Espritmodel.com Heli Air
Old Nov 05, 2012, 10:59 PM
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Thanks for posting!
I read the book when it came out but this is the first time I've seen more than still pictures.
The landing at Santorini is nothing like I imagined.
Pete
PeteSchug is online now Find More Posts by PeteSchug
Latest blog entry: A WASP named Brownie
Old Nov 05, 2012, 11:15 PM
San Jose, CA USA
Joined Oct 1999
Originally Posted by MIT KID View Post
Bob flying the Chrysalis model at 10:35 in the first video.
-Adam
In the very first shot, you can see the wing warp... a servo pulled on the bracing wires and twisted the wing... but really moved the whole plane!
The mad dash to the plane after the nose over landing was because this was long before ESC's existed. There was just a manual switch on the motor, so we had to get to the plane to turn it off before the stalled motor cooked itself!
Ahh.. the bad old days! ;-)
I would not want to put the time and effort into a built up model. But a 6 ft laser cut Depron one might actually get finished.
Bob
parky is offline Find More Posts by parky
Old Jan 22, 2013, 08:46 PM
Aircraft Designer Guy
MIT KID's Avatar
Melrose, MA
Joined Jul 2005
Started work on the 72 inch version. At first I was going to make it a simple 2x version of the original, but then the details started getting to me.
This one will have a full fuse, printed pilot/engine, v-mounts, and removable wings. Also mixed up a batch of paint to match foamular pink as best I could :P
Airframe is done minus covering and it's at about 15g, should be able to come in under an ounce.
-A
MIT KID is offline Find More Posts by MIT KID
Old Jan 23, 2013, 02:05 AM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
thats awesome! do you think the wings will be too flexible? or is that carbon going to be enough?
starting into indoor freeflight it really makes you look at EVERY component and how much you can remove before it cant support itself anymore, then add .002" and it works lol
kidding aside, it looks great so far
derk is offline Find More Posts by derk
Old Jan 23, 2013, 07:17 AM
Pigeon 4 life.
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
Thats amazing!!!!!!!!!!!!!!!!!!!!!!!!
addictedtoplanes is offline Find More Posts by addictedtoplanes
Old Jan 23, 2013, 11:03 AM
confused poet
HanksGB's Avatar
USA, CA, Orange
Joined Feb 2004
Very Cool indeed.
Good work Adam
Henry
HanksGB is offline Find More Posts by HanksGB
Old Jan 23, 2013, 01:57 PM
San Jose, CA USA
Joined Oct 1999
-A
Ok, but if you are going that far, the pilot/engine has to have the legs pedaling!
At an ounce, this could be pretty nice!
Bob
Old Jan 23, 2013, 03:14 PM
prefer lift over drag anyday
flyzguy's Avatar
Joined Jun 2005
how was the V-mount constructed? Looks like laser cut G-10 fiberglass maybe? If it was a 2d cut part, how was it folded to shape?
flyzguy is offline Find More Posts by flyzguy
Old Jan 23, 2013, 03:26 PM
MIT KID's Avatar
Melrose, MA
Joined Jul 2005
Laser cut .025 G10, with etch marks where the folds go. I put a piece of tape on the back of the part before folding to keep everything together, then hit each corner with a drop of CA.
-A
Old Jan 23, 2013, 09:17 PM
MIT KID's Avatar
Melrose, MA
Joined Jul 2005
Got everything covered, the wing mount done, and the tails on. Going to check CG tomorrow morning with the rx brick battery and motor, hopefully I don't have to switch to a lighter boom. It would be an easy way to save a gram or two, but I don;t have any hollow tubes on hand.
-Adam
Old Jan 24, 2013, 08:01 PM
MIT KID's Avatar
Melrose, MA
Joined Jul 2005
Brick and pushrods setup, just need to solder up the motor and it's good to go. Right at 28g with the Vapor battery
-A
Old Jan 25, 2013, 07:30 AM
Centreville,VA,USA
Joined Apr 2001
Wow incredible. Are you going to shape all the LE's?
Pete
mtflyr is offline Find More Posts by mtflyr
Old Jan 25, 2013, 11:06 AM
MIT KID's Avatar
Melrose, MA
Joined Jul 2005
Thanks! I knocked the corners off everything,bit no real shaping
A
Old Jan 26, 2013, 01:32 PM
MIT KID's Avatar
Melrose, MA
Joined Jul 2005
Got it in the air. Flies very nicely, although way too big for the office lobby. I ended up adding a second bracing wire, which eliminates the wing flutter I was seeing on the smaller one. Really looking forward to flying this in a big space. Looks slower in the air than the smaller one.
DAE 72 Trim Flights (0 min 25 sec)
-A
Old Jan 26, 2013, 01:55 PM
derk's Avatar
Joined Dec 2003
SWEET! looks great!
Contest Build Off II - 1/6 Scale de Havilland DH. 88 Comet - Design W@CC0 Scale Electric Planes 51 Nov 06, 2009 11:52 AM
Contest Build Off II - 1/6 scale de Havilland DH.88 Comet W@CC0 Scale Electric Planes 139 Feb 03, 2009 12:26 PM
Discussion DC-6 Build / scale 1:18 / 88" wingspan | QUESTIONS AlexanderB Scale Electric Planes 2 Nov 30, 2008 04:00 AM
Build Log DH88 Comet PSS 88" 1:6 scale BigS Slope 16 Jan 31, 2007 11:55 PM
Discussion 1/5 Scale Yellow Aircraft Spitfire 88" WIngspan. Telstar Electric Warbirds 3 Mar 16, 2006 11:20 AM
