Old Nov 05, 2014, 10:10 PM
Joined Jul 2012
Plane shuts off
every thing come from twistedhobby,, motor1750kv esc20amp battery 800,s plane flies for about one minute shuts off dead. Walk to plane see light on receive blinking. Sticks are dead. What for minute plane comes back to life flies good for a while than plane shuts off. Tried three times gave up. Please help. Forgot to tell you receiver also come from twistedhobby
groundman is offline Find More Posts by groundman
Old Nov 05, 2014, 11:36 PM
Digital Don's Avatar
United States, IL, Manteno
Joined Dec 2006
groundman,
Sounds like the battery is not fully charged. What you describe is exactly what happens when you hit Low Voltage Cutoff (LVC).
Don
Digital Don is online now Find More Posts by Digital Don
Old Nov 06, 2014, 08:19 AM
Addicted to 3DHS and EF
3Daddict's Avatar
ohio
Joined Oct 2010
Originally Posted by Digital Don View Post
groundman,
Don
+1, Try another battery that you know is good. if you have pulled that battery down that low it is more than likely no good anymore.
3Daddict is offline Find More Posts by 3Daddict
Old Nov 06, 2014, 08:54 AM
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Sounds more like the BEC is getting hot -then cooling
Very common failing on electric powered models where the power battery feeds power (reduced to aprox 5.5 volts) through the BEC to the rx
cause - too much power being pulled by servos ,is typical.
The BECs are the weak link in all these setups.
The stronger the power battery and the more power pulled by the motor - the worse the situation will become because the ESC heats more .
richard hanson is online now Find More Posts by richard hanson
Old Nov 06, 2014, 02:26 PM
Joined Jul 2012
Found problem.the plug going into esc was very loose. Replaced plug things are great Thanks all.
Discussion Help with Plane shutting off davidbross Parkflyers 2 Oct 02, 2014 08:47 AM
Discussion Trouble - plane shuts off in flight ASX3 in Carbon Cub davidbross Electric Plane Talk 6 Oct 01, 2014 09:25 PM
Question winch shut off switch ozmo01 Thermal 15 Nov 22, 2013 10:41 PM
Sold Fuel pinch shut-offs lectroglide Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 03, 2013 09:28 PM
Discussion Plane shuts off ( any suggestions) busheadfox Power Systems 4 Apr 17, 2006 09:21 PM
