Old Yesterday, 06:24 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Oh crap, I only found the one sawtooth at big Bruce racing so I assumed it was the same as what voodoo used. I'll have to investigate and see if he still makes the other sizes. It seemed like a lot to me too....I figured the sawtooth design had lower amp draw and wasn't directly comparable.
Thanks for the information everyone!
G.P. is offline Find More Posts by G.P.
Old Yesterday, 06:39 PM
feefo is offline
Find More Posts by feefo
#Finally....
feefo's Avatar
Staffs, UK
Joined Apr 2009
I think Voodoo used the GM or AJ pylon props which are on SUSA's site.
feefo is offline Find More Posts by feefo
Old Yesterday, 07:01 PM
Edhs is online now
Find More Posts by Edhs
Edhs's Avatar
the seventh planet
Joined Dec 2010
The BB sawtooth I also understand it considerably better than the 10x23GM. Not much more current one up to speed and similar performance. I would look around but that's what I read.
Edhs is online now Find More Posts by Edhs
Old Yesterday, 07:31 PM
G.P. is offline
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Tried sending voodoo a pm but his inbox is full.
I found that he was using the 12x25 sawtooth for f5d and switching to a 14.5x15 rfm for hotlines action. Also posted a screen shot of the sawtooth. Approx 140 amps max on 4s, but settled to around 100 amps.
Old Yesterday, 08:59 PM
Edhs is online now
Edhs's Avatar
the seventh planet
Joined Dec 2010
I'm just saying but I would just buy the edge130. Then you can run what ever you want!
10x23gm
12x25bb saw
14.5x14
Or even I suspect 16x17s. I think all the above on 5s!!!!
I've run my 1115-1.5d-5.2 on 5s with all but the saw and it's the same kv!
Old Yesterday, 09:03 PM
G.P. is offline
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
I like your thinking!!!
I'm gonna start with 4s though.
Old Yesterday, 09:33 PM
mustflynow2 is online now
Find More Posts by mustflynow2
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
GP I have some logs I think for 1110-1y but 6.7, 4s. Your kV, yes 5s. What rpm r u looking for at prop, ie speed? Will check my computer tonight
mustflynow2 is online now Find More Posts by mustflynow2
Old Yesterday, 10:26 PM
G.P. is offline
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
I'm just fooling around, so I am looking for something proven and reliable more than anything. I was hoping to stay with 4s if possible since everything that I have uses 4s or 8s. I have flown pylon planes in the 160 mph range, so anything in that ballpark would be nice. It's gotta sound gnarly too!
I usually fly a bunch of full throttle climbs and passes mixed with throttle off dives and passes to allow for some cooling. Not sure if that's f5d or hotliner style...at bit of a mix I guess.
I'm not in any rush to put my xplane together, and don't mind taking the time to save for the right equipment. Yuri built me a masterpiece and it deserves to be done right.
Old Yesterday, 11:10 PM
Edhs is online now
Edhs's Avatar
the seventh planet
Joined Dec 2010
I suspect even on 4s 16x17slim would not disappoint!
Old Today, 01:07 PM
anestetico is offline
Find More Posts by anestetico
Brazil, PA, Belém
Joined May 2009
Can you suggest a light setup with mid size prop? I mean no pylon but no 18" too, I want it easy to launch
What's the size of the package of the X-Plane?
Someone owns x-plane and Formula-HV too? what's the easiest to launch and the best for thermal soaring?
Thank you very much
anestetico is offline Find More Posts by anestetico
Old Today, 01:54 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
G.P.
If I remember right Jesse started with 4S and 15X16. Also made some videos.
http://www.rcgroups.com/forums/showt...53306&page=461
G.
GryphonRCU is offline Find More Posts by GryphonRCU
Last edited by GryphonRCU; Today at 01:59 PM. Reason: corrected the prop size and added link.
Old Today, 02:21 PM
Jezzejamez is online now
Find More Posts by Jezzejamez
Jezzejamez's Avatar
United States, MI, Commerce Charter Township
Joined Oct 2013
Yup, 15x16 RFM is a good start...
Yuri's X-PLANE:
Yuri's X-PLANE (9 min 4 sec)
Jezzejamez is online now Find More Posts by Jezzejamez
Old Today, 02:43 PM
savneo is offline
Find More Posts by savneo
savneo's Avatar
Cyprus
Joined Mar 2012
Thank you very much
Not an x plane but avionik f5d with a mega 16 F5D motor KPG 4.2:1 and 1500mah 6s turning a gm 11x22. It's very light ( under 1kg) it glides quite well with a camber mix It will also knock on the door of 180mph easy if you want. 3/4 throttle on launch hard throw and it's away without roll.
This for me ticks alot of boxes.
savneo is offline Find More Posts by savneo
Old Today, 06:36 PM
XtremeWingRC is online now
Find More Posts by XtremeWingRC
Fast? I got something 4 ya!
XtremeWingRC's Avatar
United States, WI, Oak Creek
Joined Oct 2007
I have a 15x16s if you want to start with that. PM if interested.
On 4S the 16x17s is a beast for sure
XtremeWingRC is online now Find More Posts by XtremeWingRC
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13233 May 26, 2015 11:55 AM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
