Old Jul 31, 2015, 05:53 PM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
Originally Posted by Ramnes View Post
Hey
I know, I downgraded it for a few days ago to test if that was the reason, but I found the reason for it. It was a screw that was to long and it was screwd a little to long into the windings, cutting them. When the screw was there it almost worked, when out, it didn't work at all.
I've ordered new motors.
Jorn
Put the screw back
bcollydas is offline Find More Posts by bcollydas
Old Aug 04, 2015, 06:44 AM
dz1sfb is online now
Find More Posts by dz1sfb
Slipping the Surly Bonds
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Hey
Jorn
Been there, done that! I hate it when that happens.
Ken
dz1sfb is online now Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Aug 04, 2015, 04:02 PM
Slobberdog is offline
Find More Posts by Slobberdog
Joined Jun 2015
I apologise if I'm going over old ground but I'm new to gimbals,
Been putting together my home made gimbal for a mobius cam using the GLB Alexmoss mini 8bit on 2.4 b7 and Multistar 1807-340kv motors,
Gimbal is pretty well balanced, but I get a high pitch noise when I plug the power in to the gimbal,
Changed the PWM setting to high but it's still there,
What do I need to do to get rid of the noise,
Slobberdog is offline Find More Posts by Slobberdog
Old Aug 04, 2015, 11:14 PM
fmimages is offline
Find More Posts by fmimages
fmimages's Avatar
United States, OR, Portland
Joined Nov 2010
I have the same problem with the 8-bit.
fmimages is offline Find More Posts by fmimages
Old Aug 05, 2015, 09:05 AM
Joined Jun 2015
here is a video of what mine is doing, any help would be gratefully received,
Gimbal noise (0 min 23 sec)
Old Aug 08, 2015, 08:27 AM
Z303 is offline
Find More Posts by Z303
Joined Jan 2013
thanks on help it is faulty motor i put other motor and works fine
Z303 is offline Find More Posts by Z303
Old Aug 10, 2015, 02:54 PM
fmimages is offline
fmimages's Avatar
Joined Nov 2010
I have the Alexmoss mini 8bit on 2.4 b7 on a CS1 gimbal and now I'm trying to get the shakes out of the gimbal when flying. It's setup to all the recomendations from the CS1 people and not its down the the finishing touches. I'm new to this. My props are balanced on my DJi Phantom 2 and the vibration/shakes come on when off the ground and flying. I'm interested in any suggestions that somebody might have. I already burnt the first controller but now I can use the GUI and reset, etc. without problems.
Old Aug 19, 2015, 06:00 PM
Dimitris76 is offline
Find More Posts by Dimitris76
United States, IN, Carmel
I am using the 8-bit controller on my 3-axis TRD Beholder Aero gimbal and I have to say I am impressed with the performance I got.
I am too in the process of ironing out some details though.
One of the most annoying phenomena is a violent vibration mostly on the yaw axis that I get at extreme pitch angles +/-45 or more. It starts slowly with a low frequency-small amplitude oscillation and it picks up quickly. After a second or so the gimbal is shaking so violently that the yaw motor cogs to the next position - either to the left or to the right -that happens randomly and it's loosing the center (I am using the gimbal in yaw-follow mode).
This happens both when I tilt the quad and when I manually pitch the camera via R/C. I feels like the initial oscillation is exciting the IMU which is giving back positive feedback to the motor to oscillate faster and so on...
But why does this happen? Why on the yaw axis when the quad or the camera is just tilting on pitch axis? What could I do to fix that?
I am attaching a screen shot of my current settings.
Thank you in advance
/Dimitrios
Dimitris76 is offline Find More Posts by Dimitris76
Mini-HowTo Super Simple Gimbal - SSG - KK2.1 & OpenPilot support crezzee Aerial Photography 1655 Jul 16, 2015 12:51 PM
Yippee! Simple Brushless Gimbal Controller--FPV MODEL fpvmodels Multirotor Talk 3396 Dec 26, 2014 06:23 PM
Discussion A very simple camera-gimbal for Gaui 330xs babanan Multirotor Talk 2 Oct 09, 2013 08:46 AM
