Old Jul 22, 2014, 07:43 PM
HELModels's Avatar
Joined Aug 2003
Originally Posted by Lt1ssteve View Post
Yeah they are completely square. I've never balanced motors or props so I'm thinking it might be a grumpy motor issue. One day I'll balance some stuff and see if that works. It's just not a priority since I know I'll crash it, break props and motors and have to do the whole tedious balancing thing all over again.
I had issues with vibrations after repairing my bent up airframe. I straightened it and reinforced it which made it stiffer and transmitted vibrations much better. That was a minor surprise when the Flip was very irratic.
I knew I better try and balance the props and I don't have a balancer. What I did was take some electrical tape and cut up a small piece and put it on one prop. I picked that prop because I could see it vibrating. The first piece didn't improve it so I added another. That made it worse. I repeated the whole process but picked the other blade on the same prop. Baaaaaammm! That nailed it and vibrations went away enough that it flew smooth again.
The point is you can balance by trial and error with just some electrical tape.
HELModels is online now Find More Posts by HELModels
Old Jul 22, 2014, 10:19 PM
Joined May 2014
I have a good prop balancer so that's not an issue... The issue is I'm lazy and crash a lot.
Lt1ssteve is online now Find More Posts by Lt1ssteve
Old Jul 22, 2014, 10:21 PM
Joined May 2014
Originally Posted by waltr View Post
Ok, well then just go fly it. A very slight yaw is not that big a deal unless you just want to hover in one place and point in the same direction. If you fly around you will be inputting yaw commands to turn.
I just got back in from flying my newest acrobatic quad. Didn't break any props tonight but they are pretty beat up right now. Probably need to replace a couple tomorrow night.
Yeah I'll just beat it up for a little while longer... My naze32 just showed up too so I'm sure I'll end up playing with that too so I doubt I'll pin down the yaw issues.
Old Yesterday, 01:08 AM
Slovenia
Joined Nov 2011
Hey all
I'm now flying with kk2.1.5 and looking for new FC for my new quad and I got some question about different versions of filp 1.5
Is this correct:
Flip 1.5 - basic FC
"Pimp Your Flip 1.5" - Baro & Mag add-on board - add on for flip 1.5
Flip 2.0 - flip 1.5 with added baro and mag sensor
Flip 2.5 - better sensors on flip 2.0
The Flip Pro MWC Flight contoller - ?????
The Flip32 (V2.3_Rev6.) - just like naze32
The Flip32 + - ?????
ventilator is online now Find More Posts by ventilator
Old Yesterday, 05:04 AM
Firmware Fiend
The Quasar's Avatar
United States, CA, San Diego
Joined Nov 2013
Originally Posted by ventilator View Post
Hey all
Is this correct:
Flip 1.5 - basic FC
Flip32 is like the Acro Naze32.
Flip32+ is like the Naze32.
The Quasar is online now Find More Posts by The Quasar
Latest blog entry: 3D Printing with the ROBO 3D R1
Old Yesterday, 08:32 AM
United States, PA, Doylestown
Joined Jan 2014
Yep.
And the Flip Pro uses the 32U4 processor which uses 32 bits internally but has fairly small Program space. Uses the same 6050 sensor as many of the Flip boards.
When comparing FC boards list the following:
Processor -
#bits and program memory size determines what additional features can be added in MW code
Gyro sensor
Accel sensor
(these 3 are the basics that every FC has)
Additional sensor like Baro & Magnetometer.
# of serial ports (needed if adding serial gps, Bluetooth, or other serial devices)
I have run:
-Flip 1.5 in simple copters with Acro and Angle modes. Works well
-Flip Pro in an Acro only quad with KISS ESCs. This one is a hot rod.
-Flip32 in mini-H with FPV. Lots of easy to adjust setting using CLI, also fast processing that can run much shorter Loop Times.
waltr is online now Find More Posts by waltr
Old Yesterday, 09:59 AM
Slovenia
Joined Nov 2011
One more question. Can you add bluetooth so you can change settings with phone (android)
Old Yesterday, 10:16 AM
Joined May 2009
Any board that has a ftdi port can be hooked up to a bluetooth module.
Arakon is online now Find More Posts by Arakon
Old Yesterday, 11:56 AM
Joined Jan 2014
Not really an FTDI port. FTDI is a maker of USB chips so incorrect terminology.
However, all the Flip boards do have the Atmega's Serial port pinned out to thru-hole pads that can connect to a BlueTooth module. These will be labeled TX and RX. This are also used to connect the Flip board to and OSD for FPV.
Old Yesterday, 12:14 PM
Indianapolis, IN
Joined Aug 2010
I have the Bluetooth on my Tri-Copter with the Flip 1.5. Have the app on my Nexus 7HD. After I load the sketch on the flip I do the rest on my tab. Setup your radio & etc
ferebeed is offline Find More Posts by ferebeed
Old Yesterday, 12:39 PM
Joined May 2009
I'm aware of that, however many of the manufacturers actually label the port FTDI.
Old Yesterday, 03:20 PM
Multiwii noob
pacoswava's Avatar
United States, ID, Idaho Falls
Joined Jul 2012
Flip EZ
Anybody know if the three pins on the Flip EZ above the rx pinouts is for a Spektrum satellite plug. I see it says S1 next to it. But doesn't say anything about it on the website.
pacoswava is online now Find More Posts by pacoswava
