Old Jan 09, 2015, 11:19 AM
OAK
OAK's Avatar
Norway
Joined Oct 2002
New Product
Dualsky coaxial motor
Seems like Dualsky is coming with some new motors suitable for F3P, including a coaxial version: http://dualsky.com/motor/typhoon.shtml
OAK is online now Find More Posts by OAK
Old Jan 09, 2015, 01:25 PM
United States, WA, North Bend
Joined Dec 2002
Lots of interesting stuff on the data sheet.
1. Low KV motors
2. PT props going to sell lefthand props for coax setups
3. the only gearing on the coax looks to drive rear prop at higher RPM.
4. Since no gearing for front prop maybe no 11 inch props.
Awesome to have DualSky building F3P equipment!!!!
Hurrah for competition!!
Vince
Vince Caluori is offline Find More Posts by Vince Caluori
Old Jan 09, 2015, 01:43 PM
DonA's Avatar
United States, CA, Placerville
Joined Feb 2006
Compared to the Dualsky RTR motors, the ESC is not part of the mount. Also, the 18g weight seems relatively heavy (compared to other approaches) unless the props are included in the weight. I also noticed the 9" prop for test purposes. At that low a kv, maybe it can swing bigger props than 9".
Don
DonA is online now Find More Posts by DonA
Old Jan 09, 2015, 10:18 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Interesting concept, but if they had driven the little intermediate pulley/gear then they could have used a lighter smaller motor and/or spun a bigger prop.
As it is gear ration between the two props could be close to 1:1.
It depends on the gear ratio and the pulley ratio, which will be multiplied to get the final ratio. The two look pretty close (one geared up, the other down)
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 09, 2015, 10:46 PM
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
I love the design. I think it could be made lighter.
Free
Free is online now Find More Posts by Free
Old Jan 09, 2015, 10:48 PM
Joined Dec 2002
Pat, i think you are right the pully ratio looks to be almost the inverse of the gear ratio. They are giving us counter-rotating props but no gear effect. The coax unit must be using the bigger of the two motors which may explain the weight.
Old Jan 14, 2015, 01:52 PM
Joined Dec 2002
2DogRC thinks he will have these in a few weeks . Price of coax around $60!!!!!
Old Jan 14, 2015, 03:09 PM
DonA's Avatar
Joined Feb 2006
I sent an email to 2DogRC expressing some concern with the gearing ratios as well as a question about how much prop diameter could the motor handle. The tests referenced in the ad only used 8 and 9" props.
Mark (2DogRC) forwarded the questions to Dualsky. Will let everyone know what the response is when I get it.
Don
Old Feb 09, 2015, 08:18 AM
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Three weeks have passed. Is there any response or progress?
feda is offline Find More Posts by feda
Old Feb 09, 2015, 10:09 AM
DonA's Avatar
Joined Feb 2006
No response from Dualsky or 2DogRC yet.
Don
Quick update from 2DogRC. Apparently, no testing was done with props larger than 9", whether the Dualsky can handle larger props is still a question. 2DogRC said they would be getting the Dualsky contra system in March.
New Product 25MM CNC Full Metal Coaxial Motor Mounting Seat HH_LJ Multirotor Talk 3 Feb 03, 2015 10:28 PM
Alert Dualsky multirotor motor promotion - lowest prices fotofly Multirotor Power Systems 2 Dec 03, 2014 05:54 AM
Alert Dualsky multirotor motor promotion fotofly Multirotor Talk 0 Nov 20, 2014 03:14 AM
Discussion Dualsky motor setup puffing batterys snyder_man Power Systems 6 Oct 01, 2014 11:34 AM
Alert 30% off Dualsky Motors, 15% off Emax Motors, 2dogrc 2dogrc Hot Online Deals 0 May 21, 2014 03:54 AM
