Old Mar 03, 2015, 07:45 PM
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
Just emailed jaebeex2 my favorite ebay seller for the V120D02S parts:
I have you as a favorite seller, thanks for your great stock of parts for the V120D02S. But have a question. What is your opinion for in the future still being able to get stock parts from Walkera or who ever you get them from for the V120D02S?
Crash Survivor is offline Find More Posts by Crash Survivor
Old Yesterday, 08:42 AM
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
I noticed some discussion on the brain Fylbarless controller.
I have one on a 500 and it is an excellent unit. I would beware of the bail out feature. there has been a lot of discussion and testing on HeliFreak that is does not always work as expected. I have my disabled.
I had a bad experience testing an A3Super by Eagle on a supercub airplne. It worked ok the first several times I turned it on, but the lasttime in level flight, it pinned all the control surfaces one way causing the plane to become totally uncontrollable. I hit the switch to disable the feature, but it never seemed to allow TX control to take over resulting in a total writeoff of the plane.
BThirsk is offline Find More Posts by BThirsk
Old Yesterday, 02:48 PM
Tucson, Az
Joined Feb 2007
Since I have bad servo in my V120 and want a few back up items ordered from C/J. Gear set for rebuild seems way to tight and will revisit that ladder. No biggie but real lucky so far and pay for my Stupids. I have downsized a considerable amout as bigger is better. Springtime here is awesome. My goal is to field four 450's by mid spring. By summer have Blade 500D flying.
V120 is just a nice heli for me and still fly micros, but much reduced level.
I will not forget my micros and should get a few more years out of them no matter what makers do. Some are now bl and know what makes them tick. A Few will go into skunk works and will smoke much of whats out there now, but point is moot. When you think small you fly small. Happy landings/
dankar04 is online now Find More Posts by dankar04
Old Yesterday, 08:06 PM
Heli Crash Survivor
Joined Feb 2011
Reply from my favorite Ebay seller jaebeex2.
Good morning, thank you very much for the business, greatly appreciated!
I would say the V120D02S parts will be available to get from Walkera for several years.
There are several parts I am sold out of and have not restocked but not due to unavailability from Walkera, I have just not restocked.
If you are worried about being able to get parts for it they will be available for years to come.
As you know this stuff is always changing and new models always coming out so they won't be around forever but Walkera will still take orders for parts on models that came out 5 years ago it is just that I have not restocked.
Old Yesterday, 08:58 PM
Joined Jan 2012
As FYI, I've posted one of my new V120D02S BNF's in the classified section:
http://www.rcgroups.com/forums/showthread.php?t=2361743
OrbitalGolem is offline Find More Posts by OrbitalGolem
Old Yesterday, 09:08 PM
microrcfiend's Avatar
United Kingdom, England, Sheffield
Joined Jun 2012
Isn't that more than a brand new one? What I miss?
http://www.hobbyking.com/store/__342...pter_BNF_.html
Awesome to hear continued availability, I got a a year at least to figure out if I like and stock up. Pretty sure I can keep my mini cpbl running till the board fails
microrcfiend is online now Find More Posts by microrcfiend
Old Yesterday, 10:57 PM
Tucson, Az
Joined Feb 2007
I don't think there is shortage of parts. I think vendors just want to sell off stock they have. Quads are hot ticket now. Vendors may not want to invest in heli parts. Plus Walkera has nothing to say about anything makes it even worse.
I have asked HH about some items and no reply. Same with JR America or get a non answer. If you have a certain bird you like and worried if parts will be around it could not hurt to get some spares. You need not go crazy but gears/ drive shafts etc.
Old Today, 03:14 AM
jamichx's Avatar
Slovakia
Joined Sep 2013
it has 3 axis gyro (is this brand new one ?) and another two batteries. Bit overpriced I think. Maybe I missed something else ? Why was the gyro replaced ?
jamichx is online now Find More Posts by jamichx
Old Today, 06:39 AM
Joined Jun 2012
Ah, I forgot the newer one was 6 axis.
My first was 3 axis and the board just leaned left, even when swash was pushed as far right as it would physically go. Board returned but rc711, they test and admitted it was wonky but never gave me another. Got a refund of $25, shame it cost me £40 for a 6 axis board from the UK to replace it.
Old Today, 09:12 AM
Joined Aug 2014
Originally Posted by dankar04 View Post
I used new gear set from CJ on V120D02s. Elevator servo and its close but different from original. Spline and part that exits for arm is longer. Checked and rechecked and gears are very tight. Other servo arms move smooth and easy. so either I have set thats a tad different or ?? changed main big gear set and top one on other post. Gears line up lubed them with white PTFE gease and no help.
I can not see this working being this tight. Heli was bought last summer.
I have noticed the same thing , replacement gears are way too tight. Only replace the broken gears, keep as many of the WK gears as possible, those are much better.
The output spline shaft is longer, but it works. I alos found that lubrication is not the issue.
sp.nn is offline Find More Posts by sp.nn
Old Today, 11:31 AM
jamichx's Avatar
Slovakia
Joined Sep 2013
Yes those replacement gears are not as good as original WK ones. I had the same problem when I replaced gears. Just too tight but at the end it did work ok. Its a shame you cant buy original ones.
Old Today, 11:36 AM
Joined Jan 2012
I've used the Airy replacement gears from Terrance for years and while they might be tighter in some cases (but not all), they're much more resistant to stripping than the originals. That makes them better. Also, if/when you move to a 180 CFX, the output spline is identical to the original.
Old Today, 11:50 AM
jamichx's Avatar
Slovakia
Joined Sep 2013
Hi, are these parts all compatible for v120d02s ?
http://www.modelhobby.sk/index.php?r...roduct_id=5185
http://www.modelhobby.sk/modely-vrtu...stovej-vrtulky
http://www.modelhobby.sk/modely-vrtu.../sada-lozisk_2
its v120d02s compatibility with 4*6 S , 4G6, v120d02 ?
thanks
Discussion new heli from walkera HIKO400? xyzy2 Micro Helis 15 Jan 12, 2012 12:16 PM
Sold Align 70A ESC W/BEC from 500/550 class Heli NEW! HD Hucker Aircraft - Electric - Helis (FS/W) 3 Oct 13, 2011 01:37 PM
Discussion Ultra Durable Diamond Mini Gyro 3 Channel Indoor Ready to Fly RC Remote Control Heli LittleG Coaxial Helicopters 32 Jan 14, 2011 01:55 PM
Discussion Walker 4#3 throttle problem Ė new heli Ronon Micro Helis 2 Jan 24, 2009 05:22 PM
