Old Feb 16, 2015, 11:33 PM
Joined Feb 2014
Should I do a brushless conversion of my Kyosho Jet stream 1000
Hey all I've been into boats for years but got out before all of this brushless stuff started. What I have now is a Kyosho Jet stream 1000 with a .21 Nitro motor in it. I was wondering what would be a good brushless set up for this boa?t I'd like to get it moving into the 40-50 mph range if possible. I'd like to try to keep the parts bill below $300. Thanks in advance.
David
z06z33 is offline Find More Posts by z06z33
Old Feb 17, 2015, 01:53 AM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Here's a guy that converted one, he stares at it for the first 4 minutes of the video, when he runs it(at 04:00) it does pretty well. I'd go with a big outrunner in the 1000kv range on 6s, you dont want huge rpms going thru that driveline, just prop up!
Kyosho Jet Stream 1000 Upgrade Brushless motor Test 2012.mp4 (5 min 11 sec)
scorpion1 is online now Find More Posts by scorpion1
Old Feb 17, 2015, 04:54 PM
Joined Feb 2014
https://www.youtube.com/watch?v=SOB3vtuCvbM
Is he running in the 40mph range?
Old Feb 17, 2015, 05:42 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Yep
Old Feb 18, 2015, 08:45 PM
Joined Feb 2014
Yep
Can I use the original gas engine shaft and prop such?
Are these motors good?
http://www.hobbyking.com/hobbyking/s...ess_Motor.html
or
or
as for speed controllers
http://www.hobbyking.com/hobbyking/s...rless_ESC.html
or
http://www.hobbyking.com/hobbyking/s...C_4A_UBEC.html
Sorry for asking so much but when I quit messing with boats there was no such thing as brushless motors for RC boats
Thanks David
Old Feb 18, 2015, 09:26 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I would keep the rpms down and use a bigger prop. That driveline is older and wasnt meant for high rpms and brushless power, but lowering rpms to the 20,000 range should do well.
Of the motors listed I would go with the 4084 1050kv on 6s2p. That's a perfect 8s motor for modern boats but great for your boat on 6s2p.
Worst case scenario is your stock driveline wont hold up and you add a modern one, so try it as it is......................just my opinion.
I dont know what your stock prop is but I would try a 45-48mm to start out.
Can you couple that motor to your driveline...................right size and all?
I'd go with the 200a ESC
Old Feb 18, 2015, 09:36 PM
Joined Feb 2014
All I know is that its a metal prop lol I bought it off a guy used about 11 years ago and I've only run it twice. Also can you use airplane Lipos with boats?
Old Feb 18, 2015, 09:43 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
You can measure the prop diameter from tip to tip easily as i'm sure you are aware.
Do those airplane lipos have the ailerons.................some dont have them.
Old Feb 19, 2015, 09:11 AM
Joined Feb 2014
Ailerons?
Old Feb 19, 2015, 12:32 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Originally Posted by z06z33 View Post
Ailerons?
Couldnt resist a joke there
You can run any battery in anything if it can handle the amps. If they are 30c or better they will work, 40C+ is better
Old Feb 19, 2015, 04:26 PM
Joined Feb 2014
Haha yea all of my 6s are 60c's
Old Feb 19, 2015, 05:05 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Sounds great!
Old Feb 20, 2015, 12:03 PM
Joined Oct 2011
but whats the capacity??
dobydog6507 is offline Find More Posts by dobydog6507
Old Feb 20, 2015, 05:07 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Good point, didnt even cross my mind to think of that, I get in the assumption mode that someone isnt planning on running 1500mah batts etc.............
Old Yesterday, 10:58 AM
Joined Feb 2014
5000mah I use them to fly my ducted fan ME-262. Also I'm not sure my drive line will fit that motor as the boat is setup for a nitro engine.
Discussion Should I do a brushless conversion of my Kyosho Jet stream 1000 z06z33 Racing Boats - Internal Combustion 1 Feb 17, 2015 05:17 PM
Build Log Retro build- Kyosho Jet Stream 800 CWBETB Dock Talk 19 Jan 06, 2015 12:17 PM
Kyosho Jet Stream 1000 Questions??? cactus Dock Talk 4 Jun 09, 2008 10:08 AM
Gallery Kyosho Jet Stream 1000 cactus Your Plane Photos 0 Apr 17, 2002 11:17 PM
