Old Feb 03, 2013, 01:17 AM
Non Eius A Stupri Fucus
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
PCM Taser F5J
Seems to be very little information (in english at least) about this glider. Or a thread...
Ive got a full carbon one on order, still havent nailed down a power system as am unsure as too what can be made to fit.
http://www.pcm.at/english/F5J/index.html
RTF weights are around the 500g mark. not bad for a 2m carbon model So its kinda like a 2m electric DLG.
Some googling dug up these -
http://www.aufwind-magazin.de/redakt...410/index.html
http://www.prop.at/testber/2010/taser.pdf
The video is better on mute...
PCM Taser carbon (4 min 2 sec)
Anyone got one?
jackosmeister is offline Find More Posts by jackosmeister
Old Feb 05, 2013, 10:42 PM
Auckland NZ
Joined Aug 2007
Found some stuff -
Manual http://www.hyperflight.co.uk/getfile...=TASER&code2=1
Glider version thread http://www.rcgroups.com/forums/showthread.php?t=1369209
German build thread ( very helpful ) http://www.rc-network.de/forum/showt...-Taser-von-PCM
French thread http://f3news.big-forum.net/t3690-taser-pcm
Old Feb 06, 2013, 05:33 AM
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
I kind of like it, but I'm wondering about a couple of things
I wonder if it needs four servos in the wing,, maybe I would tape them together and just use 1 servo per wing at first... see if it slows down good, and not tip stall.
I might tape the outboard aileron to the tip of the outboard wing, just to make sure.
I'm also wondering about the 2 piece wing... but since you won't be tip launching, it probably won't matter.
Kenny Sharp is online now Find More Posts by Kenny Sharp
Old Feb 06, 2013, 05:18 PM
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
No taping is required, as our Taser page says:
The flaps and ailerons are supplied joined, in one piece, so the model can be setup to use two servos on flaperons, or four servos controlling the flaps and ailerons separately.
Also the ailerons positions still have a layer of glass present, which would be left in place in a flaperon model. I think the Taser is a superb electric glider, it is massively undervalued in the English speaking world.
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Feb 06, 2013, 05:27 PM
turn, turn, turn.
Joined Oct 2005
Thanks for the info, I wonder if anyone is importing them to the USA?
Old Feb 06, 2013, 05:35 PM
HyperFlight Support
Joined Feb 2001
I don't know, but I can supply them. :-)
Neil.
Old Feb 06, 2013, 06:02 PM
Auckland NZ
Joined Aug 2007
Yup a few places do.
Mines coming from soaringcomposites/apachobby in Singapore, but -
http://www.soaringusa.com/Taser-F5J.html (no listing for the carbon version
http://www.soaringusa.com/Taser-Unpl...M-TSR-791.html
I thought skipmiller had a listing for it too, but cant find it now.
Im considering building it as a 2 servo wing, havent decided yet. Even the "heavy" full carbon builds seem to be ~550g, not exactly a heavy wingloading for a 2m model. Still, getting under 500g would be cool.
What do you think Neil?
Im still playing with ideas for a power plant, the recommended hyperion setup with a GS series motor instead is probably likely though. Is the G/GS series "glider nose" motor needed with the 22 series diameter? If a 28mm OD motor fits there may be some weight to save there?
Im really not a DLG guy, F5B and hotliners/pylon racers are more my thing so im a bit of a n00b when it comes to this sort of build Unfortunatly flying F5B models in the local park isnt very practical/politcally correct/wise, so I need something nice and quiet to look for thermals with
Old Feb 06, 2013, 06:22 PM
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
Looks very nice.
jaizon is offline Find More Posts by jaizon
Old Feb 06, 2013, 06:36 PM
turn, turn, turn.
Joined Oct 2005
Originally Posted by jaizon View Post
Looks very nice.
It sure does, doesn't it?
I'm really liking the full carbon version.
Old Feb 06, 2013, 06:45 PM
jaizon's Avatar
USA, NH
Joined Mar 2008
Neil.
Do you have someone who will build one for me?
Old Feb 06, 2013, 07:11 PM
Auckland NZ
Joined Aug 2007
Im curious if It needs a 60gram motor to balance or not.
Im thinking a ZS2209-30 on a 10-11x6 with a a 3S 500 is going to be the power plant. Should save some weight on the stock setup (30-40g) and give me a few more watts
Old Feb 06, 2013, 07:41 PM
jaizon's Avatar
USA, NH
Joined Mar 2008
Yeah, me too. And I don't even like v-tails. And I've got two new planes for this ALES season already. And I don't like 2m either. But still...it does kinda grab ya, don't it?
Old Feb 07, 2013, 03:32 AM
turn, turn, turn.
Joined Oct 2005
Yeah, I think it could be excellent for early morning light air.
I think the original Apogee had a V-tail, but had to go to a sub fin T-tail for tip launching.
Old Feb 11, 2013, 04:22 PM
Auckland NZ
Joined Aug 2007
Is anyone (Neil?) able to confim I can get a standard 22 series (28mm OD) Scorperion in the nose, and have room for the motor wires?
Im going to need a 32/3mm spinner if, the only thing I can find are the offset ones hyperflight .co.uk list, so my spinner ( and probably servos) are going to have to be shipped off to the colonies
Would like to start ordering all the bits, but until I know what motor fits im a little stuck
Old Feb 11, 2013, 05:04 PM
HyperFlight Support
Joined Feb 2001
Scratch the previous answer. I thought we were taking about the Scorpion 2.3 e-glider.
I will check the Taser fuselage tomorrow.
Neil.
Sold Kontronik Geared - F5J LMR/ALES motor Kholder116 Aircraft - Electric - Power Systems (FS/W) 3 Mar 03, 2014 08:11 PM
Discussion Competitive F5J models davidleitch Electric Competition Soaring-F5J/ALES/e-Soaring 52 May 02, 2013 10:22 PM
Build Log Supra f5j paxjohn Electric Sailplanes 1 Jan 15, 2013 08:05 AM
Discussion Taser from PCM Daniel Gut Hand Launch 40 Nov 07, 2012 02:38 AM
home built mf-480 (TASER) buiding pics ESB Electric Ducted Fan Jet Talk 22 Sep 29, 2003 05:44 PM
