Old Dec 05, 2015, 08:46 PM
jpurcha is offline
Find More Posts by jpurcha
jpurcha's Avatar
Canada, MB, La Salle
Joined Sep 2004
Skyangel T-45 Landing gear
Anyone have or know where to get landing gear for the Skyangel T-45?
Jim
jpurcha is offline Find More Posts by jpurcha
Old Dec 06, 2015, 12:00 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Jim
Hobby King .... STINGER .... $6 including steerable front wheel etc.
http://www.hobbyking.com/hobbyking/s...Search=stinger
t45 dec 31 2011 (1).AVI (4 min 14 sec)
Nigel
solentlife is online now Find More Posts by solentlife
Old Dec 06, 2015, 02:44 PM
jpurcha is offline
jpurcha's Avatar
Joined Sep 2004
Thanks, i'll keep these in mind.
Jim
Old Dec 07, 2015, 02:17 AM
shschon is offline
Find More Posts by shschon
shschon's Avatar
United States, CA, SF
Joined Aug 2004
These should fit right into the landing gear socket on the skyangel T-45 as they are the from the same company
http://www.bananahobby.com/front-gea...8340-prd1.html
http://www.bananahobby.com/main-gear...8341-prd1.html
shschon is offline Find More Posts by shschon
Old Dec 07, 2015, 02:38 AM
solentlife's Avatar
Joined Jan 2010
Various outlets do the specific gear for the 50mm JPowers series ... but they are fixed nose and require modification to add steering.
The Stinger is a set that has integral steering and costs less for actually a better system.
Here's a video showing at start removal of gear prior to hand launch. The Nose leg stub left after removal - in fact provides a good point for attaching a bungee hook ...
Crazy winter T45 flying 08-01-23012.wmv (3 min 31 sec)
Nigel
Old Dec 08, 2015, 03:16 AM
shschon is offline
shschon's Avatar
Joined Aug 2004
https://www.youtube.com/watch?v=qEVWiho8yx0
Nigel
The stinger 64 set is a nice set just a bit on the heavy side. Small edf jets are sensitive to weight and CG. Can still fly but I worry about performance reduction. Also the steering servo require cutting out some foam to install inside fuse, a bit more work.
Old Dec 08, 2015, 05:10 AM
solentlife's Avatar
Joined Jan 2010
In fact the weight of the Stinger is not much more than the proprietary stuff except for the nose servo.
I fitted it to my T45 which flies with anything from 1300 3S up to 1600 4S without any change of weights added to tail ... I have about 30gr fixed to tail (15gr either side of fin) ... my CoG ranges from about 60mm down to 15mm back from LE at fuselage and she flies fine whatever I put in her.
Speed reduction is small in fact I would estimate about 5 - 10kph only. I would not fly it with a small 3S pack though ... a 1300 size or more to keep amps up ...
Of course there are alternatives ... all I say is this combo works well and gives full steerage up front ... removeable for hand / bungee launch ... etc.
And for less price than a servo .............. ??
You've seen the video earlier ...
Nigel
Sold Freewing T-45 Used Landing Gear howieal Aircraft - Electric - Jets (FS/W) 1 Dec 04, 2015 10:25 AM
Sold Freewing T-45 Landing Gear Set From Crashed Plane howieal Aircraft - Electric - Jets (FS/W) 2 Nov 03, 2015 08:59 PM
Wanted Updated - Trade a SkyAngel 35mm F-86 RTF and NIB for a SkyAngel T-45 (35mm or 50mm) girick Aircraft - Electric - Jets (FS/W) 0 Apr 07, 2015 08:01 PM
Sold Skyangel 50mm T-45 w/ landing gear bruff Aircraft - Electric - Jets (FS/W) 0 Mar 16, 2015 05:26 PM
Help! Skyangel 50mm T-45 landing gear bruff Arizona Model Aviators 3 Jan 21, 2015 07:30 PM
