Old Nov 30, 2015, 12:43 PM
jumo004 is offline
Find More Posts by jumo004
jumo004's Avatar
Joined Apr 2010
streff, great stuff !!
If possible, please post a video ?
Thanks !
jumo004 is offline Find More Posts by jumo004
Old Dec 01, 2015, 05:09 AM
RNAF is offline
Find More Posts by RNAF
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
Eric,
Thanks for the remark. I'm fairly sure about the lower thrust. I used a 6mm motor I had lying around so I can't provide any details. I am interested, though, in what motor you used exactly? Could you post a direct link? I just purchased some motors off Banggood. 6x12 I think. Although there are also 6x14mm iirc.
I wish to stick to 6mm but I could use a little more thrust.. Any idea of the increased load (thus impact on required battery)?
Cheers
RNAF is offline Find More Posts by RNAF
Old Dec 20, 2015, 06:35 AM
streff is offline
Find More Posts by streff
Southport Merseyside UK
Joined Jan 2006
Video of Arado
Here is video of Arado
Arado.
Arado 234C (3 min 36 sec)
Incidently I have now 3d printed some fan housings and with 7mm motors am getting 19gm thrust which is very usefull.
streff is offline Find More Posts by streff
Old Dec 20, 2015, 06:39 AM
streff is offline
Joined Jan 2006
Latest edf
With the new Star Wars Film thought I would join in the action.
Found some 3mm depron, a mini-vapor brick and a 1s 30mm edf and got building.
No plans just played it by eye, 3 hours later and we were ready to try enjoy the result.
Span 380mm, weight 30gm including battery, 19gm thrust from edf.
Micro X Wing (2 min 39 sec)
Old Dec 20, 2015, 06:44 AM
streff is offline
Joined Jan 2006
RNAF
Sorry about the delay the link for the 6mm motors I used is
http://micro-motor-warehouse.com/col...cts/cl-0615-14
For the 7mm motors I use in my shrouds is
http://micro-motor-warehouse.com/col...cts/cl-0720-14
With the Inductrix shrouds and 6mm motors we get 13gm thrust with my shrouds and the 7mm motors 20gm and they only weigh a couple of gms more.
Old Dec 20, 2015, 10:24 AM
jumo004 is offline
jumo004's Avatar
Joined Apr 2010
TOO COOL !!!
Thanks.
Old Dec 20, 2015, 10:36 AM
streff is offline
Joined Jan 2006
As the Arado is now flying well and sorted. I have a full moulded fuselage and will transfer wings etc to that then paint it.
I will put photos and video on this thread in due course.
Old Dec 20, 2015, 10:51 AM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
streff,
Are you printing the shrouds yourself, and if so, are you sharing the file(s) on Thingiverse?
g
giuseppi is offline Find More Posts by giuseppi
Old Dec 20, 2015, 12:42 PM
RNAF is offline
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
9,5 grams, succes!
This is the second model I tried, succes! Now I used 2mm wall foam (found it by coincidence, dirt cheap). Added some carbon, moved the brick forward.
At 87% size I'm at about 10-15 mm from the leading edge to get a proper CG (too far rear was the cause of the previous failure).
It cruises at 50% and is extremely silent.
7mm motor would be a next step but I don't have shrouds
Too much fun!
Old Dec 20, 2015, 06:49 PM
AntiArf is offline
Find More Posts by AntiArf
AntiArf's Avatar
Joined Feb 2013
Neat build. The P80 is at the top of the list of wanted jets. Always wanted to build a full fuse version, but it would probably end up looking something like the Kyosho version, with intakes large enough to do the job. Also looks like you've proven once again that the cg often needs to be a good bit ahead of 25-30%, especially on small models. I've also found it to be true on small swept wing models.
AntiArf is offline Find More Posts by AntiArf
Old Dec 21, 2015, 04:54 PM
RNAF is offline
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
I'm working on a full fuselage one but I'm not too motivated due to weight issues. Fuselage alone weighs more than the entire model above (2 grams). I'm also thinking that I might lose too much thrust on ducting, even though I had to scale the exhaust. I'm not too afraid about the intakes - I'm willing to make a cheater hole. I do however remember that jet, not too pretty.
First I'll enjoy this one a bit more. Maybe another rebuild, doesn't take much to build these luckily
Old Dec 22, 2015, 09:37 AM
streff is offline
Joined Jan 2006
Originally Posted by giuseppi View Post
streff,
g
I have a friend who prints them for me and as I am thinking of supplying complete units to UK and European modellers am loath to sharing the files.
If anyone in the UK or Europe require shrouds or complete units please pm me.
Old Dec 22, 2015, 12:23 PM
addictedtoplanes is offline
Find More Posts by addictedtoplanes
and helis!
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
Finally got the time to demolish my 2nd inductrix, and threw together this Vulcan. It's scaled down from the Model Aviation 30" Vulcan by 36%. 11"wingspan, and 19 grams with a mini vapor brick, 2 stock inductrix fans and motors and a 150mah lipo. Glide tests look good, and it has enough power to slide across the floor. We'll see how she flies this afternoon. I'll get a video for you guys.
addictedtoplanes is offline Find More Posts by addictedtoplanes
Old Dec 22, 2015, 05:26 PM
and helis!
Canada, ON, Guelph
Joined Jun 2012
Well, the maiden of the Vulcan went very well, has enough power, and flies great! While I think using just one inductrix fan might be a little difficult with the weight, 2 fans can easily fly a 20 gram aircraft.
Micro Avro Vulcan EDF maiden flight (1 min 17 sec)
Discussion BVM P-80 Shooting Star Electrified jets Electric Ducted Fan Jet Talk 22 Apr 28, 2008 06:23 PM
New project: P-80 shooting star eaticus Electric Ducted Fan Jet Talk 12 Dec 02, 2005 09:32 PM
Cool Which Wing Profile did the P-80 Shooting Star have? ralf dvorak Scale Kit/Scratch Built 7 Oct 13, 2005 03:59 PM
Anyone flying a LEG 60" P-80 Shooting Star? IwantaJet Slope 3 Jun 03, 2005 06:53 PM
My P-80 Shooting star project begins...I need help! ssyed Electric Ducted Fan Jet Talk 8 May 08, 2004 03:12 PM
