Old Jan 06, 2016, 08:14 PM
Value_Hobby is offline
Find More Posts by Value_Hobby
Oak Park, Illinois
Joined Jun 2008
New Product
New Elite Series 39in 15mm EPP Foam Sbach-342 from Value Hobby with Airfoiled Wings
http://www.valuehobby.com/39in-sbach-epp-profile.html
The 8mm EPP foamies from Value Hobby have been a big success, and now we are following up with a bigger, stronger, and most importantly, airfoiled Elite Series foamie Sbach. As always, the plane is value priced, and with inexpensive and popular brushless power, you will have a lot of foamie fun without breaking your budget.
This plane is made of EPP foam. The fuselage is 15mm(.59in) thickness solid-core EPP. The wing is airfoiled solid-core EPP, and has a maximum thickness of 30mm(1.18in). There are also 2 carbon fiber rod running the full length of the wing and 2 carbon fiber rod running the full length of the fuselage. The plywood landing gear mount on the fuselage can handle rough landings without damaging the foam body. The elevator is reinforced with a piece of balsa wood strip.
The airfoiled wings allow better controls in stronger winds, and all the reinforcement makes sure the plane won't deform when maneuvering your 3D moves. The plane works well with the popular 400-size or 450-size brushless motors. The motor mount can handle motors with 28mm diameter.
Specifications:
Wingspan: 39.4 in(1000mm)
Length: 37.4 in(950mm)
Wing Area: 347.2 sq in(22.4 sq dm)
Flying Weight: Approx. 1lb (450-500g)
Recommended Setup
Motor: 2212-1000KV outrunner brushless motor
Speed Controller: 30A-40A brushless ESC
Servo: 9g digital metal gear servo (4pcs)
Battery: 3s 11.1v 1300mAh LiPO
Prop: 11 x 5.5 prop
Value_Hobby is offline Find More Posts by Value_Hobby
Old Jan 11, 2016, 09:42 PM
FlyinAg is offline
Find More Posts by FlyinAg
I Love 30mm
FlyinAg's Avatar
United States, TX, Wichita Falls
Joined Nov 2001
I am confused... this states that this is a new product, however, this product (at the link above) has been on the website for quite some time. In fact, the dates on the 2 reviews listed there are over a year old...
Is this an update to that original product? Or had the website not been updated? They look the same...
FlyinAg is offline Find More Posts by FlyinAg
Old Jan 12, 2016, 08:04 PM
Oak Park, Illinois
Joined Jun 2008
this is an update from the original S342. it has a different scheme and many minor changes.
Old Jan 15, 2016, 07:15 PM
dermott is offline
Find More Posts by dermott
Joined Jan 2016
Any vids? The numbers look right, but vids (and priced right) sell planes.
dermott is offline Find More Posts by dermott
Old Jan 19, 2016, 02:54 AM
sparktofire is offline
Find More Posts by sparktofire
Joined Jun 2014
Any differences between this one and Red Eagle Hummer?
sparktofire is offline Find More Posts by sparktofire
Old Jan 21, 2016, 10:49 PM
Oak Park, Illinois
Joined Jun 2008
yes, we will add some videos about this plane later.
Sold Twisted Hobbies RCF 48" epp sbach 342 Twinkletoze Aircraft - Electric - Airplanes (FS/W) 3 Nov 13, 2015 06:12 PM
New Product Excellent choice for 3D beginners---39" EPP Sbach 342 & SHINING from DW Hobby ! aeo-tiffany Foamies (Kits) 0 Jul 29, 2015 03:55 AM
Discussion 1m (39.37") Wingspan EPP Sbach 342 by Dancing Wings Hobby nac 3D Foamies 16 Jul 29, 2015 02:14 AM
New Product 20mm EPP Die-sinking Airplane with Airfoil from DW Hobby ! DW Hobby 3D Foamies 47 May 16, 2014 10:17 AM
Sold Hokusei Sbach 342 EPP 39in ARF NIB $70 CONUS wyldkrd Aircraft - Electric - Airplanes (FS/W) 4 Jun 07, 2012 09:33 AM
