Old Apr 27, 2015, 09:37 PM
boaterguy is online now
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Eliminating flex on hotwire cut wings?
I have a pylon racer style plane with a very thin airfoil (don't remember the exact one), it has a 3/16" fiberglass spar from a dollar store kite but the wings still flex like crazy, it's flapping around all over the place. Are there any strategies for reinforcing wings? It seems like it should be stronger than it is.
boaterguy is online now Find More Posts by boaterguy
Old Apr 27, 2015, 10:02 PM
pmullen503 is offline
Find More Posts by pmullen503
United States, WI, Fond du Lac
Joined Sep 2008
Carbon fiber is much stiffer than glass. I had some of those kite fiberglass rods and they are pretty much useless.
pmullen503 is offline Find More Posts by pmullen503
Old Apr 27, 2015, 11:30 PM
rhokita is offline
Find More Posts by rhokita
gardena, ca
Joined Feb 2003
As an experiment you can try stretch pack taping over the wing in a cross hatch pattern at a 45 degree angle. I think you glass a wing this way, they call it laying out the cloth on bias. I've done it both ways and the bias or cross hatch is by far superior in stiffness.
rhokita is offline Find More Posts by rhokita
Old Apr 28, 2015, 01:46 AM
DaveK is offline
Find More Posts by DaveK
United States, OK, Edmond
Joined Jun 2004
Rods - regardless of whether it's carbon or fiberglass are going to flex. They are tolerable with depron wings because the wing loadings are generally light enough and wings are short enough in span so the degree of bending is generally minimal.
A tube rather than a rod will have better resistance to bending, however depending on the weight and forces encountered a more traditional type of spar might be better.
Alternatively, a relatively thin piece of 3/16 carbon strip embedded vertically would probably offer the best balance of weight vs bending resistance overall and would be relatively easy to install, slice through the wing and epoxy it in then fill in any low spots.
DaveK is offline Find More Posts by DaveK
Old Apr 28, 2015, 07:00 AM
flypaper 2 is online now
Find More Posts by flypaper 2
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
A few of my planes are made rigid by slitting both upper and lower surfaces along the thickest part of the wing about 1/8 in. deep. Insert 1/16 in. or 1.5 carbon rod in the slit. It should be deep enough to almost disappear. If it's EPP foam flood with thin CA along the slit so it soaks in to lock the wire. Thin foamsafe CA if it's regular foam. Makes for a very rigid, light wing.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Apr 28, 2015, 08:27 AM
steve_o73 is offline
Find More Posts by steve_o73
Canada, ON, Quinte West
Joined Mar 2014
Made the speedy, a small pylon type foamy from a member here on RCGroups. The wing is dollar tree foam with carbon tube spar covered in packing tape. Has lots of flex with a not to fast power setup. Making a new one now, got the wing almost done. 6mm depron carbon tube to within one inch from tips. Fiberglass weave tape for drywall 6inch width, applied to both sides trimmed around the edges then sprayed with a heavy duty spray adhesive. Smooth out the adhesive with a drywall knife. Much better but still need to tape to make smooth, which will add a bit more stiffness.
steve_o73 is offline Find More Posts by steve_o73
Old Apr 28, 2015, 09:19 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Hey Steve! Monocote iron on low heat will make the glue on the tape stick better and help shrink it a bit too.
Gord.
Old Apr 28, 2015, 01:39 PM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Depends on the sort of stiffness you want.
If you're talking about bending, then a strip of fiber packing tape underneath and a rod or strip of just about anthing that doesn't compress on top works really well. I used 1/8"x3/8" basswood as the top cap on the foamystang. The plastic packing straps also work well and are near free- carbon flat works, too.
If you're talking about twist or flutter, then the "on the bias" crosshatch (or "disser") pattern works best. Fiber reinforced tape is better than regular tape.
rdeis is offline Find More Posts by rdeis
Old Apr 28, 2015, 04:05 PM
Pukin_Dog is online now
Find More Posts by Pukin_Dog
┼tvidaberg, Sweden
Joined Jul 2008
Originally Posted by DaveK View Post
A tube rather than a rod will have better resistance to bending...
That is not entirely true. Since the rod has more material it is more resistant to bending. But the effectiveness in the material decreases the closer to the core it is. The tube is of course lighter so it is a better choice though.
Pukin_Dog is online now Find More Posts by Pukin_Dog
Old Apr 28, 2015, 04:26 PM
Joined Mar 2014
A hollow shaft is always stronger than a solid shaft. Large heavy duty drive shafts are all hollow. This may only apply to twisting resistance and not bending, not sure.
Thanks for the tip flypaper, will try.
Old Apr 28, 2015, 05:34 PM
┼tvidaberg, Sweden
Joined Jul 2008
It applies to both actually and you are wrong Sir.
Think of a tube Outer diameter of 6 mm and inner 4 mm.
Then place another tube in that O diam. 4 mm and I diam. 2 mm, and in the center a rod diam. 2 mm. If it is that a hollow shaft always is stronger as you say, then the inner parts would apply force in the same direction as the force that is twisting or bending the whole structure! This is against everything.
And if we think that the inner parts have no effect at all, then if you remove the inner rod for example it would bend like an overcooked spaghetti since it doesn't have any resistance at all against any force! And that is not the case.
There is other reasons for drive shafts to be hollow like inertia and weight.
Old Apr 28, 2015, 11:41 PM
Loco1 is offline
Find More Posts by Loco1
Callington South Australia
Joined Mar 2006
A thin spar top and bottom of the wing will give you a much stiffer wing than a single rod or tube, they are called cap spars this is how most full size plane wings are put together.
Loco1 is offline Find More Posts by Loco1
Old Apr 29, 2015, 02:12 AM
djacob7 is offline
Find More Posts by djacob7
Knife cuts foam like its steel
United States, CA, Fremont
Joined Jan 2009
Cap spars work very well for bending, but are they good for torsion too? Seems to me that a hollow tube would do both jobs for bending and twist.
djacob7 is offline Find More Posts by djacob7
Old Apr 29, 2015, 05:08 AM
┼tvidaberg, Sweden
Joined Jul 2008
Yes, I agree with "Loco1", a spar on top and on the bottom are best for a wing. They don't handle torsion well though.
Old Apr 29, 2015, 06:09 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I think this one comes down to weigh. The thin spars are much lighter than a tube spar. Foam itself is relatively rigid as compares to built up structure.
Gord.
Discussion Optical distortion? Wing flex? What happened on those pics? markimtv Hand Launch 29 Jan 25, 2015 02:47 PM
Discussion 4 piece hotwire cut wing gazza2003au Foamies (Scratchbuilt) 18 Feb 21, 2012 10:39 PM
Discussion first hotwire cut wing could it possably fly? (pics) gazza2003au Flying Wings 12 Jan 14, 2008 04:31 AM
Discussion Looking for someone to hotwire cut some wings in san diego jaysbay Flying Wings 6 Mar 07, 2007 06:45 PM
My new EPP NON-hotwire cut wing! airsnyper Foamies (Kits) 7 Mar 07, 2005 10:21 PM
