Old Oct 20, 2013, 05:00 PM
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Question
Hangar 9 60cc Corsair conversion
Has anyone seen any info/builds/reviews on a conversion of the latest Corsair from Hangar 9 (60cc size)
http://www.hangar-9.com/Products/Def...ProdID=HAN4760
from glow/gas to electric?
I am really trying to avoid going back to glow/gas but something tells me this plane, as built, might just be "a bridge too far"
I love the plane, but it just seems like the the Evolution77cc glow 4 cycle radial engine is the 'correct' choice.
Am I just throwing in the towel too easily?
ltc is offline Find More Posts by ltc
Old Oct 21, 2013, 01:16 AM
Tulsa Int, Oklahoma, United States
Joined Oct 2003
Yep, you sure are. I had a friend who put a Tacon Big Foot 110 on one (10s) with a 4 blade prop (close to scale, but just a little small). It was fast and quiet, flew around the 100mph mark.
He failed to properly strengthen the wing and it suffered a most spectacular crash.
wildnloose is offline Find More Posts by wildnloose
Old Oct 21, 2013, 08:53 AM
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
wildnloose - think you must be mistaken, there's no way in the world that a $50, 2000W motor on 10S is going to be anywhere near enough power for that model. Are you sure it wasn't the Hangar 9 .60 sized Corsair that your friend had?
GordonTarling is offline Find More Posts by GordonTarling
Old Oct 21, 2013, 11:04 AM
randynsaudi's Avatar
United States, LA, Blanchard
Joined Jan 2006
My 2 cents
go with the rimfire 65cc on 12 cells 160 amp CC ESC and 10 Amp BEC..make your battery doors in the cowl keep the weight up front and easyier battery change out..
randynsaudi is online now Find More Posts by randynsaudi
Old Oct 21, 2013, 03:48 PM
Joined Oct 2003
Oops, I meant a .60 sized. Corsair. My bad.
Old Oct 21, 2013, 04:09 PM
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
I've seen the CARF Corsair conversion with the batteries located as you described.
Need to try and look at one of these to see how much room is in the cowl and how conversion friendly it is.
Old Oct 21, 2013, 05:42 PM
Joined Jan 2006
make a hatch on the bottom of the cowl.. and cut a slot in the firewall below the motor box and make a sliding tray for the batterys. i would also install a anti-spark arming plug.. the batterys would slip in about 3/4 of way thru the firewall
Old Oct 22, 2013, 12:46 PM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
I have a Suppo 7035-9 (190kv). I used a 23/10 prop, on 12s, 110hv CC esc.
Wattmeter showed 99a @ 4200watts. IMO, that would be plenty to fly a 31 lb warbird. I currently have the motor set up with a 21/10/ 3 blade PMT CF prop. I expect about 3500watts ( estimated).
Motor is supposed to handle 120a, 6000w. I believe it will make the numbers, at 99a is was barely warm. Motor weighs 3lbs same as a DA50 without muffler, offset by the battery weight far forward in the Corsair, it should work with a 23/12/3bl or a 22/12/4 blade prop. JMO FWIW Doug B
Doug Bartley is online now Find More Posts by Doug Bartley
Old Nov 04, 2013, 11:03 PM
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Friend of mine has this 60cc corsair and is using the rimfire 65cc on 12s.
He's got it setup with one 6s battery forward of the firewall and the other where the stock fuel tank would sit.
Ive done several giant scale conversions using the 65cc rimfire. Way more then enough power to fly this plane.
I myself would have probably done something different for battery placement, but without the planeto mess with, I cant say really what id end up doing.
Here's a couple pics of my friends setup.
kahloq is offline Find More Posts by kahloq
Old Nov 05, 2013, 03:23 PM
stamper's Avatar
Bartlett, IL
Joined Jun 2002
Did he make a battery hatch or does he remove the wing before and after each flight?
stamper is offline Find More Posts by stamper
Old Nov 05, 2013, 04:28 PM
kahloq's Avatar
Joined Dec 2005
I don't think hes made a hatch yet.
Old Nov 29, 2013, 03:14 PM
Volt-action...
monjo's Avatar
United States, MO, St Louis
Joined Apr 2005
Any updates/pictures on a conversion... I'd have bought this already if it were just electric friendly.
monjo is online now Find More Posts by monjo
Old Nov 29, 2013, 03:39 PM
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
I am still puzzled about the designers' comments saying it was an intentional decision to not attempt to design in any electric friendly capability/options since it is too large a plane....
I guess they haven't seen the larger motors from Hacker, Rotomax/Turnigy, even the Rimfire...
Old Dec 09, 2013, 08:56 AM
whiirrrrrr
srt8madness's Avatar
United States, TX, Houston
Joined Nov 2011
Notice none of those motors you mentioned are sold under the Horizon empire? I think that will answer your question as to why.
srt8madness is online now Find More Posts by srt8madness
Old Dec 11, 2013, 07:34 PM
USA, VA, Alexandria
Horizon has a relatively new power 360 motor which should fly the plane.
lrb75 is online now Find More Posts by lrb75
Discussion Hangar 9 60cc Corsair barracudahockey Fuel Warbirds 118 May 13, 2014 12:19 PM
New Product Hangar 9 F4U-1D Corsair 60cc ARF Mikemynameis Electric Warbirds 20 Aug 06, 2013 12:40 PM
News Joe Nall News - Hangar 9 F4U-1D Corsair 60cc Jim T. Graham Scale Fuel Planes 15 May 30, 2013 08:33 PM
Wanted air retracts for Hangar 9 Corsair and Hangar 9 Miss America P51 fnlrun Aircraft - General - Miscellaneous (FS/W) 2 Mar 16, 2010 09:46 PM
For Sale Hangar 9 F4U Corsair and Hangar 9 P-40 RTF jetmex Aircraft - Fuel - Airplanes (FS/W) 0 Jan 13, 2007 02:11 PM
