Old May 31, 2015, 10:21 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Changesun / RCBLOG 64mm 12 blade EDF with QX-Motor QF2827-2300kv motor
I just balanced a pair of Changesun/ RCBLOG 60mm 12 blade EDF's with QX-motor QF2827-2300kv motors. They came with the stock SU-27 model discussed here
http://www.rcgroups.com/forums/showthread.php?t=2287508
Very happy with the results running 6S.
Here are the test results running a Gens Ace 6S 45C 5000mah battery
1700watts 77amps peak (total watts both fans)
settling to
1550watts 73amps
The motors stayed nice and cool never exceeding 110F
I listed "Changesun" but on the shroud it is marked RCBLOG. I'm assuming Changesunmakes it as the fan is identical to Changesuns 70mm 12 blade fan only smaller.
The ESC's were not in the airflow and reached 135F.
The rather thin motor wires felt fairly warm but I do think they will be fine on 6S (as a twin setup). Specs and temps would be a little higher if the fan was run as a single on 6S.
I'm impressed with the smoothness of these motors especially considering they are outrunners. QX-motor QF2827-2300kv
4stripes is offline Find More Posts by 4stripes
Old Jun 01, 2015, 01:39 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Sounds good!
Looking forward to a new video by Feda showing the improved sound in that Su-27....
anlucas is online now Find More Posts by anlucas
Sold freewing 64mm edf unit &motor dumbthumbbum Aircraft - Electric - Power Systems (FS/W) 2 Dec 13, 2014 06:16 AM
Sold 64mm 4s EDF esc/motor Freewing tdford Aircraft - Electric - Jets (FS/W) 2 Apr 09, 2014 04:34 PM
Sold Freewing Foam 64mm EDF F9F Panther Jet with Don's Wicked 64mm EDF & 4000KV motor $75 MickeyD Aircraft - Electric - Jets (FS/W) 1 Jun 24, 2013 02:01 PM
Sold Brand new never used 64mm Freewing 4S 3800kv motor with new Freewing Fan unit JGuilty13 Aircraft - Electric - Jets (FS/W) 3 Sep 14, 2012 05:22 PM
For Sale Freewing EDF 64mm with motor X2 OBO teha99 Aircraft - Electric - Power Systems (FS/W) 1 Oct 02, 2010 03:56 PM
