Old Oct 02, 2013, 08:13 AM
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
$99 19" LCD Monitor for FPV (12V)
I have been looking for a while for a good bright large monitor for my ground station case, after buying and returning different models I found the perfect one at Target.
They are currently at $99.99 on my local Target stores ELEMENT ELEFT195
19" LCD LED
720P
VGA, HDMI, COMPONENT, AV inputs
Works on 12V 2amps or less
Very bright compared to other monitors I have tested
Great Resolution
VERY SIMPLE TO TAKE APART and modify for custom cases if you want, its very light also.
BLUE SCREEN or BLACK SCREEN = You can turn off the blue screen on the Menu BUTTTT it will give you a Black screen instead. It will hold some static before going into black/blue screen but it wakes up very quickly once the signal is getting better........ In my case I use a DVR between the Receiver and Monitor and the DVR always keeps the monitor showing static.
Get them while you can, I know I will be buying a few more to keep them for future use.
Here are some pics
crd is offline Find More Posts by crd
Old Oct 05, 2013, 10:51 AM
Joined Jun 2013
Awesome heads up. I am walking out with mine now 2 left at my local target
panaceabeachbum is offline Find More Posts by panaceabeachbum
Old Oct 05, 2013, 08:18 PM
Joined Jun 2013
can you save me some leg work and post which pelican case you have pictured
Old Oct 06, 2013, 12:24 AM
Joined Jun 2013
well I am a little bummed, Mine is the same model, manufacture date one month later, but is 110V AC , the mainboard with all the inputs is also different.
Old Oct 06, 2013, 01:42 AM
2/3s way to fat, dumb & happy
United States, CO, Centennial
Joined Feb 2006
From the Element web page:
Display
Screen Size: 18.5inch
Aspect Ratio: 16:9
Panel Resolution: 1366 x R.G.B. x768
Brightness: 180-250 cd/m2
Contrast ratio: 1000:1
Maximum Color: 16.7 M
Response time: 6.5ms
So, per their own specs, it is not any brighter than the Vizio many of us have, and even looks a little on the dim side possibly (although I don't know why the range of Brightness values is there, other than to show a min/max spread maybe?). In comparison, the 19" Vizio is rated at a straight 250 cd/m2 but is obviously adjustable up to that level. Just an observation...
BD6
Big Duke Six is offline Find More Posts by Big Duke Six
Old Oct 06, 2013, 12:54 PM
Joined Jun 2013
Thanks, I am returning this one thisafternoon, and will pick up the vizio. I have one of the craig $49 ones from CVS currently but its pretty dim and pics not so great.
other than not bieng 12v ths monitor looks great
Old Oct 06, 2013, 03:21 PM
Joined Feb 2006
The Vizio does ok, but if it were up to me, it would be brighter. Some of the smaller monitors I've seen are up in the range of 400-450 and that sounds like it would be much better for daylight viewing. I have to have mine very well shaded to use in bright sun, and even then the light from behind me is a problem too. I've actually been contemplating making a black wing-like thing to put on my back to seal off the light from coming in behind me. A smaller, brighter monitor might be better than the Vizio in this regard. Before you take yours back, take it outside and see what you think. The Vizio won't be any better, brightness wise. It is DC though, and I do like the size of it. They may be hard to find these days - I'm not sure if they are still in production.
BD6
Old Oct 06, 2013, 04:04 PM
Joined Jun 2013
I think I am going to pick up a couple of diff 12v ones and compare side by side. It would be nice to find PIP
Old Oct 06, 2013, 04:17 PM
OpenTX University
Casey101's Avatar
United States, NJ
Joined Aug 2013
I'm curious if there is an adjustment for minimum input level for the composite video that goes to black/blue screen?
It maybe as simple as locating a resistor and changing its value to eliminate blue screen
Is there a way to adjust the video out level of your receiver to output 0.1v out instead of 0 (zero) volts. This may eliminate blue screen on almost any monitor if its threashold is any level above .1 volt.
Casey101 is offline Find More Posts by Casey101
Old Oct 06, 2013, 04:48 PM
Joined Jun 2013
I wonder if this is something that could be easily addressed with the Eagle Tree distribution block
Old Oct 06, 2013, 06:58 PM
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
Brightness: 180-250 cd/m2 Seems like a typo because its brighter than my vizio 24"
Test (0 min 7 sec)
Old Oct 06, 2013, 08:13 PM
Joined Jun 2013
sure looks good, to bad not all of them are 12v
Old Oct 06, 2013, 08:24 PM
OpenTX University
Casey101's Avatar
United States, NJ
Joined Aug 2013
What case are you using with it?
Old Oct 06, 2013, 08:29 PM
Joined Jun 2013
I believe its one of these
http://www.mcmelectronics.com/manufa...ATOOL/01000288
Old Oct 07, 2013, 09:51 AM
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
http://www.mcmelectronics.com/product/22-17785
Sold 19" lcd monitor price dropped snipeworm FPV Equipment (FS/W) 4 Oct 13, 2013 09:13 PM
New Product HobbyKing 7.0 Inch LCD Monitor for FPV 800x480 No Blue Screen Doodie FPV Talk 1 Mar 18, 2013 06:37 PM
Yippee! Maybe the best LCD for FPV:Diversity LCD Screen Receiver Monitor fpvmodels FPV Talk 4 Dec 20, 2012 03:27 PM
Sold 19" PIP 12v FPV LCD Basestation Display irun4fundotca FPV Equipment (FS/W) 3 Sep 17, 2012 12:59 AM
Discussion 19" LCD HD ready TV runs on 12v - 99 MrBen. FPV Talk 2 Jun 14, 2010 04:28 PM
