Old Aug 15, 2014, 08:19 AM
Canton Township, Michigan
Joined Sep 2005
Question
Receiver Antenna Position
I am switching all my boats to Fly Sky 2.4 systems. Does the position of the antenna matter? Vertical...horizontal?
ajferkovich is offline Find More Posts by ajferkovich
Old Aug 15, 2014, 08:44 AM
Joined Jan 2013
It all depends on the pond your boating in, keep it near the deck above water line.
Old Wood Boats is offline Find More Posts by Old Wood Boats
Old Aug 15, 2014, 08:46 AM
Kamloops BC Can.
If your transmitter antenna is vertical, then your receiver antenna should be vertical for best signal transfer.
Olscuzbut is offline Find More Posts by Olscuzbut
Old Aug 16, 2014, 04:29 AM
Blackpool, Lancs
Joined Feb 2006
Rule of thumb, vertical and as high as possible, just like any other radio. While a horizontal aerial might show some signs of polarization (reduced signal, depending on which way the boat is facing), as long as there is nothing to absorb the signal between your transmitter and the RX aerial, there should be no problems.
mfr02 is offline Find More Posts by mfr02
For Sale Pro Antenna Tracker with Servos, 900MHz Receivers & Antennas tkeeg FPV Equipment (FS/W) 0 Aug 14, 2014 05:23 PM
Discussion Easy! Replace/Repair 2.4Ghz receiver antenna with PS3 wifi antenna acid8x Off-road Cars 1 May 21, 2014 11:50 AM
Sold 5.8 RC305 Receiver + Patch Antenna + 2 CP Antennas Jonesy Flier FPV Equipment (FS/W) 1 Jan 24, 2014 02:53 PM
Sold FrSky 8CH Receiver V8FR-II 3 of them and 2 antenna hurleycycle Aircraft - General - Radio Equipment (FS/W) 3 Oct 04, 2013 10:01 PM
Wanted Chainlink Dare receiver and antennas BadBert Aircraft - General - Radio Equipment (FS/W) 0 Sep 30, 2013 02:45 AM
