Old Feb 09, 2015, 01:46 PM
lost in the addiction of flyin
furballll's Avatar
Canada, BC, Kelowna
Joined Dec 2009
Hey higher C rating the better, you will have no issues.
furballll is offline Find More Posts by furballll
Old Feb 09, 2015, 02:01 PM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Buy as much "C" rating you can afford is one school of thought but to buy a 60C 5000 mah 6S pack for this plane is overkill. 30C is sufficient plus it is lighter and less expensive.
Prof100 is offline Find More Posts by Prof100
Old Feb 09, 2015, 02:25 PM
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Originally Posted by mkpatrick View Post
Is there any problems with flying this plane, stock with a high C rated pack? Such as a 60C or 70C?
I'm trying to find a 6S pack that I can use in two very different planes. One is an EDF and the other this plane. Just trying to save money and time with charging.
I don't plan to attempt any 3D stuff with the CZC. I plan to just fly it around as a cub and also do some towing service for some glider guys. So I won't be pushing it hard like hovering and such things.
To answer your question..
no, there is no issue using better high C rated packs
your voltage sag will be much less during flight and have less ripple current through the electronics
the motor will only pull what it needs to fly
brushless55 is offline Find More Posts by brushless55
Old Feb 09, 2015, 03:01 PM
United States, OR, The Dalles
Joined Apr 2011
I think the packs I run are 65c 5000. Had the packs for a heli, and wanting a plane that would use the same packs is why I got the carbon cub.
No problems at all.
JeffinTD is offline Find More Posts by JeffinTD
Old Feb 09, 2015, 04:21 PM
mkpatrick
Joined Mar 2011
Very cool thanks for the info!
mkpatrick is online now Find More Posts by mkpatrick
Old Feb 10, 2015, 01:17 PM
Dadawada's Avatar
United States, NC, Cary
Joined May 2014
Originally Posted by Prof100 View Post
Below are the key specs for the 400 kv motor. 400 KV can be fine, just prop up to provide you the thrust and speed. I run the 470 KV version.
EFLM4060A
Kv: 400 (rpms per volt)
Io: 2.7A @ 10V (no load current)
Ri: .06 ohms (resistance)
Continuous Current: 55A*
Max Burst Current: 65A*
Watts: up to 1700
Cells: 16-24 Ni-MH/Ni-Cd or 5-7S Li-Po
Recommended Props: 14x8 to 16x10
Brushless ESC: 80-Amp (EFLA1080B)
* Maximum Operating Temperature: 220 degrees Fahrenheit
* Adequate cooling is required for all motor operation at maximum current levels.
* Maximum Burst Current duration is 30 seconds. Adequate time between maximum burst intervals is required.
A 16-8 Xoar appears to be the ticket from my first couple flights.
Dadawada is online now Find More Posts by Dadawada
Old Feb 12, 2015, 11:39 AM
Prof100's Avatar
Joined Jul 2007
Well that sounds like a winner. It all depends on how you want to fly the plane. A 17 x 6 would give you a ton of thrust and that extra inch of prop provides more airflow over the control surfaces.
If you like it as is, congratulate yourself.
Bill
Old Feb 12, 2015, 08:10 PM
Dadawada's Avatar
Joined May 2014
Bill
If I can find a 17-6 in a good quality prop I'm going to give it a try.
Old Feb 12, 2015, 09:08 PM
NMdesertracer's Avatar
United States, NM, Alamogordo
Joined Nov 2007
Big blue took a nasty spill last sunday. Czc been flying like a champ for quite some time. Took off in a sudden crosswind. Flipped her over .dont know if i want get czc number 3.
NMdesertracer is offline Find More Posts by NMdesertracer
Old Feb 12, 2015, 09:55 PM
Canada, AB, La Glace
Joined Nov 2014
good thing I wasn't airborne
The weather warmed up so Ithought I would charge a battery and taxi around in my yard, first on wheels then tried my skis. My prop decided to fly on it's own leaving my CZC sitting there. guess I didn't torque it enough. or maybe it seemed to me the adapter step was bottoming so not putting enough clamp. I bought the Eflite aluminum spinner and adapter using the stock prop. I reamed the prop a little deeper so I think it is good now. Taxied around on skis after that , all seemed balanced but I need to tweek my homemade articulated landing gear , would over extend when I hit deeper snow or rough patch. have to come up with a better way of limiting travel. If I get it working I,ll post pics but or now I need to do some more designing. Still haven,t maidened it as every time it gets relatively warm it's windy. Chinnook we call it. Flying it on Pheonix , if it flys that easy IRL I'll be able to handle it no prob. (famous last words)
nof55 is offline Find More Posts by nof55
New Product E-Flite Carbon-Z Cub ChuckTseeker Scale ARF/RTF 15676 Today 07:23 AM
Help! Painting a super cub (Z foam) BiddySlayer Foamies (Kits) 4 Apr 06, 2014 08:38 AM
Discussion Eflite Carbon Z Cub shadow102 Atlanta Area RC 32 Nov 12, 2013 04:18 PM
New Product E-Flite Carbon Z Cub....... ChuckTseeker Electric Plane Talk 0 Sep 05, 2013 06:13 AM
Sold E-flite Yak 54 C-Z BNF Basic New Airframe $250 shipped $220 local pick up rblos1123 Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2013 05:33 AM
