Old Mar 17, 2015, 09:28 PM
axerhand1976 is offline
Find More Posts by axerhand1976
Joined Jan 2014
never used that stuff before ...is it easy to use?
axerhand1976 is offline Find More Posts by axerhand1976
Old Mar 17, 2015, 09:48 PM
kman24 is offline
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Yes, very easy to use. It activates with water moisture either from the air or you can wet the parts you are gluing to speed up the process. Also, it does expand so it is important to use it sparingly. Unless you have some gaps to fill.
Kman
kman24 is offline Find More Posts by kman24
Old Mar 18, 2015, 09:58 AM
Joined Jan 2014
thx again, glenn
Old Mar 18, 2015, 10:24 AM
GradyLee is offline
Find More Posts by GradyLee
Parkstormer!
Raleigh, NC
Joined Jan 2010
Originally Posted by axerhand1976 View Post
thx again, glenn
+1 on the Gorilla Glue. Since it expands, I often glue the parts together, then tape over the "joint" with bi-directional (packing) tape to both limit the expansion and further strengthen the joint. Then, I can easily paint over the tape so that the joint's more-or-less invisible. One thing I know is that it will never break there again--just somewhere else!
GradyLee is offline Find More Posts by GradyLee
Old Mar 21, 2015, 03:39 PM
Joined Jan 2014
wow finally I had a wonderful flight with this plane. cg is perfect(I think lol) after glueing the front back on (bought a new cowl) went for take-off plane came up nice was flying straight and level with just a couple of clicks of down trim. I do need to change out motor. it flies alright just not very fast(due to my elevation 5500feet). but a very nice flying plane . glenn
Old Mar 21, 2015, 04:28 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
Good to hear Glenn
Kman
Old Mar 21, 2015, 04:50 PM
Joined Jan 2014
thx kman, like you said its a beautiful flying plane.
Old Mar 27, 2015, 06:57 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
Speaking of beautiful flying plane
Dynam FW-190 Overcast Skies (6 min 22 sec)
Kman
Old Mar 30, 2015, 02:08 PM
Joined Jan 2014
I love that look. I wish I could send you one to paint for me lol. today I did an engine replacement...... went from that slow 500kv to a 4240/620 sk3 stock was 24 amps and a meager 380watts.now a good 40 amps and 540 watts much better lol. hopefully will try it out in the skies if wind ever get s better. glenn for any of you wondering it bolts right on no mods at all.....
Old Mar 30, 2015, 02:44 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
Thanks! They are easy to paint I just used a couple small brushes to paint it and some paint samples from Home Depot. That's all it takes.
I think you will see a nice improvement with that motor, just from looking at your watt meter readings
Kman
Old Apr 07, 2015, 11:37 AM
p9o1r1sche is offline
Find More Posts by p9o1r1sche
just gettin started
United States, NC, Hendersonville
Joined Apr 2014
Maidened my FW190
Must say this is one great flying plane. Maidened it in 10 - 12 mph winds. Didn't need one click of trim.
First landing was perfect, into the wind, so the ground speed was slow. The second landing was not as smooth and bent the landing gear. What have others done about the weak landing gear wire? The retracts themselves are okay (not great), but the landing gear wire is barely adequate. Has anyone drilled out the retract to use a bigger, stronger wire? or sourced a stronger wire from somewhere?
p9o1r1sche is offline Find More Posts by p9o1r1sche
Old Apr 07, 2015, 01:08 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
Great to hear I was going to replace the wires at one point early on, but after I got used to the plane landing wise, I haven't bent them in quite a while. I actually bought a spare set of landing gear legs after bending the stock ones several times. But, then of course, I stopped bending them
Kman
New Product FW-190 Typ B 1200mm EPO retracts lights mopetista Electric Warbirds 18 May 24, 2012 11:15 AM
Sold Hobbico Flyzone Focke-Wolf 190 RxR FW-190 propflipper Aircraft - Electric - Airplanes (FS/W) 10 May 08, 2012 06:07 AM
Build Log GWS FW-190 in EPO Foam mcsarge Electric Warbirds 259 Feb 20, 2010 04:58 PM
Discussion Just finished my EPO FW-190 TopSpin GWS (Grand Wing Servo) 34 May 22, 2009 05:55 AM
Sold GWS EPO FW-190 PNP Brushless + Retracts!! $150 SHIPPED!! Andrew1944 Aircraft - Electric - Airplanes (FS/W) 2 Jul 21, 2008 02:26 AM
