Old Feb 12, 2015, 01:35 PM
"Rocket Scientist"
crosstrim's Avatar
United States, AZ, Mesa
Joined Feb 2008
Prop Mod
Nice Job! Looks like OEM.
Any tips on technique? Like what grit & speed.
crosstrim is offline Find More Posts by crosstrim
Latest blog entry: Mounting the Motor (part two)
Old Feb 12, 2015, 08:52 PM
aka: Scott Ellis
Xeric's Avatar
United States, MT, Billings
Joined Dec 2012
Originally Posted by Capt. Gary View Post
kinda like this....
Exactly!
Xeric is online now Find More Posts by Xeric
Old Feb 13, 2015, 09:33 AM
Joined Nov 2010
Naturally in a world of litigation and overpopulated by people that are apparently too stupid to live, sorry Darwin really was right, I personally would “never” recommend anyone modifying a prop but I hear that a chain saw file or two, along with a fair pile of jewelers files, a router table and or Dremel tool running a straight stone bit at low speed, accompanied by a fair pile of various abrasive papers on wooden dowels would achieve said desired effect. Rumor also has it that this takes a fair bit of time and it has been advised to proceed slowly and with caution. Furthermore it has been advised to gently "break" or round over any and all sharp edges to avoid the occurrence of stress risers. Weighing and balancing also seem to be de rigueur.
Capt. Gary is offline Find More Posts by Capt. Gary
Old Feb 13, 2015, 09:45 AM
Theoretical balsa dust maker
plane_tech's Avatar
United States, MI, Kalamazoo
Joined Oct 2007
Ok, that was perfectly written.
plane_tech is online now Find More Posts by plane_tech
Old Feb 13, 2015, 04:41 PM
"Rocket Scientist"
crosstrim's Avatar
Joined Feb 2008
My Lips Are Sealed
"Loose Lips Sink Ships"
Or was it "She sells seashells...."
Anyway, Thanks.
ct
Old Feb 17, 2015, 02:31 PM
Old Prop Buster
Sir Dumb Thumb's Avatar
United States, CA, Grass Valley
Joined Dec 2009
Greetings All:
I am progressing well learning the fine points of my new Odyssey 2.7 electric . I now have the sailplane programming going on my DX8 with the flaps on the throttle stick, thanks for your help Soren. This being my first full house glider and with a high aspect wing too boot it seems like my landing speed is too high. My flaps have good throw and I have tried crow and no crow. I have not tried flaperons with my ailerons making 2 big flaps. I am little chicken to try this as with crow, my ability to keep the wings level diminishes greatly. Would it work well if I put about 50% down on each aileron and then I would have some travel left to roll correct on landings? Or is just a fast landing plane and get used to it. I am just using this for thermal flying and not slope so the faster drop that crow gives me I really don't need or my crow is not setup right as my nose seems to drop when crow is engaged. What I really what is a slower landing speed, but if I can't get it I will just deal with it.
Thanks in advance Gary
Sir Dumb Thumb is online now Find More Posts by Sir Dumb Thumb
Old Feb 17, 2015, 03:28 PM
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Originally Posted by Sir Dumb Thumb View Post
Greetings All:
Dont put the ailerons Down, this will give you tiptall and much much less aileron control and perhaps adverse yaw
Put them up with flaps Down, but not more than when using the ailerons the aileron going Down must go Down to neutral, then you still have plenty of aileron control
If you just want slower landingspeed without the fast sink that crow give you then just use normal flaps without the ailerons up.
I was flying my 2,2 m Foka last weekend with this set up, and it could still make a roll with full crowbrake
And set the flap to elev mix, so when using the flaps-crow then it fly the same flight path without droping or lifting the nose.
Mine is set
high 0%
75-16%
50-18%
25- 28%
low34%
But not sure that you just can use the same setings as mine on yours,
Adjust it so that it start to give Down when the flaps start moving.
I have 4 mm Down at full crow.
I would say its a slow landing plane
Odessey moments (1 min 28 sec)
Good luck
SpeedsterDEN is online now Find More Posts by SpeedsterDEN
Old Feb 24, 2015, 11:04 AM
Kingdom of Norway, Hedmark, Stange
Joined Aug 2014
Indeed, using crow the Odyssey lands at almost walking speed.
Dynabel is online now Find More Posts by Dynabel
Discussion WINDBURNER Pilot's Thread Kevin Bennett Dynamic Soaring 600 Jan 31, 2015 05:06 AM
News Windburner Pilots' Thread Terry Sailplane Talk 0 Mar 04, 2013 10:02 AM
Discussion Arthobby Timon - Build Thread (Finished and Flown) PedroCR Slope 59 Sep 06, 2009 03:50 PM
Help! ARRG! - Where is ArtHobby Thermic build thread? rwmson Thermal 4 Dec 29, 2004 12:57 AM
