Old May 21, 2015, 08:55 AM
Majortomski is offline
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
OK friends why do we free wheel our propellers?
First off please be aware that I am an aero engineer and a multi engine pilot. From that I understand that that we 'feather' propellers on multi engine airplanes to minimize the huge drag penalty caused by the wind milling propeller on a dead engine. I've even been told by full scale instructors if you have an engine failure in a single engine plane, if you have enough altitude and time, try to slow the plane till the prop stops wind milling so there wil be less drag.
That being said, why do we work so hard in free flight to MAKE the prop windmill when the rubber winds run out?
Seems it would be more efficient to let the prop eventually stop by spinning the rubber backwards till the air load and the turns balance out.
Then again a 'perfect' rubber flight is where the rubber wind run out as the plane touches down. So it should never have a windmilling prop to begin with.
Your thoughts please.
Majortomski is offline Find More Posts by Majortomski
Old May 21, 2015, 09:48 AM
bogbeagle is offline
Find More Posts by bogbeagle
Joined Mar 2007
"if you have an engine failure in a single engine plane, if you have enough altitude and time, try to slow the plane till the prop stops wind milling so there will be less drag."
I've done this ... deliberately ... on a number of occasions.
It works. The drag reduction is very noticeable, as evidenced by the reduced rate of descent. You may have to bring back the speed to the stall, to get the prop to stop turning, though.
bogbeagle is offline Find More Posts by bogbeagle
Old May 21, 2015, 10:21 AM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
This was covered in one of the old Zaic yearbooks. Frank Zaic was a keen fan of higher levels of aerodynamics in our model building.
The Reader's Digest version is that for low pitch:diameter ratios found on engine props and some specialty low pitch rubber model props there is less drag to be had by stopping the prop. Better the stick in the breeze than an autogyro like spinning disc. But for higher pitch:diameter ratios above somewhere around 1:1 there's less drag with a free wheeling prop. And pretty well all duration style rubber models for sport or competition have a high ratio value. So they are better off with a freewheeling prop.
Of course the optimum solution to the issue was found in the folding props used originally in the late 1930's and on from there in so many serious duration categories.
BMatthews is online now Find More Posts by BMatthews
Old May 21, 2015, 10:25 AM
GeorgeG97322 is offline
Find More Posts by GeorgeG97322
Power Upward
GeorgeG97322's Avatar
United States, OR, Albany
Joined Jun 2007
There are many competition rubber powered free flight models that will thermal very high and without the free wheeling prop would be much harder to achieve their best performance. Several events like P-30 have a limited amount of rubber available to power the model and after only a minute or so of time the winds are expended and the prop will free wheel until the model either comes back to earth gently under glide or quickly under some form of dethermalization.
George
GeorgeG97322 is offline Find More Posts by GeorgeG97322
Old May 21, 2015, 04:52 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
I know that this came up many years ago for fixed props on RC electric old timers and sailplanes. The props on those tend to have lower pitch:diameter ratios than rubber models by quite a lot. The electric stuff tending to use from 0.6 to 1.0. It was well recognized at the time that a brake function to stop the prop from freewheeling was a big help to lowering the drag.
But competition rubber models tend to use higher ratios of well over 1.0. Typically the props tend to be from 1.3 to 1.6. And that's where free wheeling works to lower the drag over a stopped prop.
Old May 21, 2015, 05:16 PM
Power Upward
Joined Jun 2007
See, this place has all the answers...
Bruce,
You going to be able to get down this way this year?
George
Old May 21, 2015, 09:35 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
For sure at least the August and September meets. Might even come down for the later Fall Annual as well if the weather looks like it'll cooperate.
Old May 22, 2015, 12:19 AM
Joined Mar 2007
With respect to full-sized ... the turning prop does not "free-wheel"... it turns over the engine, which requires quite a bit of effort.
Old May 22, 2015, 03:42 AM
danny mz is online now
Find More Posts by danny mz
Diesel Danny
danny mz's Avatar
Australia, VIC, Bellbridge
Joined Nov 2013
I found that a model with a 'mandatory' free-wheeling prop (such as a P-30) is slightly more resistant to gusts than a pure folding prop on other classes of model.
Maybe this is because a folding prop moves the CG rearwards, but I suspect that the plastic gyroscope spinning around at the front of the model helps to stabilise things a bit.
Agree that the drag of a spinning prop may be greater than a fixed one - all that energy to spin it has to come from somewhere!
Anyway - that's my 2 worth.
* Danny M *
danny mz is online now Find More Posts by danny mz
Old May 22, 2015, 08:44 AM
Joined Aug 2000
With respect, please note I used the term 'windmill' the long accepted term for what you describe.
http://www.datwiki.net/page.php?id=8...&searching=yes
Old May 22, 2015, 10:10 AM
Joined Mar 2007
I'm not having a dig at anyone. ... just saying that the full-sized situation is different from that of the rubber-powered model, owing to the lack of the freewheel.
I've also noticed that my RC models often have a better glide when dead-stick, than they do if the engine is idling.
Old May 22, 2015, 11:17 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Very much so. You can hear the engine being sped up to well over the idle speed. And that takes energy to do. At that point the prop is acting somewhat like an autogyro rotor to develop far more "lift" which would be noticed in this case as drag than a fixed prop.
Old May 23, 2015, 07:16 PM
baldguy is online now
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
I do it because I was told to.
baldguy is online now Find More Posts by baldguy
Old May 23, 2015, 08:30 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Your mother flew free flight rubber models too!?!?!?
.... nice.....
Old May 23, 2015, 11:22 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Another explanation for freewheeling: FAC rules don't allow feathering or folding props, though obviously they're authentic for the time period FAC is supposed to be nostalgic for (1930's, mostly). Same deal about gears. Lots of scale models would be feasible with gears that aren't now. Unless you're putting a big ugly prop on the nose where it doesn't always belong.
lincoln is offline Find More Posts by lincoln
Discussion Why Do We Sell Our Stuff PhoenixFlyer Classic Pattern Flying 13 May 09, 2015 12:45 PM
Discussion Where do we let everyone know about our HobbyWoods Site? dezmond Hobby Stores 0 Jan 05, 2015 12:37 PM
Question Why do we need power supplies, and how do they work?? DrewC Batteries and Chargers 10 Nov 04, 2014 11:23 AM
Discussion This is why we love our toys! Baddmove Car Talk 9 Feb 26, 2014 05:03 PM
Discussion Hoping all our friends in England are doing OK LcJ Life, The Universe, and Politics 13 Feb 12, 2014 10:23 PM
