Old Aug 19, 2014, 05:25 AM
Kavil194's Avatar
Türkiye, Eskişehir
Joined Apr 2011
Originally Posted by Isoprop View Post
The Mobius requires 1A current to be on the safe side. Remember the current draw is not constant and may require well over 550mA for a fraction of a second. During this short time the voltage will drop if the power-supply can't supply enough current. The charger IC on the mainboard will stop charging the battery for this brief interval but will charge again as soon as the power-supply reaches 5V again. This sequence is so fast that it will destroy your battery, and possibly your camera, in no time.
In summary, the BEC must be able to supply 1A under power. 550mA is not enough.
considering i am using this ESC http://hobbyking.com/hobbyking/store...dProduct=32475
it should be enough to power 4 12gram servo 1 180degree pan servo and receiver itself. it can probably supply 1 A current for the cam. however it listed as 5,5v. this can be a problem as you guys said.. what is margin of this mobius? probably i should hook up multimeter and test the voltage all servos connected and not.
Kavil194 is online now Find More Posts by Kavil194
Discussion FPV'ing successfully using tricopter/tcopters - tell us how you did it? shauntot FPV Talk 7 Apr 24, 2013 02:55 PM
Discussion Question about using computer monitors for FPV Koo FPV Talk 2 Feb 13, 2013 01:13 AM
Discussion OT, for those still on the fence about GoPro cams for your FPV needs. bgnome Dock Talk 9 Sep 19, 2012 12:59 PM
Discussion FPV cam your daughter would approve: Barbie Cam Steph280 FPV Talk 14 Aug 12, 2010 10:09 PM
Discussion Building Clear Canopy's for your FPV cams... IamLegend FPV Talk 2 Nov 16, 2007 02:50 PM
