Old Nov 26, 2014, 01:16 PM
United States, NJ
Joined Oct 2011
Thrust Vector Mixing on DX8
I'm having trouble setting up thrust vector mixing. It is for a ELV>AUX2 mix.
The trust vector servo is on AUX2 and Controlled by the Aileron DR Switch. Position 0 is off and 1 is on. The mixing rates are 100/100 and the offset is at 50 otherwise I can not get the servo to get Maximum deflection in both directions.
Currently when the mix is on (position 1) it works perfectly. When I Switch it off (position 0) instead of returning to neutral the Servo deflects to its Maximum Forward position.
Any ideas as to why this is happening. I'm stumped
Pjuran is online now Find More Posts by Pjuran
Old Nov 26, 2014, 11:04 PM
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
Go to the Switch Select menu in the System Setup. Change the AUX2 to Inh. Channel 7 (or AUX2 as it is called) is automatically assigned the 3 way toggle on the right hand side of the radio.
Then go back to your mix and change the offset back to 0 and your rate to either 100% or -100% or less based on direction and how much mix you want.
swps is offline Find More Posts by swps
Alert ALL e RC - Super Deal on HYPERION ENIGMA 15E VECTOR THRUST 3D ARF Close-outs! PittSpecial Hot Online Deals 100 Nov 24, 2014 07:04 AM
Question Futaba 8FG mixes for F16 thrust vectoring blakevan Foamy EDFs 0 Nov 12, 2014 07:57 PM
Discussion Graupner MZ-24 Program Mixing Thrust Vectoring starcop Electric Ducted Fan Jet Talk 6 Jul 20, 2014 12:32 PM
Question Spektrum DX6i Thrust Vectoring Mixing? RG916170 Radios 2 May 24, 2014 08:04 PM
Question Mixing in Vectored Thrust to Rudder Sixinarow Radios 9 Jan 07, 2013 09:22 PM
