Old Feb 07, 2016, 11:23 AM
jeffrey44 is offline
Find More Posts by jeffrey44
United States, CT, Plainfield
Joined Dec 2013
Receivers
Can I use a ar6100e spectrum receiver on a 40 size aircraft ?
jeffrey44 is offline Find More Posts by jeffrey44
Old Feb 07, 2016, 11:40 AM
Zeeb is offline
Find More Posts by Zeeb
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
That rx is classified as a "Park Flyer" unit and as such should not be used in anything that would normally require a "Full Range" rx because it's not.
Zeeb is offline Find More Posts by Zeeb
Old Feb 07, 2016, 12:06 PM
Joined Dec 2013
Thank you. I will take your advice and not use it for that application
Old Feb 10, 2016, 02:53 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Firstly the 6100 is probably faked. These RX are not produced for many years. And as already noticed it is not specified for flying greater distances because it only has 1 receiver/antenna set.
Mukenukem is offline Find More Posts by Mukenukem
Old Feb 10, 2016, 06:05 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Why would you say that (highlighted) in that specific way? Do you know the exact history of the one the OP owns?
Back in my Spektrum days I had quite a few AR6100 receivers in my smaller gliders and electric planes and they performed flawlessly. Some of the gliders were taken out to a point where they were a small dot in the sky and I never lost control. Range of these receivers is not the issue - the single antenna being easily shadowed by a larger metal containing object like an engine or a 2S 1800mAh or larger battery is.
I still keep one AR6100 for bench testing purposes with the DSM2/DSMX module conversions I provide. All of my AR6100s were bought either from Horizon or Horizon authorized resellers and all of them (minus the one I still have) went to Horizon for a check up before I sold them here on RCG. They came back with a clean bill of health and upgraded to the latest FW, a sure sign they were not fakes. I did know they were not fakes even before I sent them for the check up as I bought all of them before the clones, fakes and "compatibles" appeared.
Ivan
ivanc is offline Find More Posts by ivanc
For Sale Jr Receiver, Fma Receiver, Hi-tech Receiver chrisc Aircraft - General - Radio Equipment (FS/W) 0 Aug 11, 2008 11:51 PM
For Sale JR 955 10ch receiver with 4 receiver receiver crystals ch25 and module crystal kirbster Aircraft - General - Radio Equipment (FS/W) 0 Jun 29, 2008 02:20 PM
Cool End pin receivers, satellte receiver, and micro-receiver JimDrew Xtreme Power Systems 93 Feb 13, 2008 12:38 AM
Sold Receivers, receivers, receivers. Skyfish Aircraft - General - Radio Equipment (FS/W) 9 Jun 20, 2006 01:00 PM
