Old Mar 16, 2014, 03:43 AM
KBIO's Avatar
France, Bretagne, Dinan
Joined Jan 2012
Z drive on 360°
MANAGEMENT OF PODS , Z-DRIVE or SCHOTTEL ON 360°
SEAPOD The realistic pod, z-drive or Schottel control for scaled models
· Pre-wired, no connection mistakes
· Uses the electronic of the remote control
· Can be steered with two fingers
· Only one stick to control everything: thrust/rotation
· Suitable for every types of remote control (exept pistols
· Suitable for every types of motors : brushed/brushless
· Suitable for every variators/controllers
· Initialize automatically when the remote control starts: stop engine, steering at 0°
· The pod steers exactly at the speed ordered by the remote control
· The pod reacts exactly to the degree, according to the stick orientation
· 360 degree rotation any direction, as many times as ordered
· Fine tuning of the throttle without releasing the stick
· The thrust reduces automatically at 90° and at 270°
· The pod stays at the last order information given while waiting for a new order
· Minimum volume: 5cm*5cm (1.97 in*1.97 in)
· Warranty by replacement based on the date engraved on the case
· Price clearly under the competition
· This system is equipped with a BEC crossing(spending) 1,5 Ampère
He(It) is totally tight in the dust and in the water
Amateur video of the prototype
SEAPOD : Orientation d'un pod de navigation sur 360° (0 min 38 sec)
The complete assy is delivered with detailed plans and instructions in English
Please feel free to ask questions on this forum.
KBIO is offline Find More Posts by KBIO
Old Mar 16, 2014, 07:51 AM
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Nice!!!
Jerome Morris is offline Find More Posts by Jerome Morris
Old Mar 16, 2014, 11:17 AM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
It is ok to advertise here (with some limits: http://www.rcgroups.com/forums/wlist.php?do=post )
Maybe you can post your contact information, price, ordering, photos of the unit, etc.?
Is it possible to connect two units in parallel, for common control from one stick?
patmat2350 is offline Find More Posts by patmat2350
Old Mar 16, 2014, 11:59 AM
Joined Nov 2012
Thank you Patmat2350 for the information
It is not for sale at the moment later maybe if somebody asks for it.
It is in the point technically. It works perfectly but we have to make tests with users. It is more serious
You can put two modules on the same joy-stick ( Y )
Either if you have a programmable radio, you can couple, or not, pods
It's perfect for the laborer of tugs
GAZOU is offline Find More Posts by GAZOU
Old Mar 16, 2014, 01:06 PM
---o-O-o---
blutoh's Avatar
United States, NJ, Livingston
Joined Mar 2012
Very nice,
What type material are the pods made of?
It appears in the video that the control stick has been modified. Is that an add on piece, or does it require a specific radio?
What's the availability?
blutoh is offline Find More Posts by blutoh
Old Mar 16, 2014, 02:55 PM
Joined Nov 2012
Pods is pods GRAUPNER but any pod is possible.
Handles are slightly modified
Any radio 6 ways suits even one bottom of the range, any frequency.
It will be available after the tests by designers, in June, 2014
You will be warned( prevented) in the comment planned for the sellers as advises(recommends) it Patmar
Old Mar 16, 2014, 03:34 PM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
While I can not make it to Gazouland for the sea trials, I would love to see additional
video of the drive holding position in relation to the joystick, and also ESC proportion
compared to position of the joystick. It would also be nice to see the electronic board
size, and connections.
Looking forward to seeing more from Gazouland event at the end of the month.
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Mar 20, 2014, 11:17 AM
Joined Nov 2012
Manche de commande SEAPOD - V1 (0 min 13 sec)
Old Mar 20, 2014, 05:23 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Interesting, Now I am wondering how that might work with, say a DX6 spektrum radio...
Old Mar 21, 2014, 02:33 AM
Joined Nov 2012
It works with ALL the radios
Old Mar 28, 2014, 08:57 AM
Joined Nov 2012
Hello
Here is a photo of the module SEAPOD
The green led indicates the switched on, the red led indicates a low battery.
We had some comments
we bring some wanted régulations
It is the ideal system to command tug boats ASD or SDM
Old Mar 28, 2014, 12:02 PM
---o-O-o---
blutoh's Avatar
Joined Mar 2012
Hi Gazou,
Have you established a price for the SEAPOD yet?
Are the Graupner Z-DRIVES still available, given their financial problems?
Is anyone other than Graupner making Z-DRIVE units?
If I remember correctly, I think Phoneman2005 was working on manufacturing some Z-drives, but I haven't heard or seen anything on that in a while.
Old Mar 28, 2014, 12:06 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Bauer-Modelle.de is marketing schottel drives.
http://www.bauer-modelle.de/modules/..._id=151&page=2
_____________________________________________
I typically use both vertical channels as throttles.
One for each drive.
How does this work for dual throttles and steering.
Old Mar 29, 2014, 07:04 AM
Joined Nov 2012
Hello
Yes naturally if you have two pods are needed two systems
You can use any mark of pod, either pods which you make you even
Z-DRIVE on my EDDA FONN, is FABRICE, a friend, who made the Z-DRIVE
Principle of installation.
You can put the engine of position under platinum
Take away the engine of position and put a belt
Or put the engine horizontally and put cogs of angle. Inconvenience cogs (brass or plastic(plastic art)) make of the noise
Old Mar 29, 2014, 04:33 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
I suppose to simplify my question, How does this work with four channels or two joysticks?
There are three to six plugs when using one to two units.
How are they arranged in regards to two joysticks?
Sold Xbox 360S 320GB Hard Drive (PRICE DROPPED) Phil McCrackin Non R/C Items (FS/W) 0 Mar 09, 2014 07:51 PM
Discussion UPDATE: Z-Drives & Voith-Schneider Units capntroy Scale Boats 16 Feb 02, 2014 04:58 AM
Discussion 360 video cam on brushless gimbal on helmet? amirb Aerial Photography 0 Sep 26, 2013 08:47 PM
Discussion Silverlit 5 channel Z-Bruce (like Z-Century / AH Helix 360) aracer Micro Helis 16 Dec 27, 2010 10:27 PM
