Old Apr 07, 2015, 08:24 PM
Genivos is online now
Find More Posts by Genivos
Genivos's Avatar
Netherlands, UT, Amersfoort
Joined Oct 2013
Originally Posted by hskb View Post
Incorrect information on Flip XL arms ??? DOES NOT FIX 13" prop.
I ordered a bunch of 13x8 Graupner eProps for my other quad, and were thinking of using them on the FLIP XL arm as well. After getting the XL arms, I found out that the props on the front XL arm overlap with the back XL arm for 1 Inch.
Do i miss something here?
Are you sure you placed them right? I have XL arms as well and can place 13" without a problem.
It does depend how you install them.
Genivos is online now Find More Posts by Genivos
Old Apr 07, 2015, 08:26 PM
Genivos's Avatar
Joined Oct 2013
Originally Posted by Beachbreak View Post
Also, I was wondering, has anyone else considered this: I have been flying with my lipo attached to the bottom (larger lipo) and works great. Is there any advantage to having the lipo attached to clean part vs dirty part? It seems like there would be some differences in vibration. I've tried both, and had problems with the lipo on the clean side (excessive vibration). So I moved it back down . Using 4000 4s
Flying with a 5000 4s on the bottom. I had it on top in the beginning and no vibrations. Though I like it more on the bottom below. For weight lifting instead of pushing it in the air.
Old Apr 08, 2015, 12:15 PM
hskb is online now
Find More Posts by hskb
United States, CA, Sunnyvale
Joined Apr 2014
Genivos, Thanks for your reply, which give me hope that I can still figure out to fix the 13" props.
Could you please post a pic of your 13" quad?
How many screws do you use to tighten the xl arm?
hskb is online now Find More Posts by hskb
Old Apr 08, 2015, 04:06 PM
Genivos's Avatar
Joined Oct 2013
You're welcome. I will try to explain. The straight part of the arm is pointing to the back or front of the frame. The both not straight sides are pointing towards each other. Hope you can see it on the picture. Difficult to show. But you can install them in such way that they are pointing more far away from each other.
I will try to upload pics tomorrow morning
Last edited by Genivos; Apr 08, 2015 at 04:07 PM. Reason: Can't attach pictures on phone for some reason
Old Apr 08, 2015, 06:07 PM
hskb is online now
Joined Apr 2014
Thanks again Genivos,
I follow your post above, and now sure i can use 13" props on them
The "angled" corners of the front and the back arms should face each other.
Big thanks.
Old Apr 09, 2015, 12:03 AM
Genivos's Avatar
Joined Oct 2013
Big thanks.
Yep, exactly, that's it. Couldn't find the word angled. Lol. Glad I could help.
I could also finally upload my photo from a laptop. Not that it is still needed but who knows, for others in the future. I'm flying now with 12" props. On the photo I put 13"props in place which also fit fine.
Old Apr 09, 2015, 10:13 AM
Tom T is online now
Find More Posts by Tom T
Learning to crash
United States, IN, Indianapolis
Joined May 2014
I'm in the process of doing a few parts replacement after a crash last week (two ESC's, 2 motors) on my Flip FPV frame. Lost radio signal from my DX6 out over the muddiest damn field in central Indiana. Already ordered a Taranis X9D+ to eliminate that issue though. Still running the SS2212-980's with HQ 9x4.5 props, but would like to get a set of good CF 9 or 10" props for it. I'm not sure what a good set might be that will fit on the Sunnysky threaded motor mounts using the M5 locknuts.. Any suggestions please?
Tom T is online now Find More Posts by Tom T
Old Apr 09, 2015, 12:41 PM
hskb is online now
Joined Apr 2014
What CF prop do you want to buy?
My personal experience with the cheap CF prop is terrible.
I now use APC Multi-rotor Prop or Graupner eProps only, no Cheap chinese cf prop.
Old Apr 09, 2015, 01:19 PM
IWCoburg is online now
Find More Posts by IWCoburg
Member FPV UK
IWCoburg's Avatar
Isle of Wight, UK
Joined Apr 2010
Just getting back in to hobby and want to get my flip finished. I want to run a front gimbal, and most likely this will be a H2D, but was looking for opinions on which controller to run with. Going to use my taranis by not decided on APM, pixhawk or naxa-m, so wondering what peoples thoughts are please?
Mike.
IWCoburg is online now Find More Posts by IWCoburg
Old Apr 09, 2015, 03:36 PM
Stealdesk is online now
Find More Posts by Stealdesk
Hey ya'll watch this
Stealdesk's Avatar
United States, TX, Arlington
Joined Jun 2005
I have APC on mine and could not be happier. I have tried many different props and always gone back to the APC.
Stealdesk is online now Find More Posts by Stealdesk
Old Apr 09, 2015, 03:38 PM
Stealdesk's Avatar
Joined Jun 2005
Mike.
Look at the Eagle Tree Vector I have been happy with mine. It's easy to set up and has built in osd.
Old Apr 09, 2015, 04:57 PM
Tom T is online now
Learning to crash
Joined May 2014
I dont mind paying for a couple sets of Graupners and looked at them but wasnt sure on the bore selections and didnt want to screw a set up trying to bore them to whatever it needs to be. Hence the reason I added I was using the SS motors with their bolt on threaded M5 adapters.
Old Apr 09, 2015, 05:36 PM
hskb is online now
Joined Apr 2014
for Graupners, you can buy the one with 5mm bore to fit on your ss motors. I have these on my Flip 360 FPV powered by sunnysky x2216 motors - can't beat the price from Towerhobbies with club discount:
http://www3.towerhobbies.com/cgi-bin...?&I=LXEUVH&P=7
note: Hole Diameter: 0.197, 0.23, 0.314" (5, 6, 8mm)
On my full size FPV, i bought the 8mm bore 13"x8" prop, and buy adapters (8mm to 5 mm) from getfpv.com. : http://www.getfpv.com/catalogsearch/...Graupner+Props
http://www3.towerhobbies.com/cgi-bin...VSEARCH=e-prop
Old Apr 09, 2015, 10:03 PM
Tom T is online now
Learning to crash
Joined May 2014
Thank you hskb.
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 05:06 PM
Discussion Hoverthings quad flipping and crashing randomly? easymoney99 Multirotor Talk 9 Jun 12, 2012 02:17 AM
Sold Hoverthings HT-FPV black Lucasberg Aircraft - Electric - Multirotor (FS/W) 3 May 04, 2012 08:10 AM
Sold Hoverthings FPV Quad Plug-n-play W/ Naza Blucross Aircraft - Electric - Multirotor (FS/W) 1 May 01, 2012 06:26 AM
Discussion Test flight of Hoverthings.com FPV 'Ralphie' frame daign FPV Talk 1 Jan 16, 2012 01:27 PM
