Old May 18, 2014, 01:17 AM
Joined Mar 2014
Question
Flite Test Swappable Series
I was thinking about purchasing the 3-pack (the nutball, ft flyer, and delta). However, after researching a little more, I discovered that the swappable series is not really that swappable. The different kits (the plans for these kits are free on their website) require different motors, batteries, props, etc. The only things that I think are truly swappable are the ESC, receiver, and fuselage. Have any of you had any experience with the flite test kits? Are they worth it? This would be my first time doing a kit/scratch build by the way. Thanks for your time and help!
benman2468 is offline Find More Posts by benman2468
Old May 18, 2014, 01:41 AM
nerdnic's Avatar
United States, CA, Sunnyvale
Joined May 2014
The basic 3 you've listed can run the same electronics. All the other planes can be run off another set of electronics. So really if you want to fly all of their planes you'd need 2 full electronics set ups.
There are many different motors/esc combos that will work but a 50-70g 2-300 watt motor with a 1500-2200 3S and 40a esc is what you'd need for the second electronics set up and it will fly everything from the versa, duster, all the way to the spit, racer, and mustang.
nerdnic is offline Find More Posts by nerdnic
Old May 18, 2014, 02:53 AM
You laugh... But it flies!!!
TEAJR66's Avatar
United States, MO, Rocky Mt
Joined Oct 2013
The kits are well worth the time to download the plans scratch build them. The speed build kits are worth the price, to me, when I don't want to take the time to measure and cut. I have not been disappointed with any of the FT designs that I have played with in either scratch or speed build. For the three pack, one power pod set up should swap through the three airframes and fly them well with no issues.
Be safe and have fun,
Tommy
TEAJR66 is offline Find More Posts by TEAJR66
Old May 18, 2014, 10:07 AM
Joined Apr 2013
Those FliteTest builds are very nice, but to me it seems almost pointless to build someone else's design according to a "script". Might as well just by an ARF - there are tons of very reasonably priced, very nice performing ARFs out there.
Now, if you're designing it yourself, then it's a whole different story. Even if you know the basic idea will work, it's a challenge to work out the implementation details and tweak stuff and re-test - that's rewarding for me.
In all cases, if the plane gets damaged you'll need to have some degree of understanding to repair and re-balance.
nuteman is online now Find More Posts by nuteman
Latest blog entry: My youtube channel
Old May 18, 2014, 12:27 PM
Joined Mar 2014
Nerdnic could I keep the same esc and receiver for all the airplanes? I'm just trying to figure out the cheapest setup possible to fly the most airplanes. I don't want a bunch of plane-specific parts that can only be used with one model.
Old May 18, 2014, 01:53 PM
nerdnic's Avatar
Joined May 2014
Yes. I did just that. I started with a 40a esc which is heavy for the nutball but it worked. The delta and flyer won't know the difference. I used the same receiver for all my planes, it sits nicely in the power pod. So you'll end up with two different motors and two different batteries but the rest can be swapped.
I've built around 20 FT birds so far and have really enjoyed the scratch building aspect. It's such a cheap way to enjoy the hobby and the swappable design only adds to the value.
Old May 18, 2014, 03:48 PM
Joined Mar 2014
Two questions:
1. Would I need different props?
2. This probably had something to do with me not knowing what an esc does, but why do I need a 40a esc? The most that they recommend for any of their kits is 25a.
Old May 18, 2014, 04:38 PM
nerdnic's Avatar
Joined May 2014
1. It will all depend on what motors you get. But likely you will have a slow fly prop on the smaller motor and a normal 8x6 apc on the bigger motor.
2. Depending on what motor you get for the big one, you can pull 30a easy. You always want 15-20% head room on your esc in general. The 40 just gives you more motor options.
Where are you planning to buy parts from? I can link some suggestions if you want.
Old May 18, 2014, 04:54 PM
Joined Mar 2014
Links are always appreciated! I was planning on ordering from hobbyking (US warehouse only). It just seems that the 40a is so much more expensive than the 25a
Old May 18, 2014, 06:20 PM
Joined Apr 2013
I just looked on HobbyKing's site.
The 25A ESC is about $13 and a 40A ESC is about $19 dollars (link provided below)
It just doesn't pay to NOT get the 40A
http://hobbyking.com/hobbyking/store...ontroller.html
Old May 18, 2014, 10:17 PM
Joined Mar 2014
Why would a 40a esc be more expensive than a 45a esc?
Old May 18, 2014, 10:25 PM
WombatControl's Avatar
Joined Jul 2011
The three-pack of swappables can take the same power pod - they can use the same motor, ESC, and receiver. All of them will run just fine on a 1300kv Blue Wonder and a 12amp ESC with an 8x4 prop. You certainly can use the same power pod, although swapping the servo connections would be a bit annoying.
A 40A ESC will work just as well, although it will add dead weight - you will not be pulling anywhere near that level of amp draw.
If you want a very beefy setup that will let the Nutball really perform, you can go for this kit:
http://www.altitudehobbies.com/flite...appable-series
It's slightly more expensive than HobbyKing, but all the parts are in one set and the connections have already been soldered for you.
Add in a 500mAh 3S or 800 mAh 2S and you'll have a really nice setup for all three.
WombatControl is offline Find More Posts by WombatControl
Old May 18, 2014, 11:16 PM
Joined Mar 2014
I thought the linkage stoppers came with the servos. I see that the link wombatcontrol posted comes with 4 linkage stoppers and two servos. Do I need two stoppers per servo or I are there two extra in the kit? I also was not aware that I would have to solder anything. How would I know it the parts I'm looking at need soldering?
Old May 18, 2014, 11:34 PM
Joined Jul 2011
There are two extra. You'll only need one linkage stopper per servo.
Most ESCs and motors come with bare wires, so you'll need to do some soldering to connect them with bullet connectors. Smaller motors like the Blue Wonder will usually use 2mm bullet connectors. Larger motors use the 3.5mm bullet connectors.
You'll also generally need to add your own battery connector. The good news is that with these airframes, you'll want to use JST connectors. With JST connectors, you can just crimp pins on the wires with a wire crimper or a needle-nosed pliers - you don't need to solder those.
Old May 19, 2014, 12:53 AM
Joined Mar 2014
Ok so:
The servos: http://hobbyking.com/hobbyking/store...ehouse%5F.html
The battery: http://hobbyking.com/hobbyking/store...ehouse%5F.html
The motor: http://hobbyking.com/hobbyking/store...ehouse%5F.html
The ESC: http://hobbyking.com/hobbyking/store...ehouse%5F.html
Do any of these need soldering, and if so, what parts do I need? Links are very helpful.
For Sale E-Flite EC5 Series Connector, Deans to EC5 Series Connector,and 4mm to EC5 Connectors MitchellY Aircraft - General - Miscellaneous (FS/W) 0 May 12, 2014 12:13 PM
For Sale Top Flite F4U Corsair Gold Edition 60 series Kit Buzzox45 Aircraft - Fuel - Airplanes (FS/W) 3 Sep 29, 2013 04:24 PM
Discussion Flitetest Swappable Series rapture_212 Foamies (Kits) 7 Jun 07, 2013 10:36 PM
Discussion Making a non-swappable LiPo swappable gbjbasdw Coaxial Helicopters 28 Sep 26, 2011 09:50 AM
