Old Aug 19, 2014, 12:51 AM
United States, AZ, Lake Havasu City
Joined Feb 2010
Large Tiger Moth
Having owned a .60 nitro powered silk covered Tiger Moth at one time, I always wanted another. I now have plans for such a plane, but in the mean time I came across the GWS Tiger Moth at a good price and bought it. I plan on installing floats, but the $80 price tag for GWS floats is a bit much, so I found a set of floats from another manufacturer for only about $20.00 shipped, so I ordered them.
The one question I have at this time is how robust is the brushed geared 400 power system? Should I just install a brushless motor or is the 400 system powerful enough to fly this plane aerobatically, no not 3D , just mild aerobatics.
Thank You,
SpadCat
SpadCat2000 is offline Find More Posts by SpadCat2000
Old Aug 19, 2014, 04:15 AM
Taipei, Taiwan
Joined Oct 2005
Hi SpadCat,
The brushed 400 system was powerful enough to fly this plane with 8-cell NiMh, many pilots applied it earlier than the wild introductions of brushless motors. But nowadays I'd apply brushless outrunner 450 size 1000KV + prop EP9050 or EP1060+ 3S lipo instead.
Back to the GWS floats, I wonder why it was quoted that high when you found it out. The suggested retail price is USD15.00 only. Probably it is rare now, so the vendor quoted it higher. Boss told me that there'll be GWS floats again, but it might take long to release the new batch thoguh.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Aug 19, 2014, 02:20 PM
Joined Feb 2010
Hi GWS CHEN,
OK, I will go ahead and install a brushless. Also, when the GWS floats become available, I will order at least another set if not two.
Thanks for the info!
SpadCat
Old Aug 19, 2014, 04:32 PM
semperfi1970's Avatar
Joined Feb 2012
SpadCat2000, good luck with the 450 brushless motor. You will be very lucky to find a good CG without adding a few ounces of weight to the nose. Here is mine with a 480 motor and a 2650mah 3s battery spinning a 12x6 prop just to find proper CG without adding dead weight.
GWS Tiger Moth 400 (2 min 21 sec)
semperfi1970 is offline Find More Posts by semperfi1970
Old Aug 19, 2014, 07:35 PM
Joined Feb 2010
I was planning on a 2200 3s and whatever motor I had laying around that would be large enough. If the combination does not help with the CG, I will go larger. I don't like to add dead weight if I can help it either.
My goodness, it must have been really cold that day! Your poor camera person was freezing. It has been a long time since I have experienced that kind of cold.
Thanks Simperfi1970, for the info and video. I always enjoy the videos you post.
SpadCat
Discussion Comparison FlyZone Ultra Micro Tiger Moth, SE5A, and Nieuport 17 Torch8 Micro Ready-to-Fly 15 Nov 08, 2013 10:04 PM
Discussion Great Planes vs GWS Tiger Moth? ForeverFlying Foamies (Kits) 0 Sep 20, 2013 02:51 AM
Brushless for GWS large Tiger Moth? The 400C one. yukondog Power Systems 13 Feb 14, 2006 03:42 AM
Large Tiger Moth? spessx Parkflyers 4 Dec 01, 2003 06:37 PM
Power System for a Large Tiger Moth doc-e Power Systems 1 Sep 12, 2003 08:17 PM
