Old Jun 13, 2014, 06:26 AM
United Kingdom, England, Birmingham
Joined Oct 2012
Question
Cutting a battery hatch in a carbon fibre fuselage
Hi, I have a glider that I want to convert to electric launch. Radio access is via hole under the wing, but I would like to add a hatch to access the lipo to avoid the need to untape the wings between flights. Being an utter noob to carbon mangling, does anyone have any (sensible) suggestions for what sort of dremel cutter to use to make a neat opening and still hopefully be able to use the removed bit as a basis for the hatch?
hobgoblin is offline Find More Posts by hobgoblin
Old Jun 13, 2014, 08:32 AM
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Carbon is a little tougher to cut than fiberglass. I apply masking tape and draw the outline. Then carefully take a #11 Xacto blade and make many multiple cuts. A Dremel tool could be used but I would want a very thin cutting wheel and a very steady hand.
After it is cutout then you can make a lip for it to sit on. See here how I accomplished this: http://www.rcgroups.com/forums/showt...8#post21194889
Best of luck.
Curtis Suter is offline Find More Posts by Curtis Suter
Old Jun 13, 2014, 09:20 AM
Michigan's Upper Peninsula
Joined Sep 2007
Solid advice from Curtis.
My carbon cutting has been limited to smaller pieces but I've cut lots of glass.
If you do decide to use a Dremel, get the thinnest cut-off discs you can find. Also, take the time and apply an extra layer of tape beyond where you intend to cut. This isn't bullet proof but adds a little thin armor in case you have a minor slip. I have some experience on this (grin).
Cut well inside your desired opening. When the opening is roughed in, use some of those fine grit drums to "sneak up" to your finished line. You can dress up the edges with fine sanding sticks.
Take the time to look at the link Curtis posted. A nice approach.
One last thought...cut-off wheels are hard but brittle. Make sure you have good eye protection. I've only had one come apart on me, but it does happen. Oh...and be careful with that beautiful carbon!
Dave
Highride is offline Find More Posts by Highride
Old Jun 13, 2014, 09:40 AM
Joined Oct 2012
Hi Curtis and Dave,
thanks for the knife advice, the Supra thread is particularly useful! I had not thought of making a lip before seeing this.
I will give the patient knife approach a go first, seems much safer, I have some carbon sheet to practice on, and I've seen a cutting wheel let go in the past, so I am goggled and masked up before I use these.
thanks
Jon
Discussion Kevlar fibre vs flax fibre in fuselage robertboxhoorn Hand Launch 5 May 19, 2014 06:37 AM
Sold Blade 350 QX Hydro-dipped Carbon Fiber Effect Battery Hatch flyinjrc74 Aircraft - Electric - Multirotor (FS/W) 2 Apr 10, 2014 05:33 AM
Discussion Cutting Carbon Fibre tubing John Webb The Builders Workshop 8 Dec 06, 2006 04:56 PM
Carbon Fibre for fuselage?? Airwolfie Micro Helis 2 Feb 15, 2005 12:37 PM
Better Aerial for Carbon Fibre fuselage? Red Baron Sailplane Talk 2 Jul 15, 2004 02:26 PM
