Old Feb 17, 2015, 05:12 PM
ITTD you're Clear for Takeoff!
IntheTubeDeep's Avatar
United States, CA, San Diego
Joined Jan 2011
Looks solid! well done cnc lets see a pic of it in the fusi
Originally Posted by cnchelicopter View Post
The long journey to have removable wings. Also notice that I created a separate servo box for the slat. I also created the removable antenna using a nut. Also cut a slot for the elevator servo wires. The landing gear will come from SU-35. Thinking of cutting the cheater slits intake like the real thing...
IntheTubeDeep is online now Find More Posts by IntheTubeDeep
Old Feb 17, 2015, 05:19 PM
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Do you have a pic of the fuse where it mounts? What keeps the wing from sliding off? Does the wing cf rods go through the intake? Thanks.
DamonH is online now Find More Posts by DamonH
Old Feb 18, 2015, 12:26 AM
United States, CA, Garden Grove
Joined Sep 2011
havnt built the joint connection yet...will post when am done
cnchelicopter is online now Find More Posts by cnchelicopter
Old Feb 23, 2015, 09:58 AM
Joined Jan 2011
How 'bout now?
Old Feb 23, 2015, 10:37 AM
Joined Sep 2011
Since u insist...plus some other mod. Look simple but took me alot of simulation and external testing before I decided on this design because it also affect landing gear monut. The mount is 80% done..just some minor work but the wing is solidly mounted. Added weight is 100 gram
Old Feb 23, 2015, 07:16 PM
90mm F-16
Tartago's Avatar
Joined Apr 2006
Maybe you can use this joining method from the HSD J-10. A lot of wiring will be avoided.
Tartago is offline Find More Posts by Tartago
Old Feb 23, 2015, 07:30 PM
DamonH's Avatar
Joined Oct 2011
So does the carbon wing spars go into the wood block?
Old Feb 23, 2015, 07:41 PM
Joined Sep 2011
I have the J10...a crashed one...so I know how and have all the spart parts to make it, but the wimg is very thin on the Mig...so I will have to fabricate a connector for it and I might not have the skill to do it. ..unless I get a 3D printer
Old Feb 23, 2015, 07:44 PM
90mm F-16
Tartago's Avatar
Joined Apr 2006
There is a good exc... I say, need for a 3D printer.
Old Feb 23, 2015, 07:53 PM
Joined Sep 2011
Yep... the hardest part is to have the carbon rod straight into the wing and in the middle bc the wing is very thin. Each wing has 3 carbon rods....2rounds one that protrude out of the wing and a flat one that implanted into the wing and run all the way near the tip. Collars will stop the wing from sliding out... My technique require less surgery than Madison techniques. I am not that skilled like Madison to do all that surgeries . My extra SU35 LG will be used...they are more generic and easy to replace. I have beefed up my SU35 LG and they are very sturdy and strong at the same time they are very easy mod to do.
Discussion Flyfly mig 29 OVT ak MIG 35 amigob Electric Ducted Fan Jet Talk 11 Oct 28, 2010 01:22 PM
Sold HET-RC Mig 29 Twin Fans Grey 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Dec 07, 2009 11:15 PM
For Sale Mig-29 twin fan (including 2 X Het 6904mm fans 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Jun 17, 2009 05:58 PM
Discussion new mig-29 twin fans to be out soon gazza2003au Foamy EDFs 11 Feb 24, 2009 06:08 PM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 01:32 PM
