Old Jun 18, 2015, 11:08 PM
scigs30 is offline
Find More Posts by scigs30
Joined May 2005
Build Log
Guillows Laser Cut P-47
Here is my Guillows Laser Cut P-47 prototype, went together well with high quality balsa. Using white glue the she went together in 2 days then sat until today when I started covering. Built per the plans and will be freeflight with rubber. Only modifications is the nose block and increased dihedral. No paint used all tissue from Guillows except Green and Black from Peck.
scigs30 is offline Find More Posts by scigs30
Old Jun 23, 2015, 04:23 AM
bshultz327 is offline
Find More Posts by bshultz327
Branjo
Joined Sep 2013
Nice, glad to finally see this one from Guillows. Looks awesome,
Branden
bshultz327 is offline Find More Posts by bshultz327
Old Jun 24, 2015, 01:22 PM
scigs30 is offline
Joined May 2005
I was able to finish my P-47 today and she is ready for rubber flight. I made a small modification to the nose to allow for a removable nose block, nothing fancy just keep it simple. I glued the cowl to the balsa blocks so if she does not fly with rubber I can rip off the cowl and add electrictonics. All the landing gear parts are removable for flight but could be left in. The prop is too small so I will be adding another. The weight without landing gear is 90 grams and will need nose clay. I did increase the dihedral so the wing fairings had to be shaved but otherwise they fit well. The canopy was moved forward for a better fit, could not get it sit right placed as shown on the plans. Once again I used domestic tissue for everything including the red cowl, only painted the black tail wheel and black inside cowl. The HV decal on the right side will be removed and the correct orientation will be placed once I order a new decal or make one. Covering was simple, first where you see the white tissue was placed first with glue stick reinforced with 50/50 white glue. Then the grey was added followed by the black, green and red. The trim was applied with glue stick and shrunk with alcohol. Once again a great laser cut kit from Guillows, I would say the best balsa kit for your buck. One can build a simple plane or add the details for RC or display. I think Guillows is doing a wonderful job of adding laser cut quality wood to their kits, the old die crunched oak was terrible. I am amazed that we were able to build and fly the old Guillows kits.
Old Jun 24, 2015, 09:39 PM
D-Rock is offline
Find More Posts by D-Rock
D-Rock's Avatar
Phoenix, AZ
Another winner Scigs30, always enjoy how well you build and finish your models!
D-Rock
D-Rock is offline Find More Posts by D-Rock
Old Jun 26, 2015, 07:07 PM
kevin matthews is offline
Find More Posts by kevin matthews
carbondale il
Joined Jan 2007
Nice job
kevin matthews is offline Find More Posts by kevin matthews
Old Jun 28, 2015, 09:24 PM
Dave K is offline
Find More Posts by Dave K
Dave K's Avatar
Sebastopol, Ca
Joined Jun 2004
Looks amazing. Looking forward to a flight report.
Dave K is offline Find More Posts by Dave K
Build Log Guillows Sopwith Snipe 18" - DPCModels Laser Cut Kit moscow580 Scale Kit/Scratch Built 12 Jun 29, 2015 08:35 AM
Build Log Guillows Laser Cut P47 Build scigs30 Free Flight 1 May 08, 2015 11:47 AM
Build Log Guillows Laser Cut BF109 500 series build scigs30 Free Flight 11 Jul 12, 2014 09:36 AM
For Sale Laser Cut Short Kit for the Meister Scale P-47 fockewulf37 Aircraft - Fuel - Airplanes (FS/W) 0 Jul 20, 2009 04:52 AM
For Sale Dumas P-47 Thunderbolt laser cut kit -- $35 PENGINEER1 Aircraft - Electric - Airplanes (FS/W) 1 Feb 20, 2009 08:22 PM
