Old Oct 30, 2010, 04:23 PM
Rem 1973 is offline
Find More Posts by Rem 1973
Rem 1973's Avatar
Holland
Joined May 2006
Build Log
Depron Gee bee R3
Here is my scratch build of a Gee Bee R3.
I was just surfing the net, when i found a top and side view of the Gee bee R3.
I started drawing a bit in Rhino and made my plans as i go.
Version1 was wrecked in a crash by a radio signal dropout.
Version2 plans are up for grabs. Mine is upside down in the spray booth.
New plans involve 2 Deg. of main wing incedence and some touch-up on 3 parts.
Wing span will be 130cm (~51inch), lenght 100cm (~49inch)
I try to build as light as possible.
Used foil: sipkill.
650Watt on 4S motor.
Thanks for any help or suggestions in advance.
Greeting from holland.
Rem.
(Small video on the 10th page)
Rem 1973 is offline Find More Posts by Rem 1973
Old Oct 30, 2010, 04:30 PM
Rem 1973 is offline
Rem 1973's Avatar
Holland
Joined May 2006
some more pictures...
Old Oct 30, 2010, 06:48 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
This is looking quite beauiful. I love this plane. Sexy curves every where. I'll be reading this thread.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Oct 30, 2010, 07:48 PM
den bach is offline
Find More Posts by den bach
den bach
den bach's Avatar
USA, WA, Moses Lake
Joined Sep 2008
super job
what will be your paint scheme?
can't wait to see more
den bach is offline Find More Posts by den bach
Old Oct 31, 2010, 08:53 AM
Rem 1973 is offline
Rem 1973's Avatar
Holland
Joined May 2006
I'm not sure yet about the painting scheme.
The TEXACO scheme is widely used, but attractive for me.
Also the gilmore is one of my favorites.
Any suggestions?
Old Oct 31, 2010, 02:41 PM
den bach is offline
den bach
den bach's Avatar
USA, WA, Moses Lake
Joined Sep 2008
that gilmore is nice
I like that tail wheel skirt
Old Nov 06, 2010, 04:17 PM
Rem 1973 is offline
Rem 1973's Avatar
Holland
Joined May 2006
I have been abroad for a week working.
So no big progress.
Here it is so far.
Servo's mounted and pushrods installed,
Wings joined,
Wheelpants put together and shaped. Including strengthning cables.
mounted 1 wheel.
Greetings,
Remco.
Old Nov 07, 2010, 02:33 PM
Rem 1973 is offline
Rem 1973's Avatar
Holland
Joined May 2006
Also made a start on the internaly hinged ailerons.
Question:
Is it possible to use these ailerons also as flaps, each side powered by a seperate servo?
maybe some mixing on 2 channels?
Greetings,
Rem.
Old Nov 07, 2010, 08:11 PM
DaDesign is offline
Find More Posts by DaDesign
ɹǝsn pǝɹǝʇsıƃǝɹ - inverted!
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
On my Spektrum DX7 I can use "Flaperon's" which let's you mix flaps with ailerons.
DaDesign is offline Find More Posts by DaDesign
Old Nov 08, 2010, 04:21 AM
guillaumeux is offline
Find More Posts by guillaumeux
Joined Apr 2007
Very nice job !!!
Plans for a 60 cm wingspan ?
guillaumeux is offline Find More Posts by guillaumeux
Old Nov 08, 2010, 03:15 PM
Rem 1973 is offline
Rem 1973's Avatar
Holland
Joined May 2006
Thank you, DaDesign..
Found the same type of mix here on my JR DSX9.
Sorry guillaumeux..
At first i will try to see this plane in the air.
After that we will see...
Both internal hinges made, and figuring out a way to move the surfaces invisible. And yet still accessible when i take off the wing.
Greets,
Rem.
Old Nov 08, 2010, 03:20 PM
3Dmuse is offline
Find More Posts by 3Dmuse
Ontario, Canada
Joined Sep 2009
Well done so far. How did you cut the foam so nicely?
3Dmuse is offline Find More Posts by 3Dmuse
Old Nov 08, 2010, 03:52 PM
rcflyer50 is offline
Find More Posts by rcflyer50
USA, Massachusetts
rcflyer50's Avatar
Joined Dec 2005
I would love to see that put into plans. Although it is a might on the intense side of building for me. A beautiful plane none the less
rcflyer50 is offline Find More Posts by rcflyer50
Old Nov 08, 2010, 05:13 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
I would definitely like to see plans of that
and My style of building too
RogueTitan is offline Find More Posts by RogueTitan
Old Nov 09, 2010, 02:57 PM
Rem 1973 is offline
Rem 1973's Avatar
Holland
Joined May 2006
Barzaun..
I guess you know you have to use sharp blades to cut foam.
So far i used 3 chirurgical blades on cutting the foam. (nice to have a nurse in the family)
For cutting straight, use a ruller, or something straight.
For cutting nice holes i use a "holpijp" and a circle cutter, dont know the translation, but you can see in the pickture.
Plans wil be worked on some later.
Here is what i have sofar.. but there is no former count or numbering yet.
Problem is that i have the abillity to print on a A0 size plotter.
So i don't need to tile my plans.
Greetings,
Rem.
Last edited by Rem 1973; Nov 10, 2010 at 11:53 AM. Reason: Plans wil be posted later.
Discussion ***OFFICIAL*** Gee Bee R3 Build Thread appflyer Scale ARF/RTF 28 Dec 04, 2009 11:57 PM
Discussion Best Brushless RC Motor parts for GEE BEE R3 appflyer Electric Plane Talk 12 Aug 28, 2009 03:40 AM
Discussion Gee Bee R3 Donuts Fuel Plane Talk 24 May 08, 2009 09:40 AM
Discussion AIRWORLD GEE BEE R3 120" 40lbs. needs motor modest-master Sport Planes 16 Nov 19, 2008 10:38 PM
Discussion Gee Bee R3 Janusz Jawien Scratchbuilt Indoor and Micro Models 7 Apr 10, 2007 07:52 PM
