&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXDTB4&P=7 This is around 50 oz torque at 4.8 volts and 63 oz at 6vots. It sounds like a cool design show us some pics when it's done. |
As the steering link is on the suspension arm I can imagine the suspension travel has no impact on the steering angle. But the added weight on the suspension arms will increase the inertia of the suspension. And this will affect the ability to absorb bumps.
How about a compromise? Use one servo for each side, but still have these mounted on the chassis. That way you have low slop steering, with the option to change Ackerman "on the fly" with the ER9x mixers. |
Joined Jan 2013
wparsons, again, its been modeled, and again, you might be picturing something totally diffrent than what i have modeled. but yes.. again.. there is 0 change in angle regardless of steering posistion or suspension travel
that said.... solo ... im seriously considering moving the servos inbound. i have a design that will still eliminate MOST of the bump steer, while give less unsprung weight. Originally i didnt want the linkage "outside the box" (at least what im calling a box) for asthetic concerns. however this design DOES still call for 2 servos to be able to angle the linkage properly to prevent the bump steer. also, by mounting them inboard i can posistion them farther forward helping the weight distribution greatly. Im not sure without doing a little more work, but i think if i take this route i may even be able to get away with using stock (or aftermarket) steering blocks and not have to make my own. |
I would love to see models of it, anything I've drawn up shows that you would have a change in steering angle through suspension travel. The only way I can see it working is if you're mounting the servos vertically, which would create all kinds of clearance issues.
Instead of two inboard servos, why not a single servo with bellcranks or a steering rack? They're both well proven designs that work VERY well on high end race vehicles. |
I think the reasons are to try out if it works. And having 2 servos does allow for quick adjustment of the steering geometry without having to get the tools out. If you want to do speedruns, simply set some toe-in for better stability. On a curvy track, some toe-out for better cornering. You can adjust Ackerman by simply altering the mixes. The ER9x software is very versatile.
Whether it will give a big improvement in handling, remains to be seen, I agree. In a race car simplicity often pays off, and single servo steering will probably be more reliable. Still it makes interesting reading. |
Latest blog entry: Vintage Kyosho Buggies, why I love 'em...
Joined Jan 2013
ill post pictures when the project is done and the designs are all copy righted.
| Thread Tools | |
| For Sale Mantis/Axial XR10 4 way steer Crawler with Futaba (RTR) | rick62 | Cars - Trucks and Parts (FS/W) | 1 | Apr 22, 2013 09:58 PM |
| Discussion m5 poor steering | Nolines | Motorcycles | 9 | Jan 23, 2013 02:17 PM |
| Discussion Spyhawk vTx, independent battery | mig29n | DIY Electronics | 0 | Jan 10, 2013 09:04 PM |
| Discussion Spyhawk vTx, independent power | mig29n | Micro RTF | 0 | Jan 06, 2013 11:16 PM |
| Question Need advice on steering my piper cub | trimble95 | Fuel Plane Talk | 17 | Jan 03, 2013 08:23 PM |
