Old Dec 28, 2015, 09:53 AM
Crash Override is offline
Find More Posts by Crash Override
is always breaking stuff :D
Crash Override's Avatar
United States, MI, Charter Twp of Clinton
Joined Dec 2014
You're welcome, Steve.
I'm waiting for the clearcoat to dry on my new one. It should be ready by the time the winds calm down here enough to fly - in two days. *grumble*
Crash Override is offline Find More Posts by Crash Override
Old Dec 28, 2015, 03:50 PM
Hugo Flynow is offline
Find More Posts by Hugo Flynow
Fond of Foam
Hugo Flynow's Avatar
United States, MD, Ridge
Joined Oct 2015
Originally Posted by SailingAlong View Post
Battrery placement has been a small issue that most have dealt with for this bird. I decided to dedicate the stock size battery to leave in the plane and charge it there. The CG is slightly off towards the tail but some added weight will be added to compensate. After getting the feel of how this Pitts flies, I will probably replace the battery with a 1500 or 1800 mah size. I hope I am able to attach the pics I took.
I laid the battery lengthwise from the front bay and secured it in the front to prevent shifting. Then I tood a peice of spongy foam to hold the battery in. I am easily able to replace the battery if I feel I need to. Charging will be easy and I have enough aircraft to rotate it into the mix as I fly the others. Works for me
Charging a lipo while in the plane can be very dangerous. One of the top 3 things lipo instructions tell you NOT to do. Just sayin....
Hugo Flynow is offline Find More Posts by Hugo Flynow
Old Dec 28, 2015, 04:54 PM
SailingAlong is offline
Find More Posts by SailingAlong
SailingAlong's Avatar
United States, MN, Bloomington
Joined Oct 2008
I am aware of that but will use this method. There is a bigger chance of a battery fire while flying, crashing , midair, and hard landings. I will take my chance.
Steve
SailingAlong is offline Find More Posts by SailingAlong
Old Dec 28, 2015, 07:14 PM
Fond of Foam
Joined Oct 2015
If you are charging your plane outside, the risk is equal I guess, except you lose the plane and the battery if something happens during charging.
In the end...it's your plane and you can do with it what you want!
Old Dec 30, 2015, 07:46 AM
Joined Dec 2014
It's a balmy 33F/1C outside, SW wind 6MPH/10KPH.
I think I'll be taking my sttiP out today - along with a couple other birds, of course.
Old Dec 30, 2015, 10:17 AM
Fond of Foam
Joined Oct 2015
Look on the other side of your rudder...
Raining here for 2 weeks straight...today is no different.
Old Dec 30, 2015, 02:27 PM
Joined Dec 2014
Whiskey Tango Foxtrot, over?
How dare they print sttiP reversed on the other side?!?
For the past two weeks here, it's been rain to snow and everything in between - except for today (just calm, cold, and grey) and Christmas Day (calm, cold, and sunny). Didn't fly on Christmas - I hosted the family get-together this year.
I hope you get a flying day soon.
Old Dec 30, 2015, 02:46 PM
Fond of Foam
Joined Oct 2015
Thanks CO....By saturday the sun should show up...which will scare everybody. People here will be squinting while shedding their gills.
I'm glad I got as much flying in as I did when we had 2 solid months of warm sunny and calm...I almost couldn't keep up with the nice weather! So it all evens out in the end...
Old Dec 31, 2015, 03:35 PM
Fond of Foam
Joined Oct 2015
Got my wattmeter today It's pretty cool.
First thing I did was try out my Pitts and it's new 10x7 slow flyer APC prop.
I rushed the experiment so I took a 1500 MaH 40C battery with 3.85 left on it and plugged it in. OK it's not a fully charged battery, but enough to give me an idea.
at WOT it was only pulling 13.8 amps...well short of the 20 amp ESC. Now we know!
Old Jan 02, 2016, 10:10 PM
Tinkersalot is offline
Find More Posts by Tinkersalot
Joined Jan 2016
So you could actually get away with a 1500mah 10c battery. Or increase your fly time with a 2000mah 10c battery, for the same weight as the 40c. ???
Tinkersalot is offline Find More Posts by Tinkersalot
Old Jan 03, 2016, 02:59 PM
Fond of Foam
Joined Oct 2015
Doing the math..technically yes...I would at least use a 15 C to allow for servo draw, But this plane is not a high amp usage plane. I think the motor is very underpowered and just doesn't draw much amps. The 10x7 prop really perked the plane up, but I guess there is still room for more!
Old Jan 03, 2016, 03:21 PM
PikeStaff is online now
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
I am aware this suggestion will cause some in here to go into apoplexy, but here it is:
Switch the ESC for a 40 amp. Install a 4s 1300 / 1500 / 1800 mAh batt, with a 10x8 ParkZone PKZ1005 or an APC Electric prop.
Beware aileron and elevator flutter above 75% throttle. Keep a close eye on the health of all hinged surfaces, as they will now show where the weakness in the stock assembly lies.
The motor will run very, very well on 4s. It will pull in the region of 24-28 amps on 4s, hence the need for a bigger ESC.
The plane will now be berserk on WOT. Don't say you weren't warned .
PikeStaff is online now Find More Posts by PikeStaff
Old Jan 03, 2016, 03:29 PM
Fond of Foam
Joined Oct 2015
Sounds like a killer combo! I fly in a somewhat limited area so I like a scale speed so I don't have to make my turns as frequent. Also, I try to keep flying somewhat relaxed, or I get too tense. I bet someone here will be all over that mod though!
Old Jan 16, 2016, 09:16 AM
Joined Dec 2014
Like to see video of one modded this way with the control surfaces coming off in flight so I can LMAO.
Flutter is a symptom of several things, but it is mainly a harmonic vibration in the flight or control surface due mainly to either improper maintenance or exceeding Vne. With this mod, one accomplishes both of those causes. To try to eliminate the flutter, I would replace the aileron and elevator servos with higher torque metal gear servos, replace the plastic clevises and horns with metal ones (preferably ball joint), and remove every last bit of slack throughout the entire surface control system. I might also install vortex generators just aft of the wings' leading edges to reduce or eliminate boundary layer separation.
Of course, the simplest and easiest way to eliminate flutter in this case (and most other cases as well) is to not exceed Vne - by tuning down the powerplant to match the airframe's upper design limit. If that still is not fast enough, buy a plane designed for much faster than you wish to fly.
http://www.wired.com/2010/03/flutter-testing-aircraft/
Speaking of mods, when the tail wheel assembly breaks on my new one (and it will), I intend to replace it with the smallest Sullivan steerable tail wheel bracket. It is a superior design over stock.
Old Mar 11, 2016, 11:40 PM
Mud Butt is offline
Find More Posts by Mud Butt
New Bee
Santa Cruz, CA. USA
Joined May 2007
Did everyone crash??
Hello to all, if anyone is still here, looks like it's been a while since the last post.
I'm going to put in my order for this little guy. I thought I better stop lurking in this thread and post something.
It's been a long time since I've flown a plank, probably 20 years. Been running 1/8 and 1/10 scale off-road for the last five years. I've got an old DX7 one of the originals that I've used for my helos and quads, that I'll use for the sttiP.
I've read probably 1/2 the posts here and the info has been great! I was wondering if anyone can tell me where in the US I can get the carbon fiber strips for the wing spars (reinforcement)? I'd like to find .5mm x 10mm x 75cm.
I'm getting the 3" foam wheels, 40 amp esc w/5amp ubec, 10x8sf prop, the sport cub landing gear, 4x htx900 servos.
Any other suggestions?
Thank in advance
Brian
Mud Butt is offline Find More Posts by Mud Butt
Herr Engineering Pitts Special crashnburn Sport Planes 9 Aug 16, 2003 12:41 PM
Robbe Pitts Special JeffD Aircraft - Electric - Airplanes (FS/W) 3 Nov 13, 2001 06:29 PM
Herr Pitts Special rubber-to-electric conversion mkirsch1 Sport Planes 11 Oct 25, 2001 10:59 PM
Robbe Pitts Special GMILL47 Scale Kit/Scratch Built 3 Oct 03, 2001 09:15 PM
Herr Engineering Pitts Special crashnburn Sport Planes 7 Jul 05, 2001 10:06 AM
