Old Apr 20, 2015, 08:43 PM
ace_drummond is offline
Find More Posts by ace_drummond
ace_drummond's Avatar
United States, CO, Parker
Joined Mar 2001
Module Into Futaba 8JN
I picked up a really nice Futaba 8JN at the Toledo show and want to convert to 2.4 using a DIY module from Orange 2.4 DSMx compatible (requires + - and ppm.
This unit has an old style module with 10 pins (so FRSky module won't work here) and the round 5 pin DIN on the side.
I am trying to confirm the following:
1. Is this Futaba negative shift thus needing signal inverted?
2. I found the following pinout for another Futaba 5 pin DIN as follows:
1 = signal ppm/pcm (use ppm on sim software)
2 = ground both charge and/or ppm signal
3 = battery positive + (if linked to 5 tx wil power up on insert of plug,
but no tx signal, and the power meter will not go up indicating that
4 = positive + for charger, only works when tx power swith is turned off
5 = linkable to 3 to power the tx on plug insert
Does this look correct?
I'm thinking the place to connect is at the 5 pin DIN plug unless someone has a better idea?
Space internally is really tight so I may have to remove the old module to make room therefore if I knew the pinout for the 10 pin connector that might also work.
I'm trying to retain the built in functionality which includes servo reversing and centering controls as well as roll buttons.
Would appreciate any input to help me get this done.
Thanks//
ace_drummond is offline Find More Posts by ace_drummond
Old Apr 23, 2015, 07:55 PM
Joined Mar 2001
Update
With some help have found 10 pin configuration
left to right as you look at back of TX with module removed
1-2 PPM This PPM is Positive Shift!
3-4 +
5-6 -
Have hooked up DIY module and it works perfectly.
Want to refit DFT module in old AM module case and looking for DFT module pinout now.
Old Apr 24, 2015, 01:45 AM
orraman is online now
Find More Posts by orraman
Scottish Borders
Joined Mar 2006
Since you posted I have been looking for my Futaba 8JN in 70 years of modelling and general 'storage spaces'.
With your information I will continue excavating.
Thank you for posting.
Dave
orraman is online now Find More Posts by orraman
Wanted Futaba FP-8JN Radio uboinus Aircraft - General - Radio Equipment (FS/W) 1 Nov 21, 2013 06:39 PM
Sold 8 Channel AM Futaba FP-8JN & FP-R8K-AM irun4fundotca Aircraft - General - Radio Equipment (FS/W) 2 Apr 11, 2012 08:56 AM
Wanted Futaba 8JN AM Receivers TonyF3A Aircraft - General - Radio Equipment (FS/W) 0 Oct 13, 2010 10:02 AM
Discussion Dead Futaba FP-8JN. Need help. MountainMan43 Radios 6 Nov 04, 2008 05:29 AM
