Old Jun 26, 2015, 09:57 AM
flybydanny is online now
Find More Posts by flybydanny
dannylooper
flybydanny's Avatar
United States, TX, Fort Worth
Joined Aug 2011
Ok let me try this again
I'm a total UHF NOOB and I'm looking for something I can use on my jr9503x will range link work just plugging into the trainer port on the back without having to mod the radio?
Anyone else using range link with jr 9503x?
All comments appreciated
Thanks in advance
flybydanny is online now Find More Posts by flybydanny
Old Jun 27, 2015, 12:51 PM
Recon RCPlanes is offline
Find More Posts by Recon RCPlanes
United States, TX, Arlington
Joined May 2014
Trinity Head Tracker and 2.1 Firmware
Has anybody got the trinity head tracker to work with the new firmware?
Was working fine until I loaded the 2.1 firmware.
I assume I need to do this through the JFPV program but I can't seem to get the tx to talk to the program.
I have Ground to Ground, TX to RX, and RX to TX from the USB2TTL to the TX - I push the read tab in the JFPV program and I get no communication between the two...
Any help would be appreciated.
Recon RCPlanes is offline Find More Posts by Recon RCPlanes
Old Jun 27, 2015, 08:09 PM
sid.huang is offline
Find More Posts by sid.huang
Chinglish-funny
Joined Mar 2011
After uploaded the v2.1 fw ,you need to rebind them.
1. connect the usb2ttl to tx;
2. make tx on high power mode and power on tx with hold down the tx button until the second beep,(i will take about 10s).
sid.huang is offline Find More Posts by sid.huang
Old Jun 27, 2015, 08:11 PM
Chinglish-funny
Joined Mar 2011
Thanks in advance
>>>YES, no need to mod the radio.
Old Jun 27, 2015, 09:23 PM
Joined May 2014
Thanks for the instructions, Sid! Got it to work!!!
Old Jun 27, 2015, 09:41 PM
Chinglish-funny
Joined Mar 2011
Thanks Sid! Both Tx and 12ch rx have the new 2.1 fw and have been bound.
I was able to go into the Tx and change channels 7&8 to tppm with your instructions.
But I still have no luck getting head tracker to work. Is there anything on the Rx side that needs to be changed? Do I leave it cppm or change it to none?
Maybe the tx lost the TPPM SIGNAL? poor connection?
try feed the head tracker ppm signal to RC PORT ppm signal input...if TX fast blink that shows the signal is good. and the n make sure the which channels is for (pan / tile / roll).
Sid
Old Jun 29, 2015, 04:16 AM
_Sibi_ is offline
Find More Posts by _Sibi_
_Sibi_'s Avatar
Joined Aug 2008
Sid could answer this?
Originally Posted by _Sibi_ View Post
I was reading the documentation for RL ver.2. There I have seen this comment:
PPM SIGNAL 1 (rc radio cppm channels) can be override by PPM SIGNAL 2(TPPM HEAD TRACKER INPUT) This setting can be ON/OFF by short press the tx button.
Does this mean that all TX/RX flashed on firmware V2 can pause the headtracker when short pressing the TX button?
_Sibi_ is offline Find More Posts by _Sibi_
Old Jun 29, 2015, 08:32 AM
Chinglish-funny
Joined Mar 2011
No, Not pause ,,,,will output all channels as PPM 1 input... if you want that feature, you can turn off the PPM 2(tppm) signal input.(like turn off head tracker power, or remove the cable .)
Old Jun 29, 2015, 11:32 PM
guaglione87 is offline
Find More Posts by guaglione87
KG5AWQ
guaglione87's Avatar
United States, TX, Mansfield
Joined Apr 2012
Can anyone point me to a working hex file for the 1.24 rx, or whatever came before 2.1? Need to roll back an rx to the version previous to the new 2.0 versions...
Thanks!
guaglione87 is offline Find More Posts by guaglione87
Old Jun 29, 2015, 11:41 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
http://www.rcgroups.com/forums/member.php?u=352541
Release 4
Daemon is offline Find More Posts by Daemon
Old Jun 29, 2015, 11:47 PM
KG5AWQ
Joined Apr 2012
Thanks Daemon - that is what i've tried (note its fw version 1.25 in that file - not 1.24). But in anycase when i go to check connection in the flashing program, i've verified that i can read the firmware (currently have 2.10 loaded). However, when i go to roll back to 1.25, i get a "no device found" message... stumped!
Old Jul 01, 2015, 09:59 PM
Chinglish-funny
Joined Mar 2011
>>click the send button 3times,;
Note: power off tx,and then power up the rx;
Old Jul 01, 2015, 10:22 PM
KG5AWQ
Joined Apr 2012
Thanks Sid - i got it to work by deleting the preceding file location to the hex file in the loading program
Old Jul 04, 2015, 09:20 PM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Hey folks,
Can someone tell me if the JR DSX9 is plug and play compatible with the RangeLink? I'm currently using my Spektrum DX8 but prefer the JR and want to use that instead.
Cheers,
TS.
Teamsherman is offline Find More Posts by Teamsherman
Yippee! DRAGON LINK - The Ultimate in PLANE and COPTER CONTROL, No Glitches, No lockouts... JettPilot FPV Equipment 40564 Today 05:40 AM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
