'I'm going to glass with two layers of epoxy and 6oz 45 deg weave cloth. Wing saddle an extra layer. If still reasonably light I'll do a final layer of fine 2oz cloth so that I'll need less surface finish thus keeping weight down. So basically should end up around 14 oz in three separate layers with foam formers inside."
To me that seems like a lot of glass/epoxy over foam. Sure 14oz layup is necessary? I used fanfold on my 1/4 scale Me-163 and only gave it one layer of 3 oz cloth. Just saying........ J |
Latest blog entry: F7F Tigercat from Palmer Plans
I don't know if this would be of any help, but in humbertomelo's build of the Super Habu - 120mm EDF - Parkjetdesign, I had asked him about the weight the glass added. Sizable plane at: Length -72.8" WS-59"
http://www.rcgroups.com/forums/showp...6&postcount=73 If my conversion is any where close, the glass was just over 3 oz sqyd. |
You know your build bette than I Ace. I'm sure when you get to that stage that the model will "talk" to you and you'll know what it needs. Good luck and let's see some pics soon!
J |
There is a learning curve.
![]() J |
JIM!!
Glad to see the jet is coming together. I have a slew of Google Sketchup designs I've been working on between trips I'd like to build. I have been busy as a bee but there will be time for some collaboration and flying at the field soon I hope!! Eddie P |
Latest blog entry: The Gas Turbine Engine (with images)
To get better you have to spend a lot more. I've purchased direct from the maker in Austria but it took a while and also from Mike here int he USA. I've owned 3 of them, 90MM and 80MM. Mike, if he has them in stock, ships out very quickly but you will pay a slight bit extra. |
It's looking good Ace. I think you will find that once skinned it is very strong and light. The skin carries the loads. I normally cut out most of the bulkheads as I go along skinning. My F-16 has most of the formers/bulkheads cut out.
I should have mentioned the bulkhead strips, I call them nailers, a carpenter's term. Have a good time flying. J |
| Thread Tools | |
| Discussion Looking for a composite lightweight 90mm jet? | firehawkzach | Electric Ducted Fan Jet Talk | 21 | Jan 25, 2013 06:26 PM |
| Discussion Scratch Build RQ-7 Shadow Composite/Balsa | parri0923 | Balsa Builders | 2 | Jan 17, 2013 04:17 PM |
| Sold Stearman PT-17 scratch-build from Barron's Scale Classics Plans 1/6th Scale | spitfire1999 | Aircraft - Fuel - Airplanes (FS/W) | 5 | Jan 06, 2013 10:01 PM |
| Build Log Scratch Build Composite UAS System | parri0923 | UAV - Unmanned Aerial Vehicles | 6 | Jan 04, 2013 04:27 PM |
| Discussion Euro Fighter Typhoon scratch built for 90mm fan | Lboogie | Electric Ducted Fan Jet Talk | 56 | Jul 22, 2009 12:59 PM |
