Old Jul 21, 2014, 01:52 PM
mikecopey's Avatar
United States, FL, Oviedo
Joined Dec 2008
[QUOTE=efflux RC;28650631]Here's mine with a Wemotec Minifan rotor, and a 3200kv motor, on 6s. (ICE 100 ESC) It also flies on 5s,
The The HET 1W-40 (3300kv) would be great (and a bit faster) on 6s.
The Jet would require air frame mods (as Apex Mentioned for 6s). Mine also has a thrust tube in it. 5s would be the easier route with no structural reinforcements.
Hi EffluxRC,
24 V(6s) x 3300kv = 80000 rpm.....Is that not exceeding fan limit ?
I bought a 12 blade pro balanced fan with 1W-40 from Efflux, planning to max out the fan speed at 53000 rpm using a 4 cell.
Did we crunch the numbers wrong ?
Here's the specs --
Max RPM : 52000
Max recommended power : 1800W
Motors required : 28mm inrunner or Outrunner (mfgr recommends 2200- 3300Kv )
Thanks !
mikecopey is offline Find More Posts by mikecopey
Old Jul 21, 2014, 03:32 PM
New Zealand, Waikato, Hamilton
Joined Nov 2011
Hi all,
I am considering this Habu as my first edf, I have flown a F27q stryker on 6S and a eflite scimitar, you guys think I will find this jet a good one to start with? Also been looking at the Tamjets Habu 2 struts for the eflite retracts, they look nice but just wondering if anyone can tell me do they drop straight in without mods to the wheel wells?
Cheers,
Matt
1stfoot is offline Find More Posts by 1stfoot
Old Jul 21, 2014, 04:39 PM
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Hi Mike,
It looks like you're running a 12 blade fan, and Efflux was using the 5-blade Wemo mini fan. Two very different units. I don't know the specs for the Wemo, but a general rule is that high blade count fans max out at much lower rpm than low blade count (4-6blade) fans. If your 4s lipos hold 16v at max throttle, and there isn't much load on the motor, you'll see rpms just north of 50,000, which seems close to your goal. Looks like a winner to me .
Best,
Josh
[QUOTE=mikecopey;28971431]
Hi EffluxRC,
Here's the specs --
Max RPM : 52000
Thanks !
jgalexander is offline Find More Posts by jgalexander
Old Jul 21, 2014, 07:18 PM
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
Originally Posted by 1stfoot View Post
Hi all,
Cheers,
Matt
It's a great edf to start with. You'll have to dremel the LG wells a little bit for Tams springs to clear when retracted. Also some minor modification/drilling to get Tams struts onto the Eflite retracts. IMO, I would use the fixed gear for your first few flights, just to get a feel for landing. Then move on to the retracts and then Tams struts. You'll save a few bucks his way if you have any carrier landings, lol.
Have fun.
supercollider is online now Find More Posts by supercollider
Sold 2 PNP Parkzone Habu's - willing to ship jgalexander Aircraft - Electric - Jets (FS/W) 16 Mar 29, 2012 09:44 PM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Airplanes (FS/W) 3 Nov 15, 2011 12:36 AM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Jets (FS/W) 0 Nov 13, 2011 02:40 PM
Sold Brand New Parkzone Habu EDF Jet BNF zsultan Aircraft - Electric - Airplanes (FS/W) 0 Nov 07, 2011 01:05 PM
Sold Brand New Parkzone Habu EDF Jet BNF. zsultan Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2011 01:04 PM
