Old Mar 12, 2014, 10:28 AM
babaknt is offline
Find More Posts by babaknt
Joined Feb 2014
Addiction Prop-Spinner Problem
Hi,
I just purchased a PA Addiction and got a VOX 12x4 prop with a 1.5" Aluminimum spinner as recommended by PA. I have however problems fitting the spinner over the prop. Have I missed something?
I am using the standard Thrust 20 engine.
Babak
babaknt is offline Find More Posts by babaknt
Old Jan 06, 2016, 02:56 PM
TrueBuld is offline
Find More Posts by TrueBuld
TrueBuld's Avatar
Joined Nov 2013
Originally Posted by babaknt View Post
Hi,
Babak
The spinner that is supplied for the PA Addiction is a carbon fiber spinner with aluminum back plate.
The carbon spinner must be trimmed to match the root of the propeller. PA specify that the gap must not be too small (the actual gap should be in the manual).
I used Dremel with a small grinding wheel attachment.
TrueBuld is offline Find More Posts by TrueBuld
Old Today, 01:34 AM
rwq66 is offline
Find More Posts by rwq66
rwq66's Avatar
United States, CA, Seal Beach
Joined May 2012
I am using a VOX 13X5 and a Great Planes 40mm spinner.
Ron
rwq66 is offline Find More Posts by rwq66
Old Today, 03:45 AM
braeckman is offline
Find More Posts by braeckman
Joined Mar 2007
Hi,
Babak
Hello Babak
I suppose that your spinner just has a too small opening. The Vox props have quite a thick hub on the contrary of the majority of nylon props. You should inscrease the size of the gap and assure (also with a metal spinner) that the prop doesn't touch the spinner at no point (very dangerous because inducing high stress)
Alvin
PA Distribution Germany
braeckman is offline Find More Posts by braeckman
Old Today, 05:00 AM
Poffertjesporem is online now
Find More Posts by Poffertjesporem
Thumbs are overrated.
Poffertjesporem's Avatar
The Netherlands, NB, Sint-Michielsgestel
Joined Nov 2014
This a dead thread as it was started in may 2014.
Poffertjesporem is online now Find More Posts by Poffertjesporem
For Sale ZDZ 80RV, Canister Muffler, Props, Spinner, Prop Bag, Drill Guide newheliguy81 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Feb 28, 2014 06:45 PM
Sold FMS 1400mm P-51 4 Blade Prop & Spinner & 13x9 2 Blade Prop IntheTubeDeep Aircraft - Electric - Airplanes (FS/W) 3 Feb 11, 2014 09:09 AM
Sold BNIB Precision Aerobatics Addiction w/CF spinner and prop adapter ptflyer Aircraft - Electric - Airplanes (FS/W) 9 Jul 10, 2011 08:52 PM
My Miracles' spinner came apart + broke the prop! Has anyone else had this problem? 1g1yy Electric Plane Talk 1 Jul 11, 2005 08:04 AM
Prop And Spinner Problems nmaier88 Fuel Plane Talk 4 May 30, 2004 01:17 AM
