Old Feb 18, 2015, 06:56 PM
I've got a Heli hankering
train06's Avatar
United States, TX, Arlington
Joined Mar 2014
Question
Main bearing blocks
I am wondering about the bearing blocks on an Align 500 DFC Pro, are they supposed to be situated with labels facing up top and bottom or label up on top, and bottom block with label facing toward main gear?
Mine are both facing with the label up....
train06 is online now Find More Posts by train06
Old Feb 19, 2015, 01:07 AM
train06's Avatar
Joined Mar 2014
I found the answer...for anyone that might have the same question.....the orientation of the bearing blocks are as follows on the Align 500 Pro DFC.....
Top bearing block! Printed side where it says "Align" goes facing down from the top of the heli...
Bottom Block: Printed side faces up looking down from the top of the heli you should see the print "Align" on the block.....
Old Feb 19, 2015, 01:29 PM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
There is a way to tell the correct way on most bearing blocks. The block itself is machined with a large recess to accept the bearing on one side, and a slightly smaller hole only big enough for the shaft to pass through on the other side. The smaller holes must face each other.
If you did it the other way there would be nothing to keep the bearings in place and the thrust from the rotor would push the bearings out of the blocks.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Feb 19, 2015, 03:07 PM
train06's Avatar
Joined Mar 2014
Yep found that out the hard way....I'd gotten the frame with blacks already installed, and did the cardinal sin.....assumed....;-)
Question Im looking for a 700e Main shaft block with bearing. jonathan7x70 Large Electric Helis 2 Dec 10, 2013 01:17 PM
Sold Align t-rex 600e pro dfc metal main shaft bearing block h60217 helifreak592 Aircraft - Electric - Helis (FS/W) 0 Nov 09, 2013 02:56 PM
Sold ALIGN T-REX 450 PRO DFC COMPLETE CARBON MAIN FRAME/ NEW Main Shaft Bearing Block helifreak592 Aircraft - Electric - Helis (FS/W) 10 Apr 30, 2013 01:17 PM
New Product New main bearing block with thrust bearing for Trex.(Waitting for test result) iceman33 Mini Helis 43 Dec 02, 2008 09:04 PM
Sold I accidentally bought the 600E main bearing blocks for my nitro... lovespicyfood Aircraft - Electric - Helis (FS/W) 4 Oct 22, 2008 08:07 PM
