Old Jan 22, 2016, 09:51 AM
Dreamcatcher is offline
Find More Posts by Dreamcatcher
Warbirds Lover
Dreamcatcher's Avatar
South of France
Question
Bi-plane flying wing ?
Hi !
I was wondering if anybody ever tested to build a kind of bi-plane from a couple of EPP combat Flying wings ?
(with or without fuselage)
The purpose would be to increase the wing surface without increasing the size of the model and to allow it to carry more loads (for exemple some FPV gear with bigger batteries, and so on...)
Dreamcatcher is offline Find More Posts by Dreamcatcher
Old Jan 22, 2016, 06:31 PM
Pat Mattes is offline
Find More Posts by Pat Mattes
Yoder, Indiana PROUDLY USA
Joined Dec 1996
Not with those particular wings, but sure. What do you want to know?
You'd want to have outer wing struts and something in the center (in the absence of a fuselage), the sole purpose of which would be to keep the two wings continually parallel to each other.
Additionally, you'd want to stagger them rather than stack. The reason being, with a stagger you will have a less sensitive CG point. Those are just a few thoughts. Do you have any particular questions?
Pat Mattes is offline Find More Posts by Pat Mattes
Old Jan 23, 2016, 02:33 AM
ConEx is offline
Find More Posts by ConEx
ConEx's Avatar
Bern, Switzerland
Joined Jun 2010
Something like this?
ConEx is offline Find More Posts by ConEx
Old Jan 23, 2016, 05:37 AM
Warbirds Lover
South of France
I was just wondering if somebody already tested to "link" a couple of this kind of EPP foam wings :
http://www.hobbyking.com/hobbyking/s...be_1000mm.html
In the purpose of a FPV use or to transform them in an "heavy lifter".
I would like to build an EPP FPV / aerial video model. I was thinking to design and build something out of depron but EPP foam is more "crash proof" than the Depron so... it could be better for a prototype.
The other problem is that EPP block are out priced here. That's why i was thinking to use some low cost commercial EPP wings.
Old Jan 23, 2016, 05:38 AM
Warbirds Lover
South of France
Yes, i think that something like this could do the job !
Old Jan 23, 2016, 07:34 AM
Number_6 is offline
Find More Posts by Number_6
Ft Lauderdale
Number_6's Avatar
Joined Sep 2012
Really interesting, do you have video of them flying?
Number_6 is offline Find More Posts by Number_6
Old Jan 23, 2016, 09:51 AM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Here's a thread on a "biplane" flying wing by a great designer and builder:
http://www.rcgroups.com/forums/showthread.php?t=2004271
potshot is offline Find More Posts by potshot
Old Jan 23, 2016, 12:25 PM
nuteman is offline
Find More Posts by nuteman
Joined Apr 2013
Mine accomplishes the above.
See: http://www.rcgroups.com/forums/showthread.php?t=2489266
A lot of the reasons for the way I did it are seen in subsequent discussion on that thread.
Hope that helps
nuteman is offline Find More Posts by nuteman
Old Jan 23, 2016, 12:48 PM
Warbirds Lover
South of France
Thanks potshot,
I had found this video on YouTube last week but it's not exactly what i'm searching.
The model picture posted by ConEx seems to be more able to transport FPV / aerial video cam
Old Jan 26, 2016, 04:28 PM
Joined Dec 1996
But there's a reason why you don't see full scale planes with wings that close together (Conex post). You're not taking full advantage of the lift capability of both wings. With increased inter-wing spacing, you could get by with even smaller wings and have the same amount of lift. With wings that close together, there are aerodynamic interferences which cancel out a lot of the benefit. Yea, it provides a bit more lift, but not nearly maximized for the capability you COULD have.
Old Jan 26, 2016, 04:39 PM
DKNguyen is offline
Find More Posts by DKNguyen
Edmonton, Alberta, Canada
Joined Oct 2008
I think tandem wing might have better performance and be easier to work with too (you basically have a tail) which still would not be as efficient as a regular tail for the reasons Pat mentioned.
DKNguyen is offline Find More Posts by DKNguyen
Old Jan 27, 2016, 02:34 AM
Warbirds Lover
South of France
I agree withe that. I think that the drag generated by one wing can even aerodynamicaly mask the second wing on some angle of attack.
a real Biplane or Sesquiplane solution could be better indeed.
Old Jan 27, 2016, 02:38 AM
Warbirds Lover
South of France
Yep...
What i was thinking about using two wing was to decrease the wing loading of the model without increasing the wing span
Old Jan 27, 2016, 06:56 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Originally Posted by Dreamcatcher View Post
Yep...
Simply increasing the chord of a monoplane to provide that extra area will be more efficient that just about any biplane configuration. It's also much less complicated.
DT56 is offline Find More Posts by DT56
Old Jan 27, 2016, 07:14 AM
Warbirds Lover
South of France
Increasing the wing chord is not the solution imho - it will drive to a poor roll rate, big drag, modification of the plane's horizontal stability and a couple of other annoying things.
New Product 33.5 EPP Bi-plane DW Pitts from Dancing Wings Hobby DW Hobby Beginner Training Area (Aircraft-Electric) 12 Apr 26, 2016 05:52 PM
New Product EPP Bi-plane DW PITTS from Dancing Wings Hobby nac Foamies (Kits) 11 Apr 15, 2016 02:46 AM
Sold Reactor Bi Plane Upper Wing NIB dawhale Aircraft - Fuel - Airplanes (FS/W) 1 Apr 26, 2015 07:44 PM
Sold fms beech craft stagger wing bi plane 40" wing lpu in mission valley $25 warhawk crazy Aircraft - Electric - Airplanes (FS/W) 3 Jan 14, 2014 08:48 PM
Discussion Flying Wing bi-plane? Rusty-Gunn Flying Wings 10 Oct 01, 2006 06:29 PM
