Old Jan 09, 2014, 02:48 PM
IntheTubeDeep's Avatar
United States, CA, San Diego
Joined Jan 2011
Freewing Su-35 Pilots Flying on FrSky Taranis Resource
Ok Su35 flyers using the awesome FrSky Taranis, hopefully this thread will be a good place to get info you need to set up and fly your Su35 on the new Taranis and OPEN-TX firmware. I will post all my eepe files and other downloads such as Model Images and Sounds. Everyone please feel free to post your own files here, it could be a great resource for us all
IntheTubeDeep is online now Find More Posts by IntheTubeDeep
Old Jan 09, 2014, 03:00 PM
Joined Jan 2011
My home screen on Taranis
Old Jan 09, 2014, 03:02 PM
Joined Jan 2011
YT vid of my Taileron Set up- the mixes are all included in
my eepe file
FrSky Taranis 16ch Programming Mix on Freewing Su-35: 360TV & Tailerons (12 min 34 sec)
Old Jan 09, 2014, 03:13 PM
Joined Jan 2011
Binding 2 x X8Rs to get 16ch
Here's how you bind 2 x X8Rs to get 16ch on Taranis
Taranis How To: Bind Two X8R's together to get 16 Channels (6 min 35 sec)
REMEMBER ON Rx 1 NO JUMPERS, Rx 2 JUMP
SIGNAL PINS on ch1&2!!
* IN MENU REMEMBER EACH MODEL HAS ONE(1) RECEIVER, FOR EXAMPLE MY SU35
UNDER "CHANNEL RANGE" Shows Receiver number 01, THAT MEANS EVEN IF I BIND
2 X8Rs THE Receiver Number will BE 01, NOT 02 for 2nd X8R!! I MADE THAT MISTAKE
AND IT WILL NOT WORK!! TARANIS AUTOMATICALLY ASIGNS THE 2nd X8R IN SEQUENCE
SO DO NOT CHANGE THE Receiver Number!
Connector for 2 X8Rs
FrSky Taranis: How to Connect 2 X8Rs from One BEC (2 min 42 sec)
Old Jan 09, 2014, 03:15 PM
Joined Jan 2011
How to make Custom Voice Files for Taranis
Heres How to make Custom Voice Files for Taranis
FrSKY Taranis How To: Create Custom Voice/Audio Files for Alerts in OPEN-TX (14 min 51 sec)
FrSky Taranis Voice Alert for Freewing Su35 (1 min 0 sec)
Old Jan 25, 2014, 01:19 PM
Joined Jan 2011
Latest eepe file 1/26/14
Latest ITTD Su35 eepe file from Jan 26 2-14 This version includes the FOD screens following
gear AND on an override switch with gear down in case I want screens up on takeoff
The channels are as follows for Rx
ch1- THR
ch2- ELE L
ch3- AIL L
ch4- RUD R
ch5- Gear
ch6- TV Rud (Vector 3)
ch7- TV L (Vector 2)
ch8-TV R (Vector 1)
ch9- R ELE
ch10-Wheel Brakes
ch11- FOD Screens
ch12- RUDDER AIRBRAKE
ch13- AIL R
ch14-RUD L
ch15-Steering Rud
ch16-
Old Jun 25, 2014, 11:27 AM
Mach One
captain MoMo's Avatar
Joined Apr 2011
subscribed
captain MoMo is online now Find More Posts by captain MoMo
Old Jun 25, 2014, 11:04 PM
Joined Jan 2011
Good timing CMM! I'm uploading the latest Su35 eepe files
Originally Posted by captain MoMo View Post
subscribed
Old Jun 25, 2014, 11:08 PM
Joined Jan 2011
Latest Su35 eepe Files 6/22/14
Latest Su35 eepe Files 6/22/14, I will post the channel order later
Old Jun 25, 2014, 11:18 PM
Joined Jan 2011
How to set up X8R & 1 S.Bus Decoder to get 12 Channels
1 x X8R + 1 x S.Bus Decoder =12 channels
FrSky Taranis: How to Set Up the S.Bus Decoder to add 4 extra channels (12 min 0 sec)
Old Jul 01, 2014, 12:02 AM
Joined Jan 2011
Taileron Mix for Su35 on Taranis
Pilots this is my first attempt at Tailerons, I've since simplified it in my new desert camo, I'll will post that video tomorrow, its much more streamlined!
Old Jul 03, 2014, 01:03 AM
Joined Jan 2011
FrSky Taranis How To: Get 16 Channels from 1 x X8R & 2 x S.Bus Decoders
Title says it all
Btw if you're using a single X8R the latency is 9mS, once you add an additional X8R or S.Bus Decoder(s)
the latency goes to 18mS for ALL channels, Resolution is not affected
Links:
Here's what you need:
http://www.alofthobbies.com/frsky-x8...nna-combo.html
http://www.alofthobbies.com/servo-channel-changer.html
http://www.alofthobbies.com/frsky-sbus-decoder-1.html
FrSky Taranis How To: Get 16 Channels from 1 X8R & 2 S.Bus Decoders (16 min 9 sec)
Old Jul 03, 2014, 06:04 PM
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
Since I joined the Taranis club because of you, I better join this thread also. Thanks for starting this thread. I'm sure it will come in handy for me since the Taranis thread moves along WAAAAYYYYYY too fast.
garryk is offline Find More Posts by garryk
Old Jul 04, 2014, 12:19 AM
Joined Jan 2011
Welcome to the cutting edge Taranis/Su35 club garry! Yup that Taranis thread moves so fast, if you miss a day or 2 you're gonna have to spend a few hours catching up Ok how far are you into Taranis? Have you flown any planes yet? damn I'mwaiting for ou to hook up your sweet Desert Camo on Taranis and post the vid flying on Taranis
Old Jul 04, 2014, 09:09 AM
Andrew Scerbina
Toronto, On
Joined Aug 2007
Subscribed! ITTD why do you need 15 channels? I counted 13 for your plane. AIL is on one channel, isn't it? Do you really need AIL L and AIL R? Also Rudder airbrake seems to be redundant. It is a channel per servo. RUD-L and RUD-R is all that is needed for full functioning rudder and airbrake. Just trying to see if I am missing something.
Unless: You can use Ailerons as Flaps That would be nice. And then use the tailerons for the Roll control while landing. What do you think?
Andrew
scerbina is offline Find More Posts by scerbina
Discussion Question on FrSky Precision Vario, X8R and Taranis Chuchuf Radios 10 Sep 09, 2014 10:05 AM
Sold Freewing SU-35 gromitvt10 Aircraft - Electric - Jets (FS/W) 3 Sep 27, 2013 09:23 AM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 10:02 PM
Discussion Freewing Su-35 fredmdbud Foamy EDFs 0 Dec 26, 2011 09:05 PM
